RE: Purple Brushless Electric Ultimate BiPe
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RE: Purple Brushless Electric Ultimate BiPe
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Purple Brushless Electric Ultimate BiPe - 1/23/2007 3:03:30 AM
PJD1
Status: offline
I built an electric ultimate biplane, and purchased a Tower Pro BMC 25A esc to run it from Raidentech. Their website indicates that you can set the cutoff voltage at 7.5V or 5V with a jumper switch. When the stuff came in there were absolutely no instructions for setting cutoff voltage or programming the brake on or off. I have contacted Raidentech at least 3 times for instructions and received no reply. Does anybody know how to set the cutoff voltage? I am using a 3 cell Li poly battery, and don't want to ruin it by discharging too far. Also, I am using a SK400XTmotor, which is way underpowered. It can bearly maintain altitude much less do loops, rolls, etc. Also, I had to add 84 grams of weight to the nose to achieve balance. My battery is only 1100 MAH, so i figure a larger battery up front will help with the balance. Any help on these issues will be appreciated.
(in reply to opjose)
       Post #: 51
RE: Purple Brushless Electric Ultimate BiPe - 1/23/2007 4:11:59 AM
opjose
Status: online
The instructions are available on line...
I have the documentation that came with a Towerpro 60Amp Esc which pretty much worked for the 25A version.
Here is the link
http://www.hobbywing.com/upload/esc-e.pdf
You also may be getting poor output from the motor because the Towerpro ESC timing is not optimal for your motor.
This made a BIG difference for me... the ESC defaults to timing for the INRUNNER, which does not work very well.
The default cutoff is "medium", this is calculated as a percentage of measured total voltage (the ESC calculates the number of cells to use for this) and should be fairly safe.
Re: Weight
GET A BIGGER BATTERY!
Never add unusable weight to a plane if you can avoid it... I use the 1800mAh and 2200mAh that Nitroplanes sells, which work very well with this plane.
Who did you e-mail, Raidentech?
Did you purchase it through them or from Nitroplanes?
< Message edited by opjose -- 1/23/2007 5:20:02 AM >
_____________________________
Build em'', fly em'', crash em'' and build more.
(in reply to PJD1)
       Post #: 52
RE: Purple Brushless Electric Ultimate BiPe - 7/8/2007 4:52:46 AM
morespeed
Status: offline
i'm using the park 480 - 910kv and eflite 40amp controller, max amp 2100 battery
and 10 x 7 slow flyer prop.
gotta say this plane is great to fly, i'm having a blast with it.
       Post #: 53
RE: Purple Brushless Electric Ultimate BiPe - 10/13/2007 8:58:33 PM
crashinbash
Status: offline
Hi guy's, I'm soon to be a newcomer of biplanes since I looked at my girlfriends visa statement. I don't think I can wait till Christmas...... so now that I know what I'm getting I figure the sooner I buy an elect. setup the better. I've never flown any planes driving more than 2 servos, I have a parkzone brushless stryker and j3 cub but I do fly a number of 6ch helicopters. I've got a simulator and practicing on the e-flite ultimate which I can already fly patterns on pretty good after a few hours.
I plan on using this speed controller http://www.unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=2164 , will it drive the 4 servos without a problem or should I get a ubec and separate battery? I notice no one else is really running a separate bec so I'm guessing it's not really necessary. With my hei's I only use a bec when the weights over 500g or using more than 3s batteries.
Also considering motors since I'm a newb to biplanes I was looking at this motor, http://www.unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=3886 and using a low throttle curve until I'm comfortable doing more maneuvers. Is this way too much power with direct drive for this plane? or will I be ok if I'm driving the motor under 80% of it's potential power?
I'm going to use my 20c 1700mah 3s1p batteries and 20c 1800mah 3s lipo's I use in my helicopters for this plane
Thanks for any help
Heli's........ It is your destiny..... and perhaps your demise.
http://www.geocities.com/the_b_i_g_01/BIG_RC.html
(in reply to morespeed)
       Post #: 54
RE: Purple Brushless Electric Ultimate BiPe - 10/14/2007 3:17:49 AM
opjose
Status: online
While you should be fine with the ESC ( Overkill with an ESC never hurts ) as the servos will at most only draw 1.5 to 1.8 A at worst....
The motor is a bit big for this plane.
The plane really only needs about 18A 250-350 Watts or so for almost unlimited verticals.
Heck I fly mine with a Frio which only draws 160 watts max.
You mention "throttle curve"... "this ain't no heli"... where that is applicable.
If you keep the prop size down though you will not draw more than 20-28A with say a 9x6E which is FAR more than enough for this plane.
(in reply to crashinbash)
       Post #: 55
RE: Purple Brushless Electric Ultimate BiPe - 1/3/2008 5:08:03 AM
texastomek
Status: offline
I flew my red ultimate for the first time today. I have a bit of an extreme setup: E-flite Park 10 motor and a 2100mah battery. This gives a short flight time < 10 min but provides LOTS of power. I do unlimited vertical at half throttle with a 11x7SF prop. This is a small prop for the motor, but any bigger and my bipe would counter-roll to the torque to the point of being un-trimmable. The plane is definitely not a trainer with this setup. It flies FAST and does not slow down for landing. I haven't weighed it yet because I don't have a small scale, but I'm sure it's considerably heavier than it should be.
