Vision Peak Ultra vs MRC superbrain 977
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> Vision Peak Ultra vs MRC superbrain 977
Page: [1]
Login
Vision Peak Ultra vs MRC superbrain 977 - 10/28/2006 5:51 PM
andrew222
Score: 100
Last Login: 11/20/2009
Status: offline
Im specifically looking for an AC/DC charger with lipo capabilities. After a few months of searching this is what I have come up with.
The superbrain has a discharge function which i believe is critical in maintaining lipos, however I hear a lot of crap about charging lipos with this one.
Vision peak ultra less fancier. No discharge. Otherwise should be reliable.
Im leaning more toward the superbrain but hesitant. Thanks
Edit: also considering the Swallow 2.
< Message edited by andrew222 -- 10/28/2006 5:56 PM >
Hide Signatures
       Post #: 1
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/28/2006 10:16 PM
guver
Score: 106
Last Login: 11/21/2009
Status: offline
Dischargeing lipos is not necessary.
977 uses a questionable/debatable charge routine.
No idea about the vision, How about a hobbico Elite?
_____________________________
good judgement comes from experience
experience comes from bad judgement
Hide Signatures
(in reply to andrew222)
       Post #: 2
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/28/2006 10:22 PM
Elmo6s
Score: 100
Last Login: 10/7/2009
Status: offline
I would recommend just picking up a power supply and grabbing the Duratrax Ice. You'll find that a power supply is very handy in R/C and the Ice is the best charger available in its price range...
President Boom Boom Batteries
Hide Signatures
(in reply to guver)
       Post #: 3
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/28/2006 10:25 PM
guver
Score: 106
Status: offline
Definately , if you can use a dc charger along with any 12 volt power supply it will open up a lot more possibilities.
Hide Signatures
(in reply to Elmo6s)
       Post #: 4
TheLinkster
Score: 100
Last Login: 6/11/2009
Status: offline
I have a Vision Peak Ultra and its never given me any problems... Its a very nice charger.
Or if you get a power supply theres also the Triton Jr. Its DC only but the screen is backlit and it discharges and cycles.
Member of Team Nomadio 007
My R/C's... T3 FT, TC4 FT, 777MSR, Mini-Z MR-02, Mini-LST, Micro-T and an Xmod Evo
Hide Signatures
       Post #: 5
-Inverted-
Score: 100
Last Login: 9/7/2009
Status: offline
Im selling my Vision Peak Ultra, leaving the hobby for a SHORT break. PM me if your interested.
The Living Legend
Hide Signatures
       Post #: 6
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/29/2006 2:49 AM
Nitronutt
Score: 100
Last Login: 9/21/2009
Status: offline
PEOPLE KEEP MISTAKING THE 977 FOR THE 969!!!!!!!!
THE 977 CHARGES UP TO 3S LIPO'S JUST FINE! I HAVE ONE! I HAVE LIPO'S!
It was the 969 that had LiPo issues!
The 977 can charge 2 batteries at once (Lipo or other). It can discharge one and charge another. It works great and is easy to use.
However, I have never heard that it is necessary to discharge LiPo's. The charging has to be specific, but there isn't a need to discharge.
LST-Big Joes-RPM • Jato • Mini LST2-Mamba-7.4v-HS65MG • Wide Stampede-FLM Ext. Chassis-Mamba 5700-11.1v-Solid Diff
Hide Signatures
(in reply to -Inverted-)
       Post #: 7
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/29/2006 3:23 AM
guver
Score: 106
Status: offline
Unfortunately, it is true that many people have mistaken the 977 for the 969 or vice/versa. The 969 was little more than a glorified digital timer charger for lipos. It was a dangerous chargeing routine in my opinion (without a voltage cut-off unlike the 977)
< Message edited by U-dUd -- 10/29/2006 3:48 AM >
Hide Signatures
(in reply to Nitronutt)
       Post #: 8
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/29/2006 3:37 AM
andrew222
Score: 100
Status: offline
Thanks for the replys guys.
ewww...977 doesn't have a voltage cut-off? Is it that serious of a problem?
