RE: Jetlegend T-45 Hawk    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Jetlegend T-45 Hawk
Page: <<   < prev  46 47 48 49 50 51 [52] 53 54 55   next >   >>
Login
RE: Jetlegend T-45 Hawk - 10/11/2011 11:32 PM
Kraftei
Score: 100
Last Login: 5/25/2013
Status: offline
Thank you guys.
This tallies with all infos I've read so far. I can really not imagine that he needs downtrim with flaps. I hope I'll be able to see his T-45 fly the next days...
On my sweety I'll have to change the engine mounting completely since I received my new BF-100 at the Jetpower fair.
I'll have to shorten the thrust pipe a bit and move some weight into the nose because however it's smaller and lighter than a P80 it's a bit more than my previous little Lambert.
The good news is that I'll have 120N / 26.5 lbs of thrust then - this should be enough , even on our 400ft grass strip
Of course for flying it's way too much but to have an extra punch for take off or in critical situations is never a bad choice.
It's a pefectly machined engine with amazing data: 120N @ only 125.000 rpm, weight is 2.65 lbs / 42oz / 1,21 kg; diameter : 3.9 inch.
Using of diesel fuel (any diesel, not only premium diesel like Shell vpower or sth. like that) as well as common 2 stroke engine oil is officially permitted by the manufacturer. It comes with kerostart and everything... Can't wait to let it run
Unfortunately winter is coming and finishing the heating system of my home to burn some oil actually has priority than burning kero
Holgi
Hide Signatures
(in reply to kordi)
       Post #: 1276
RE: Jetlegend T-45 Hawk - 10/15/2011 5:02 PM
Xairflyer
Score: 105
Last Login: 6/19/2013
Status: offline
Most aeroplanes need down trim with flaps but all Hawks need up trim
_____________________________
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to Kraftei)
       Post #: 1277
RE: Jetlegend T-45 Hawk - 10/15/2011 5:18 PM
fireblade5437
Score: 105
Status: offline
Apart from the CARF Hawk! none needed at all
Alan
Hide Signatures
(in reply to Xairflyer)
       Post #: 1278
RE: Jetlegend T-45 Hawk - 11/19/2011 10:35 AM
paulaus
Score: 100
Last Login: 9/25/2012
Status: offline
Just thought I'd let you know, maidened my t-45 today with a p-100 powering.
Absolute delight to fly and didn't need anymore than 1/2 throttle for above average cruise speed.. Had two flights, both 6 minute flights, both came down with 1ltr plus of fuel left, even with the extra weight it still slipped into the landing slope like it was on rails.. Will wait til the feild is a little less busy and put it through its paces.
Hide Signatures
(in reply to fireblade5437)
       Post #: 1279
RE: Jetlegend T-45 Hawk - 11/19/2011 2:18 PM
Jesus Cordoba
Score: 100
Last Login: 6/18/2013
Status: offline
Hello from Barcelona.
i have 2 question:
i glued the small pieces in front of elevators follow the lines on the fuse (parallels to airbrakes) but i see that the pieces aren´t  on line with the
elevator (0º , i think that the pieces are with a little of positive angle. (is this normal on the T-45 or i will to change the angle?
here an image.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1280
RE: Jetlegend T-45 Hawk - 11/21/2011 4:22 AM
paulaus
Score: 100
Status: offline
pictures added
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to paulaus)
       Post #: 1281
RE: Jetlegend T-45 Hawk - 4/6/2012 4:23 AM
meps
Score: 105
Status: offline
Finally got back on my T-45. Just wondering if you all have what I consider excessive play in the nose gear? Mine has a great deal of play between the part of the strut that goes into the sleeve that is in the trunion. It seems that this play will cause a very unstable airplane when accelerating for take-off.
Steve
Hide Signatures
       Post #: 1282
RE: Jetlegend T-45 Hawk - 4/6/2012 7:23 AM
paulsf86
Score: 105
Last Login: 6/17/2013
Status: offline
meps:
Nose gear does tend to be a bit sloppy but is not an issue. Have 130 take offs and no issue with movement in nose gear system.
Paul S
Hide Signatures
(in reply to meps)
       Post #: 1283
RE: Jetlegend T-45 Hawk - 4/6/2012 1:48 PM
meps
Score: 105
Status: offline
Thanks Paul, I really appreciate your response.
