Another HS-5625 Failure -- This one from Jan 02 Lot
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Another HS-5625 Failure -- This one from Jan 02 Lot
Page: [1] 2   next >   >>
Login
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/20/2003 1:13:13 AM
hilleyja
Status: offline
Well I dillegently watched this thread for the last several months because I had bought (5) Hitec digitals to put in my 1/4-scale Cap 232 for a winter project.
By the time it died down it appeared that the problem with the Hitec Digitals was limited to older versions and solved by resetting them to factory starts with a v1.03 programmer.
I was running a Futaba RX and setting up my tail surface controls (2) HS-5625s for elevator (AILEVATOR function) and (1) HS-5645 for the rudder. I had no problems, everything went together well and then came the time to setup the throttle. All of my servos are lableled Jan 02, v1.02.
Since I had to salvage an HS-422 from another airplane I also salvaged the Hitec Supreme 3200 8-channel RX. I setup and installed the throttle servo and hooked up all to the Hitec RX. Less than 5 seconds after energizing the RX the channel 2 elevator servo deflected hard over to the left. No problem, I have the Hitec programmer and it was upgraded to v1.03 recently.
I executed the programmer's "reset-program", the servo went through the left-then-right deflection process and then responded with "success". Now that servo will not deflect more than a couple of degrees and running through the reset process again didn't solve anything.
Since I recently purchased another set of Hitec digitals for my Creek Hobbies Sukhoi, I swapped out the bad one for an HS-5625, Mar 02, v1.03. I used the programmer to reset that one and then installed it. Everything is working fine now BUT!!!!
If that servo had failed in flight there is no doubt in mine mind I would have lost that airplane -- now I'm afraid to trust the rest of the servos with an $1800.00 investment.
I'm looking for a warm fuzzy from Hitec -- telling me that I had one of the rare failures is not going to hack it. I most certainly will be testing the other servos but given the failure scenario of the above that won't give me the warm fuzzy I need.
_____________________________
Jim Hilley
AMA #671825
RCCA# 758
Twist 150 Brotherhood #14
       Post #: 1
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/21/2003 10:34:11 PM
MikeMayberry
Status: offline
I would like to get a little more information and would prefer to talk to you on the phone, so please call me @ (858)748-6948 x 302 and I would be happy to talk to you about this.
In my experience, if a servo is going to fail it will do so within the first few minutes. That is why it is always a good practice to let the servos warm up and prove themselves to be worthy for an airplane before flying them for the first time. Many people will fly a set of servos in a "beater" before they put them in a big bird.
Also be aware that with such a substantial investment you should consider the coreless motor servos which if you were to switch to a JR or Futaba you would be using. Neither of those two companies offers anything like 5625MG so making a comparison to them would not be fair. The coreless motors that are used in the high end servos like the 5945MG which is what I would recommend in the larger, more expensive birds.
The 6 series servos are designed for sport use; however, with the digital curcuit they are very impressive but they are still a sport level servo. If you want the best then you need to go with 5945MG that uses a coreless motor like the JR and Futaba high end servos.
Mike.
(in reply to hilleyja)
       Post #: 2
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/21/2003 11:52:52 PM
AV8TOR
Status: offline
Boy I only have one HS-5645 and I have been following these all to frequent post of digital failures. Sure makes flying more UN-nerving.
       Post #: 3
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/22/2003 8:17:52 PM
hilleyja
Status: offline
After a lengthy discussion on the phone with Mike Mayberry I was still not convinced 100% that these servos failed infrequently but have decided to essentially "break them in" on the bench. I have a total of 10 of these Hitec "sports plane" servos and currently 5 of them are installed in my Hanger 9 1/4-scale Cap 232. I hooked up each servo to my HFP-10 digital servo programmer/tester and ran it for over 15 minutes in auto test mode. In 15 minutes I probably got several hours worth of servo activity. None of them failed -- I've got my warm fuzzy for now. I will duplicate this test for the other servos before I install them in an airplane.
Now, "was still not convinced 100%"!!!! This post of mine was perpetuated by my skepticism of these servos from reading all of the posts over the past year and then having one of the first ones I've use fail on me. Hitec still insists these servos do not fail any more frequently than any other, but based on my statement above I still can't bring myself to be 100% convinced but will fly my airplane in its current configuration.
BTW, I once again used my Hitec programmer to reset the failed servo. This time the servo work perfectly afterward. My previous several attempts were identical to this one????