This charger looked REALLY good http://www.modelflight.com.au/rc_model_chargers/swallow_2.htm What do you think?
Hide Signatures
(in reply to guver)
       Post #: 9
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/29/2006 3:46 AM
andrew222
Score: 100
Status: offline
U-dud: the hobbico accu-cycle elite looks REALLY good too. Thanks man. Possibly the best choice for an AC/DC unit.
Hide Signatures
       Post #: 10
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/29/2006 3:49 AM
guver
Score: 106
Status: offline
That looks really nice and is new to me. I edited previous post for clarity. The 977 Does have a volt cut-off.
Hide Signatures
       Post #: 11
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/29/2006 3:50 AM
zephar123
Score: 100
Last Login: 8/6/2009
Status: offline
quote:
ORIGINAL: andrew222
977 has a voltage cutoff the 969 was one that did not
Hide Signatures
       Post #: 12
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/29/2006 3:56 AM
-Inverted-
Score: 100
Status: offline
Accu Cycle is nice but the charge rate is super low.
The Living Legend
Hide Signatures
(in reply to zephar123)
       Post #: 13
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/29/2006 4:05 AM
bxpitbull
Score: 100
Last Login: 7/28/2009
Status: offline
quote:
ORIGINAL: Nitronutt
Thank you. I have been saying that since I started using this charger. Maybe now people will get it. And it comes with its own powersupply. Not as intricate as ICE or the Triton, but when going li-po, the need for balancing isnt as extreme as sub c's...especially when using a low voltage cut-off. But, you cant change people and their way of thinking.
HPI Hara Pro 4 Novak GTB/3.5 HPI R40 HPI Savage OFNA Big Block w/oversized cooling head.
Hide Signatures
       Post #: 14
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/30/2006 2:53 AM
Nitronutt
Score: 100
Status: offline
quote:
ORIGINAL: andrew222
...ewww...977 doesn't have a voltage cut-off?...
RE-READ HIS POST! THE 977 DOES HAVE A VOLTAGE CUTOFF!!!!!!
Hide Signatures
       Post #: 15
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/30/2006 3:27 AM
andrew222
Score: 100
Status: offline
guys I think im just going to go with the swallow AC/DC 2. Its the best charger out of all of them.
Hide Signatures
       Post #: 16
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/30/2006 4:00 AM
jamesdickinson
Score: 100
Last Login: 12/21/2006
Status: offline
Definately get the Swallow 2. I have one of these, the thing is awesome!
supports every battery type out there pretty much, has several cycling functions, adjustable charge and discharge rates, lots of lipo options, plus you can attach the SJ LCB-6C lipo balancer thing to it.
I dont even look at my other chargers anymore. the swallow rocks
Hide Signatures
       Post #: 17
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/30/2006 4:05 AM
guver
Score: 106
Status: offline
Does anyone know the max power of the swallow ac/dc 2 ?
Hide Signatures
(in reply to jamesdickinson)
       Post #: 18
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/30/2006 7:32 AM
andrew222
Score: 100
Status: offline
what do u mean by max power?
Hide Signatures
(in reply to guver)
       Post #: 19
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/30/2006 4:20 PM
guver
Score: 106
Status: offline
Max power in wattage. I want to know the max current at the max voltage multiplied together. It has a 5 amp limit and looks to be a 22-24 volt limit , but probably is not a 120 watt charger. It may be more like a 50,63,90 watt. That's what I want to know.
Hide Signatures
       Post #: 20
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/30/2006 5:21 PM
andrew222
Score: 100
Status: offline
how does that affect the charging quality?
Hide Signatures
(in reply to guver)
       Post #: 21
RE: Vision Peak Ultra vs MRC superbrain 977 - 10/30/2006 6:06 PM
guver
Score: 106
Status: offline
It does not affect the charge quality, but does affect the time.
An example might be charge a 14 cell battery may only do it at 3 amps rather than the 5 amp max. (this is if it is perhaps a 63 watt)
Hide Signatures
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.453RCU1