Steve
Hide Signatures
(in reply to paulsf86)
       Post #: 1284
RE: Jetlegend T-45 Hawk - 4/6/2012 10:08 PM
paulsf86
Score: 105
Status: offline
Steve:
No problem, let me know if you have any other questions.
Paul S
Hide Signatures
(in reply to meps)
       Post #: 1285
RE: Jetlegend T-45 Hawk - 4/6/2012 11:02 PM
Jesus Cordoba
Score: 100
Status: offline
my first experience with the t-45....
Hide Signatures
       Post #: 1286
RE: Jetlegend T-45 Hawk - 4/6/2012 11:28 PM
jetnuno
Score: 105
Status: offline
Hola Jesus,
I am sorry for this crash. Do you know waht happened? Did you put gear and flaps down?
Sorry
Regards
Nuno
Hide Signatures
(in reply to Jesus Cordoba)
       Post #: 1287
RE: Jetlegend T-45 Hawk - 4/7/2012 1:46 AM
FILE IFR
Score: 120
Last Login: 3/31/2013
Status: offline
Sorry to see that Jesus.
It's hard to tell from the video because the camer didn't zoom in at all..... Many turns appeared to be tight and abrupt (in my opinion), my guess is it stalled from too tight of a turn.
Again Jesus, I'm sorry you lost the jet.
Mike * Intercepting The Localizer* AMA# 365566
Bud Nosen C-310 Club #32 * J.P.O. Member 2302
Hide Signatures
(in reply to jetnuno)
       Post #: 1288
RE: Jetlegend T-45 Hawk - 4/7/2012 3:33 PM
Jesus Cordoba
Score: 100
Status: offline
 this jet flyes very well. for the first fly i don´t put expo (watch  the firsts turns!!!!!), but after some turns the plane was on my hands...
the turbine installed was the first VT-80 in Spain, perfect for that plane.
i don´t know what´s  the error. the last turn (it´s not very closed), i don´t think whats the problem.
Another think are that, my secuencer door was programed :
     doors down, after 4 seconds gears down.
may be gears down when the jet are turn, then the plane go to stall ???
the vt-80 and all the electronic are ok, only the fuse sucks...
i´ll be back whit another in the future.
thanks.
Hide Signatures
(in reply to FILE IFR )
       Post #: 1289
RE: Jetlegend T-45 Hawk - 4/7/2012 9:35 PM
RCISFUN
Score: 105
Status: offline
Can't post this warning enough, DO NOT SLOW DOWN the JL T-45 down in turns, it will snap and fall out of the sky every time
From what I can see in the Video it was way too slow at your turn.
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
       Post #: 1290
RE: Jetlegend T-45 Hawk - 4/8/2012 5:50 AM
paulaus
Score: 100
Status: offline
I didnt end up posting the flight video taken by a friend of the T-45..
shortly after this, it went in due to my own error (too slow on approach) and I'm just getting the rebuild finished at the moment!
Hide Signatures
(in reply to RCISFUN)
       Post #: 1291
RE: Jetlegend T-45 Hawk - 4/8/2012 5:53 AM
paulaus
Score: 100
Status: offline
after the crash...
after the repair...
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1292
RE: Jetlegend T-45 Hawk - 4/8/2012 5:16 PM
Craig B.
Score: 100
Status: offline
Noice mate! Get that sucker ready for some serious formation flying at the jet rally! I'll be sure to bring mine out too!
CB
Hide Signatures
       Post #: 1293
RE: Jetlegend T-45 Hawk - 4/10/2012 1:46 AM
mmontella
Score: 100
Last Login: 6/13/2013
Status: offline
Did anyone do anything with the springs on the main gear? I am a little concerned that they are way too soft. I will be flying off of grass and the first stage spring is almost non-existant.
Mark
Hide Signatures
(in reply to Craig B.)
       Post #: 1294
RE: Jetlegend T-45 Hawk - 4/10/2012 2:07 AM
paulsf86
Score: 105
Status: offline
Mark:
You could replace spring with longer stiffer spring. I streched the inner large spring to give more spring effect when all of the weight is on the gear.
Paul S
Hide Signatures
(in reply to mmontella)
       Post #: 1295
RE: Jetlegend T-45 Hawk - 4/10/2012 8:55 PM
olecr
Score: 100
Status: offline
quote:
ORIGINAL: mmontella
Mark
Yes it’s definitely too soft. I also flies on grass and the plane was crazy to handle in takeoff.