< Message edited by hilleja -- Jan 22 2003 3:36PM >
Jim Hilley
AMA #671825
RCCA# 758
       Post #: 4
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/22/2003 10:00:16 PM
AV8TOR
Status: offline
[QUOTE]Originally posted by hilleja
"break them in" on the bench. [/QUOTE]Gees are we talking motors or servos here Would you so kind as to explain this procedure.
Nothing that came with my servo mentioned anything like this.
       Post #: 5
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/24/2003 1:42:51 AM
Whymee
Status: offline
Maaannnnnnnn.......
I know how ya feel hilleja, how would you behave if you had 14 Hitec Digitals ready to go up? (in one plane)
Nervous is not quite the adjective I would use. ( or is it verb?)
Good luck to us all....
       Post #: 6
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/24/2003 1:58:53 AM
WreckRman2
Status: offline
I just know someone is waiting for me to chime in so here goes...
First off I am glad to hear you found the problem before you sent the aircraft in the air so you got one up on me. I am also glad to hear Mike is still trying to find a resolve to this problem as well. Unfortuanetly when my loss happened we were never able to pin point the problem so my confidence for Hitec went right out the door. Like many others I never thought to throughly test my servos before flying with them because this is not known as something we all should do like breaking in an engine on the bench. If I had did this maybe my outcome would be different and so might my views on Hitec servos. Yes they all fail, it just sucks my failure was the first time I choose to use Hitec.
I too was using a Futaba radio, T6XAS, with a Hitec Supreme rx and 5625 servos. I just wonder if the Futaba radio has anything to do with it because a couple others have had similar problems also using a Futaba radio...
David Smith
       Post #: 7
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/24/2003 3:06:31 AM
hilleyja
Status: offline
[QUOTE]I too was using a Futaba radio, T6XAS, with a Hitec Supreme rx and 5625 servos. I just wonder if the Futaba radio has anything to do with it because a couple others have had similar problems also using a Futaba radio... [/QUOTE]
Actually, when the servo went south on me it was when I had it connected to the Hitec RX. I ran that same servo for a little while connected to a Futaba R28DF RX with a Hitec Xtal and it ran fine. Subsequent to the failure and a few days later I re-ran the failed servo through the Hitec programmer's "Program-reset". The servo was fine after that -- will still send it to Hitec for replacement.
Your right about the "break in" -- who would have thought it was necessary. Unlike an engine it really is not necessary but the ability to do so with the Hitec programmer does give you the opportunity to find a bad servo at the time it more than luckly would be bad. Another good side to the Hitec programmer is you can test ANY servo, regardle of manufacture and/or whether it is a digital or analog servo. I will be doing this "break in" with every new servo I purchase.
Jim Hilley
AMA #671825
RCCA# 758
       Post #: 8
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/24/2003 4:57:27 AM
Whymee
Status: offline
The point WreckRman2 is trying to make ( I think) is he was using Hitec digitals with a Hitec RX & a FUTABA TX. (correct?)
EGAD.... I have a 8US & a 9C...... The saga continues... *shiver*
Wreckman2, I remember your post of your unfortunate crash & the warnings you gave to the RC community. If memory serves me correct, yours was one of the first I had seen with a failure of these digitals.
I personally thank you for the "heads up" !
       Post #: 9
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/24/2003 5:38:31 AM
WreckRman2
Status: offline
Ya, I was one of the more known issues because of what I lost and my emotions. I made it known to everyone mostly because I had just sold all my smaller airplanes to afford this 27% one only to lose it on the 5th flight. So after this crash I had nothing too fly so why not stir the pot with my free time instead of flying. I really hope Mike does find what is causing this because it sucks to see anyone lose a plane. Mike is a great guy to deal with, I'd just hate to be in his shoes... Until there is a known cure I can't afford to try Hitec again. I'll spend the extra money and go with the equipment that has treated me so well up until this point.
I will also say that I had servos marked AUG2001 and they worked flawless on the first 4 flights. Between the 4th flight and the next one I had heard of the programming issue so I hooked them up to the programmer and reset them. On the next flight the one failed. So is it something in the programming... that's the only thing I changed from the 4th great flight to the 5th and last flight. Who knows but best of luck to Mike to find a resolve.
