Volfy
Joined: 1/4/2002 From: Houston, TX, USA Status: offline
Back gear belt drive, power cross feed, cam lock spindle, and a nice quick change gearbox are the main features I am looking for in my next lathe. I'm not fond of gear heads for the reasons Tim220225 mentioned. Also, most of gearheads in the price range I'm looking at typically don't have spindle speeds below 70rpm. Back gear belt drive can get down to 50rpm for thread cutting. I would like a larger lathe, if only for the mass and rigidity. Most of the stuff I'll use a lathe for are not that big, but having the size and capacity sure would be nice. Jet made in Taiwan tend to be better quality and precision than the copies made in China. But even Jet will eventually move all their production to the Mainland. I do keep an eye on Ebay for a nice used Clausing or Mazak for sale locally, but I have no problem buying brand new imports. Problem with the imports is that quality could vary greatly - even among machines that look almost identical. My experiences are that as long as you do the home work up front and don't buy blind, there are good import machines.
_____________________________
Si vis pacem, para bellum.
