lymant3
VA, USA Status: offline
Hi, As Tony mentioned, I did add a carbon fiber anti-rotation pin to his stabs. However, the Carden supplied "L" brackets are - when properly set-up - are quite up to the task. Bad things can happen when people don't take the time to ensure that their brackets mate flushly to both the fuse side and the pad-mount in the stab. This fit is critical! Any gap results in the bracket being flexed and stressed when the stab is bolted in place. Moreover, once they are fit, mark them as left and right, should you ever remove them completely they need to go back in the same location as there are likely subtle differences between the left and right fit. An added anti-rotation pin can give you a little piece-of-mind, but if you take your time, properly fit your brackets, and employ a sound mechanical set-up with your linkages, you should have no worries. t
_____________________________
Futaba, Desert Aircraft