David Smith
       Post #: 10
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/24/2003 9:04:34 AM
hilleyja
Status: offline
[QUOTE]...I will also say that I had servos marked AUG2001 and they worked flawless on the first 4 flights. Between the 4th flight and the next one I had heard of the programming issue so I hooked them up to the programmer and reset them. On the next flight the one failed. So is it something in the programming... that's the only thing I changed from the 4th great flight to the 5th and last flight. Who knows but best of luck to Mike to find a resolve. [/QUOTE]
There is something curiously coincidental about this statement. Although my servo did not fail after I reset the program I did reset it after it failed. Mike from Hitec insists the problem with these servos were/are not related to the digital circuitry and/or their firmware programming -- I think your scenario and the following belies that:
As I stated before;
1) I initially used a Futaba R28DF 8-channel RX with a Hitec chnl 35 Xtal for my initial setup (this configuration was only intended to be used to set up the pushrods and pull-pull controls for the tail surfaces). This setup worked fine and I detected no problems with the (2) HS-5625s and (1) HS-5645. Although my use of this setup was not real extensive, I did put those servos through many maximum left and right deflections -- again no problems.
2) When it came time to setup the throttle channel I also replaced the Futaba RX with a Hitec Supreme 3200 8-channel RX.
3) My configuration upon startup of the RX was now (2) HS-5625s, (1) HS-5645, and (1) HS-422. Each servo was installed in a separate RX channel. The (2) HS-5625s were setup in an "AILEVATOR" mode with channels 2 & 8 with no y-connector and no extensions -- servos were direct connected to RX.
4) BTW, my TX for both of these setups was the Futaba 9C.
5) Within 5 seconds of energizing the RX the channel 2 HS-5625 immediately deflected to maximum left, a full 45 degrees from neutral.
6) I disconnected the failed servo from the RX and hooked it up to the Hitec programmer and ran the "progra reset" function. I was awarded with the "success" response. [COLOR=red]During the "program reset" activities the servo was commanded to deflect full left first and then full right. This occurred with no indication of problems[/COLOR].
7) I then activated the "auto self test" and observed that the servo only deflect a couple of degrees around neutral. I could not get the servo to move normally. I redid the "program reset" and it still would not deflect normally.
8) I replaced the Jan 02, version 1.02 servo with an HS-5625 lableled as Mar 02, version 1.03. Setup was normal and no problems with the servo.
9.) Three days later in preparation to box up the failed servo to return to Hitec and again hooked it up to the Hitec programmer and ran the "program reset" function. I subsequently ran the "auto self test" and this time the servo reacted normally.
Conclusion: The servo was in a failed state for a period of time and then was able to be reset. What component degrades and stays degraded for a couple of hours, only to return to normal a few days later? BTW, for those thinking heat is involved here. I reset that servo after a couple of hours since its failure and it still stayed failed -- a couple of hours is more than sufficient time for thermal degredation on an IC to reverse itself.
I know these facts only further confuse the issue, but maybe there is someone out there that can make some sense of it. I am returning the servo to Hitec for replacement -- it failed once and I'm certainly not going to install it in an airplane again.
Jim Hilley
AMA #671825
RCCA# 758
       Post #: 11
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/24/2003 10:38:08 AM
akflyer
Status: offline
Well after telling everyone how great these servos have been for me, I guess I get to eat a little crow. I had an elevator servo go hard over on me while doing a pre-flight check. It was fine in the garage but once out in the cold ~ 2 deg. it would lock up. All other servos were fine. When warmed back up it started working again, however, the programing went back to factory NOT what I had set it at.
Last week a buddy had his left aileron lock out on him in the full down position on a UCANDO. He changed that one and today the right one did the same thing but it SLOWLY crept UP till it locked in the up position. He also has an elevator servo that will revert to factory programming when cold ???????? I am thinking that when cold the board shrinks and soldered joints are touching or something of this nature, because the servos work fine when warm, but ARE BACK TO FACTORY PROGRAMMING.
I hope to get this figured out because I flew them for the last two years without any problems.
       Post #: 12
Another HS-5625 Failure -- This one from Jan 02 Lot - 1/24/2003 11:01:48 AM
WreckRman2
Status: offline
I'll also add that all 4 of the 5625's I had showed "success" after being reset with the programmer.
After my crash I brought the remains home and removed all servos, extensions, etc and laid out the entire scheme on my work bench using the same extensions, battery, etc. Exactly how it was in