I'm keeping the battery hatch door sealed with velcro. I also use velcro to keep the battery in place. I'm having problems linking the lower wing aileron pushrods from my servos to the horns. I used the little metal connectors on both the servo and horn sides of the pushrod but this is not giving me a stable connection. How did y'all make this connection???
       Post #: 56
RE: Purple Brushless Electric Ultimate BiPe - 1/3/2008 5:17:41 AM
opjose
Status: online
I replaced the connectors.
I used "quick" connectors at the servo horn if I recall correctly and metal dubro connector clips at the aileron polls.
It sounds like you turned yours into a small missle!
< Message edited by opjose -- 1/3/2008 5:18:03 AM >
(in reply to texastomek)
       Post #: 57
RE: Purple Brushless Electric Ultimate BiPe - 1/4/2008 3:38:15 AM
texastomek
Status: offline
I have a LiPo charging question...
I originally bought the park-zone charger with built in balancer because it was cheap ($30). However, this charger is just weird - it gives me errors and it seems like it keeps charging indefinitely until I get tired of waiting and simply stop the charge. Thus, I want to get a better charger but I'm confused by the different options out there. I like the idea of GP PolyCharge4 (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKAU0&P=0) but I don't know if it balances...and if it doesn't, would I have to get 4 separate balancers to charge 4 batteries simultaneously??? This would make it unpractical. I'm also looking at the GP Triton JR (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMAH9&P=0) but from what I read, that doesn't balance either. I would have to get a balancer for that unit. And it only charges one battery at a time? Is that right? I'd be fine with this if I had no other choice. Also, can I directly connect my electrifly battery (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMDN3&P=ML) to these chargers or would I have to but some sort of connectors?
What are you guys using? Please help!
       Post #: 58
RE: Purple Brushless Electric Ultimate BiPe - 1/4/2008 3:59:01 AM
opjose
Status: online
Get whichever charger you want... I prefer the ICE charger over the Triton as it's slightly cheaper, and FAR more versatile...
It's ability to graph cycles ( so you can see the battery trend ) is very helpful, etc.
And then you stick one of these on: CLICK ME!
The multiple battery chargers such as the Polycharge are very handing for field use when you want to charge multiple batteries. In this case you would need one of the above for each set of batteries you want to charge at the same time.
However the Polycharge is not very "smart". As such it has no provisions for doing the things that the ICE can do ( the triton does many of the same things though IMHO not as well... ).. such as testing battery capacity, battery cycling under load, NiCD deconditioning, etc.
So I purchased a Triton as my general purpose charger which I have hooked up to a converted 450 watt PC power supply, and then TWO Hobbico Quick field chargers ( each charges two batteries at the same time ) in a Goldberg Electro-Tote field box with a 27Ah sealed gel battery.
I have several Equinoxes which I use on either.
The Equinox will balance the battery as the battery is being charged. It goes between the charger and the battery pack.
       Post #: 59
RE: Purple Brushless Electric Ultimate BiPe - 1/21/2008 1:42:32 AM
jumper666
Status: offline
Acft: http://www.nitroplanes.com/pubrelulbiar.html
Motor: Scorpion 3008-32 http://www.rcdude.com/servlet/the-218/Scorpion-3008-dsh-32-Brushless-Motor/Detail
Prop: 10X7 or 9X7.5 prop data with Scorpion: http://innov8tivedesigns.com/Scorpion/Scorpion%203008-32%20Specs.htm
AUW: with 2200mAh = 2lb 1oz with 1300mAh = 1lb 15oz
Enlarged servo holes so they could accept HS65-HB's
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by jumper666 -- 1/21/2008 8:49:33 PM >
       Post #: 60
RE: Purple Brushless Electric Ultimate BiPe - 1/21/2008 2:04:27 AM
opjose
Status: online
Looks nice, good combo too.
(in reply to jumper666)
       Post #: 61
RE: Purple Brushless Electric Ultimate BiPe - 1/21/2008 8:52:08 PM
jumper666
Status: offline
opjose, thanks. If/when it ever warms and the winds die, we will see how she flies. Forcast in DAL/FTW area calls for cold, windy, with on and off showers for the next week.
       Post #: 62
RE: Purple Brushless Electric Ultimate BiPe - 1/22/2008 10:58:38 PM
opjose
Status: online
quote:
ORIGINAL: jumper666
That sounds like our forcast for the next two MONTHS!
Ugh.
       Post #: 63
RE: Purple Brushless Electric Ultimate BiPe - 3/12/2008 4:26:11 AM
jumper666
Status: offline
Mine (post #60) maidened today. It went well. The Scorpion is a GOOD motor. Am considering another Scorpion for another build. Make sure to use a 20C or better battery. The 12C I used was okay but left something to be desired. Several have commented about the cg placement. Yes, it is as far forward as plans indicate. You might let it slip a tiny bit aft but not by more than a mm or two. Do everything you can to move weight forward. My battery is firm against the back side of the firewall. <
