RE: Craftsman 55cc    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Craftsman 55cc
Page: <<   < prev  1 2 [3]
Login
RE: Craftsman 55cc - 12/17/2006 6:49 AM
cu. in.
Score: 100
Last Login: 1/27/2012
Status: offline
Nice looking prop hub. What are the 6 (?) holes for on the rear surface (toward the engine) of the hub?
Bruce
Hide Signatures
(in reply to flipflop)
       Post #: 51
RE: Craftsman 55cc - 12/17/2006 7:34 AM
captinjohn
Score: 247
Last Login: 5/19/2013
Status: offline
flipflop: Nice work! What knurling tool did you use on face of adapter. Thanks Capt,n
_____________________________
I never met a engine I did not like !
Hide Signatures
       Post #: 52
RE: Craftsman 55cc - 12/17/2006 4:02 PM
flipflop
Score: 100
Last Login: 12/23/2012
Status: offline
The six holes are drilled with the hub mounted to my rotary table. They are used to "index" the hub while I'm machining the slots in the hub.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to captinjohn)
       Post #: 53
RE: Craftsman 55cc - 12/17/2006 6:22 PM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
Another way to make 4 grooves...Drill a prop bolt hole exactly in the middle of a 2" square block. Put the prop hub on the engine...Bolt the square block on the end of the hub...Clamp the hub in your mill vise, use a 1/2" ball end mill to make grooves in the hub...
Click for fullsize
RC Ignition
Hide Signatures
       Post #: 54
RE: Craftsman 55cc - 12/22/2006 4:46 PM
tim220225
Score: 100
Last Login: 4/17/2013
Status: offline
Even another way or two is to use hex or square collet blocks. leave just enough material on one end or the other of the hub, insert it in the collet block and clamp it in the vise. use a machinists jack under the hub for support. Mill a slot and turn or index the block. Have also done the same thing with my Yuasa spin indexer.
Hide Signatures
(in reply to Antique)
       Post #: 55
RE: Craftsman 55cc - 12/23/2006 2:38 AM
BME
Score: 100
Last Login: 3/1/2009
Status: offline
Looks like you borrowed the idea from BME.
Hide Signatures
(in reply to tim220225)
       Post #: 56
RE: Craftsman 55cc - 12/23/2006 3:59 AM
tim220225
Score: 100
Status: offline
Keith your design for your hubs and timing rings are pretty slick in my opinion.
< Message edited by tim220225 -- 12/23/2006 4:00 AM >
Hide Signatures
(in reply to BME)
       Post #: 57
RE: Craftsman 55cc - 1/9/2007 5:58 AM
mnrcaerobat
Score: 100
Last Login: 4/27/2013
Status: offline
I stopped at Sears today and they had a 55cc saw on clearance. It was used, but probably minimally. I might be interested in doing a conversion, but don't know much about it. Does anyone have any input?
It sounds like I need a carb adapter? What is that for?
Where can I get a prop hub? I don't have a lathe or machine tools.
I would like to go with an electronic ignition. Is the ss the way to go? What others are there?
WHat about a muffler?
WHat else?
Brian
Hide Signatures
       Post #: 58
RE: Craftsman 55cc - 1/10/2007 12:14 AM
AIRPLANENUTS
Score: 105
Last Login: 5/18/2013
Status: offline
Flipflop, is this the saw your engine came from?
http://www.sears.com/sr/javasr/product.do?cat=Power+Lawn+Equipment&pid=07135085000&vertical=LAWN&subcat=Chain+Saws&BV_UseBVCookie=Yes
I'd like to make this my first conversion. I don't have a lathe, so if anyone has links to the machined parts, I'd love to see 'em!
"Futaba gets it right the first time."
Hide Signatures
(in reply to mnrcaerobat)
       Post #: 59
RE: Craftsman 55cc - 1/10/2007 2:47 AM
flipflop
Score: 100
Status: offline
That's it.
Hide Signatures
(in reply to AIRPLANENUTS)
       Post #: 60
RE: Craftsman 55cc - 1/10/2007 5:39 AM
mnrcaerobat
Score: 100
Status: offline
http://ak-models.com/mm5/merchant.mvc?Screen=PROD&Store_Code=AKM&Product_Code=RM-37&Category_Code=RichModel_GasPower
http://ak-models.com/mm5/merchant.mvc?Screen=PROD&Store_Code=AKM&Product_Code=RM-36&Category_Code=RichModel_GasPower
Now that I have the motor, I am going to be sick without one of these planes. I might just have to sell off my fleet and get this going.
Brian
Hide Signatures
       Post #: 61
RE: Craftsman 55cc - 1/12/2007 4:20 AM
captinjohn
Score: 247
Status: offline
billzair: Nice looking 55cc engine. Did you run it with mag ignition first. Is it as smooth with electronic ignition. It looks lite....what does it weigh ready to run? Thanks Capt,n
Click for fullsize
Hide Signatures
(in reply to rev)
       Post #: 62
RE: Craftsman 55cc - 1/15/2007 10:10 PM
mnrcaerobat
Score: 100
Status: offline
quote:
ORIGINAL: mnrcaerobat
WHat else?
Anyone??
Brian
Hide Signatures
       Post #: 63
RE: Craftsman 55cc - 2/18/2007 6:26 AM
AIRPLANENUTS
Score: 105
Status: offline
Looks like Sears has discountinued these saws. Anyone have another source for the 55cc engine that comes in it, or similar (besides ebay)?
< Message edited by AIRPLANENUTS -- 2/18/2007 6:33 AM >
Hide Signatures
       Post #: 64
RE: Craftsman 55cc - 2/19/2007 3:55 AM
AIRPLANENUTS
Score: 105
Status: offline
Stopped by Sears today. I was told these engines were recalled due to emission issues. Bummer. I was gonna see if Scott @ Brillelli would convert one for me.
Hide Signatures
       Post #: 65
RE: Craftsman 55cc - 2/22/2007 3:50 AM
billzair
Score: 100
Status: offline
mcculloah sells a 50cc saw for the same price at menards.
If it came from a chainsaw or weedwacker, its GOTTA be good.
Hide Signatures
       Post #: 66
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: Craftsman 55cc
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
