Gas Oil Mixture
Tower Hobbies
Logged in as Guest
  Printable Version
RCGF 20cc Gasoline Model Airplane Engine
Seller:  jewillis2
Details:   $214.88   |  1/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Gas Oil Mixture
Page: [1]
Login
Gas Oil Mixture - 10/31/2006 6:48:33 PM
aeroviasx15
Status: offline
I would like to know what is the correct gas and oil mixture for Zenoah G-38 engine, like how many ounces of oil to the gallon of gasoline. I feel mathematically confused with the ratio explanation on the engine manufacturer's instructions and want to know a simpler way of mixing. Thanks
       Post #: 1
RE: Gas Oil Mixture - 10/31/2006 7:08:26 PM
dirtybird
Status: offline
3 fluid oz/gal works for me. Thats about 35:1
(in reply to aeroviasx15)
       Post #: 2
RE: Gas Oil Mixture - 10/31/2006 7:22:31 PM
Brian Smith
Status: offline
You can go to the local motorcycle or Go cart shop and get a plastic beaker that is all measured/marked out in oz to gal so you can very easily find the exact ratio you want.. Cheap too..
40 to 1 Pennzoil outdoor/aircooled 2 cycle oil is a popular product and mixture. That is what I use in my Zenoah G38s..Brian Smith
quote:
ORIGINAL: aeroviasx15
< Message edited by Brian Smith -- 11/1/2006 1:01:28 AM >
_____________________________
Brian P. Smith Bismith2@hotmail.com
AMA 1044 IMAA 21141 W4BPS <><
       Post #: 3
RE: Gas Oil Mixture - 10/31/2006 8:37:27 PM
WLJ
Status: offline
I've been using 4oz. oil/ 1gal. gas forever in Zenoahs. NO PROBLEMS
(in reply to Brian Smith)
       Post #: 4
RE: Gas Oil Mixture - 11/1/2006 12:54:03 AM
Rcpilot
Status: offline
128 ounces in a gallon of gas.
4oz of oil
128/4 = 32
Thats a ratio of 32:1 meaning 32oz of gas per every 1oz of oil
128 ounces of gas and 3.2 ounces of oil yeilds 40:1 ratio
128 ounces of gas and 2.6ounces of oil yeilds 50:1 ratio
Technically, it's not exactly perfect, because TECHNICALLY you should be dealing with only 128ounces of fuel when your done mixing.
So, if you want to get TECHNICAL, you'd dump out 4oz of gas and then add your 4oz of oil back in for an exact 128 ounces of mixed fuel at 32:1 ratio.
I don't know ANYONE who is that anal though. Not with gasoline. Maybe a guy homebrewing glow fuel--but I have yet to meet a guy who will actually dump out 3 or 4 ounces of gas and then add his oil.
I run 40:1 in my engines.
Airplanes have expiration dates. It''s just not printed anywhere on them.
I''m not really an airplane pilot; but I did stay at a Holiday Inn Express last night.
(in reply to WLJ)
       Post #: 5
RE: Gas Oil Mixture - 11/1/2006 1:00:19 AM
dick Hanson
Status: offline
approximately 30.076854732 to 1 -- is a good mix
unless it's gin -then about 100-1
I am watching you
Libby
(in reply to Rcpilot)
       Post #: 6
RE: Gas Oil Mixture - 11/3/2006 9:13:15 PM
brachito
Status: offline
Hey Boys!!! Is there a correct technique to mix oil/gas??? The RATIO part got it nailed. I will be mixing 5 gallons gas on a 32:1 with Lawnboy ashless to break a DA-50R. Do I simply fill the 5 gallon gas container and then add the oil completey plus a nice shaking, or go bit by bit so the recipe will be done.
(in reply to dick Hanson)
       Post #: 7
RE: Gas Oil Mixture - 11/4/2006 12:01:36 AM
Geistware
Status: offline
I put in about 1/2 gallon then pour in the oil and then add the remaining 4.5 gallons.
If you leave a little in the jug it also helps.
Then you don't have to put in the 1/2 gallon just put in the entire 5 gallons.
quote:
ORIGINAL: brachito
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
(in reply to brachito)
       Post #: 8
RE: Gas Oil Mixture - 11/4/2006 12:45:21 AM
Rcpilot
Status: offline
I fill a 2 gallon jug at the gas station.
Dump my oil (3.2oz per gallon) into the jug and then put the pump nozzle in there and squirt the gas in at high speed by squeezing the pump handle all the way. By the time I get about 1.5 gallons in there, the 2 gallon jug is getting full, so I slow down and put that last 1/2 gallon in slow to prevent spilling and overfilling.
Thats how I mix my gas and oil. The sloshing of that gas going into the jug at full speed from the pump nozzle is going to mix my oil for me. I usually turn it upside down when I'm done and give it a couple shakes just to be sure.
Then I pour 1 gallon at a time into my field jug. Easier to transport and lighter. Leave the 2 gallon jug at home and pump fuel out of my little 1 gallon jug at the field with my hand crank. Seams like a gallon lasts me about 9 or 10 flights--about 3 trips to the field.
< Message edited by Rcpilet -- 11/4/2006 5:18:14 PM >
(in reply to Geistware)
       Post #: 9
RE: Gas Oil Mixture - 11/4/2006 2:18:54 AM
brachito
Status: offline
Thank GEISTWARE, RCPILET!!!! Sounds very easy, I appreciate the info, I will sure use the technique. This is my 1st gasser, so Ill keep u posted.(Extra 260 27% H9)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.797RCU3