The way I stiffened the springs was that I took a shims on both sides of the spring and put an ordinary fuel tube inside the spring. That make the spring much stiffer.
Ole Rønning
Trondheim - Norway
Hide Signatures
       Post #: 1296
RE: Jetlegend T-45 Hawk - 4/16/2012 5:17 PM
Kraftei
Score: 100
Status: offline
Hi Jesus,
unfortunately I know exactly how you feel, because looking at the last seconds of your video, I felt watching a replay of my maiden flight but with one difference: you had a couple of minutes fun with her while mine died after 10 seconds on her maiden flight, already on the first turn - destroyed in seconds
What happend :
after a very smooth take off I throttled down to about 70% of the 120N engine (the BF 100 really gave her a punch - Wow what an engine!).
My measurement to correct the thrust axis and to move the tank into the CG absolutely succeded in very impressive way!
The climbing was really flat and smooth and she felt really well behaving at the stick.
At a height of about 150 ft I brought her in a very slight big left turn with very little left aileron and little elevator.
Not wanting to risk an elevator stall if it would have been necessary to pull a bit more for a closer turn, I decided to maintain the left turn with left rudder while I wanted to "support" the left wing by giving very carefully a little right aileron. But as soon as I did this (once again: i did this very carefully and with very little travel!), still beeing in a big left turn, she immitiadely snapped (!) to the right into a spiral spin untill the impact - It happend in a second so I had no chance to recover her :-(
Neither I nor the other pilots around couldn't believe what we saw. We all agreed that this was a typical tip-stall but none had an idea why it happend!
Speed was absolutely OK and CG was about 140mm totally empty (tank was exactly IN the CG, with filled hopper CG was apprx. 138mm)
With the flaps full down (which have not been activated on take off) I also mixed 2mm aileron up. The installation was very neat (so obviously no technical problems) so what did I wrong ???
Obviously either she's a real beast or I wasn't skilled enough for her (or probably both)
Anyway, very sad! She was a real beauty!
kind regards
Holger
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to olecr)
       Post #: 1297
RE: Jetlegend T-45 Hawk - 4/17/2012 3:37 AM
causeitflies
Score: 120
Status: offline
Holger,
Was a beautiful plane, sorry for the loss.
I think the cross controlling is what did you in. It needs to fly through the turns, not skid.
Mark P
An Expert has made every mistake - A Master has made every mistake twice
Hide Signatures
       Post #: 1298
RE: Jetlegend T-45 Hawk - 4/17/2012 6:04 AM
Ron101
Score: 116
Status: offline
I have one of these in E power... mine seems to fly well. I only have 3 flights due to power system problems.
My old setup was 23.5 pounds, had tons of power on 14s ...... but I had two ESC issues and a fire
I swapped out to a much lighter 12s setup and I'm now 21.5 pounds loaded and ready to fly... I moved the CG to 135mm and reduced the flaps to I think about 15 mm
I had a huge amount a flap at first (all I could get) and it did some strange things, I think it was blanking out the elevator
so I'm really excited to get it back out with the new setup, I know when this plane is dialed it flies really sweet... I watch Pablo flies his for many flight at California jets a few years ago and knew I had to have one. I went with full gear doors and a cockpit. I think it I ever do a new one I'll strip it down to bare bones like Pablo
his is 20 pounds loaded and flies killer..... so maybe it's just a wing loading issue
look how well his flies
"It''''s not personal, Sonny. It''''s strictly business."
Hide Signatures
(in reply to causeitflies)
       Post #: 1299
RE: Jetlegend T-45 Hawk - 4/17/2012 11:11 AM
EDFCrazy
Score: 100
Status: offline
quote:
ORIGINAL: Kraftei
Holger
I noticed in this picture Holger that your nose strut seems to be bent back very far. i wonder what had happened and if this had pushed up against any batteries that might have been in the nose area.
I see you moved your tank closer to your cg, now with other people that have not done this, i wonder if you were then tail heavy with your tanks full? Reason i say this is because people measure there cg before they fill there tanks but then add fuel before they fly, with other people tanks more forward then yours, that would make there planes slightly more nose heavy and with your tanks not forward of the cg your did have this extra nose weight.
Click for fullsize
Hide Signatures
       Post #: 1300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.765RCU1
