RE: Jetlegend T-45 Hawk
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Jetlegend T-45 Hawk
Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: Jetlegend T-45 Hawk - 11/7/2007 3:31:32 PM
339tricolore
Status: offline
HI, very nice videos, please do you have the mix flap whith elevator? thanks...
(in reply to A-GO)
       Post #: 376
RE: Jetlegend T-45 Hawk - 11/7/2007 5:25:05 PM
A-GO
Status: offline
sorry my poor english
yes .Taiwan now is midnight.
but Weight become to wet ????why ???why???maybe I want.......
The flow straightener .I put thin ALU sheet (0.20 mm) and CA glue. high 1cm and wide. then folio to 0.5 cm.
elevator mix about 0.8cm up when flap full down.(I love this seting)
about 1/3 throttle the bird can smooth down the altitude.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by A-GO -- 11/7/2007 5:37:01 PM >
(in reply to 339tricolore)
       Post #: 377
RE: Jetlegend T-45 Hawk - 11/7/2007 7:01:53 PM
meps
Status: offline
Thanks for the info. I really appreciate it. You have your model detailed just the way I had planned on detailing mine.
Steve
(in reply to A-GO)
       Post #: 378
RE: Jetlegend T-45 Hawk - 11/8/2007 1:40:06 AM
CPS
Status: offline
I have seen this plane fly for several times and it is really amazing!It is very aerobatic and can land very slowly under Mr. A-Go suitable setting.
(in reply to A-GO)
       Post #: 379
RE: Jetlegend T-45 Hawk - 11/8/2007 3:00:25 AM
Wayne22
Status: offline
nice video...that "music" though, was a bit hard to take...........
_____________________________
All I ask is for a chance to prove that money can't make me happy......
(in reply to CPS)
       Post #: 380
RE: Jetlegend T-45 Hawk - 11/17/2007 4:03:01 PM
RCISFUN
Status: online
I wanted to pass on some paint information to anyone who may need to repaint the white on the JL T-45, I went to my local Auto paint supplier and had them run a computerized color match on the white, they came up with a 1990 Mazda (Code UC) the name of the color is "Crystal White".
When I paint the nose of my T-45 I will post some photos.
Rich
Rich
Jet Central Falcon Owner
(in reply to RCISFUN)
       Post #: 381
RE: Jetlegend T-45 Hawk - 1/14/2008 9:16:15 PM
meps
Status: offline
Just wondering if anyone have ordered wing fairings for their wings. I ordered a set but I only received enough to cover the aileron and flap control horns. I thought I would get enough to cover the flap hinges.
       Post #: 382
RE: Jetlegend T-45 Hawk - 1/14/2008 11:04:12 PM
RCISFUN
Status: online
Thats all you get from JL
Rich
(in reply to meps)
       Post #: 383
RE: Jetlegend T-45 Hawk - 1/15/2008 2:38:42 PM
meps
Status: offline
That sucks!!!! I'll just have to make my own.
Thanks, Steve
       Post #: 384
RE: Jetlegend T-45 Hawk - 1/15/2008 10:19:52 PM
RCISFUN
Status: online
Hey if you going to make some, myself and my two buddies could use some
Rich
(in reply to meps)
       Post #: 385
RE: Jetlegend T-45 Hawk - 2/18/2008 9:19:03 AM
KW Mitchell
Status: offline
Just had two flights with my new T45 (21lb, JC Falcon power). Very, very fast - too much power really for normal flying but the Falcon has plenty of poke to get it off a soggy grass strip, midwinter at my club site, Longhorsley in NE England.
Falcon installation is shown in pic' and is very neat by removal of ~ 3/4" of duct, then insertion of my own fabricated FOD and the front housing mates up beautifully.
A couple of criticisms on an otherwise lovely kit; the main leg springs are not really man enough and will be replaced. Also, the brakes don't work unless there's ~ 100lb in the air system. Any comments?
Click for fullsize
Click for fullsize
       Post #: 386
RE: Jetlegend T-45 Hawk - 2/18/2008 11:02:06 AM
mikedenilin
Status: offline
Nice setup. I wish I had kept my Falcon. I am almost done with my T-45.
What's your C.G. location?
By the way, do you have the problems of the main gear doors hitting the wheels when the plane is on the ground? I have to remove a section of the gear doors to clear rooms for the wheels. I then glued the section of the doors on the wings so when the gear's up, the doors sit flush with the wings.
I modified the wing tips to make it more scale and also added the vortex generators.
Here are some photos of the planes before I applied any decals. It's polished, air bubble filled, and repainted to get rid of the ugly seam lines and air bubbles. will put a semi-glossy coat after the decals are applied.
Mike
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to KW Mitchell)
       Post #: 387
RE: Jetlegend T-45 Hawk - 2/18/2008 1:36:35 PM
KW Mitchell
Status: offline
Mike - thankyou for your kind comments:-
CG is at ~120-125mm.
The inner gear doors are presently not attached. The doors on the legs tend to dig-in at the pointed lower front - exacerbated by the spring problem. I've just removed that corner this morning - very non-scale I admit but I want the model to be flyable from my local patch and not just a 'Runway Queen'!
You seem to be going the 'whole hog' with the finishing - should look very nice when it's finished. One last point, I found the recommendation of 15mm for ailerons way too sensitive. Reduced it to 12mm with 50% exp.. AFT is 30mm with 30% expo -just right.
All the best with your test-flights,
Keith
(in reply to mikedenilin)
       Post #: 388
RE: Jetlegend T-45 Hawk - 2/19/2008 6:04:33 PM
meps
Status: offline
What did you use for your vortex generators? I'm doing the same for my wing. I was planning on using the method that A-GO used on his in previous post. I'm also trying to come up with a solution to the main wheels banging the gear door.
Steve
       Post #: 389
RE: Jetlegend T-45 Hawk - 2/19/2008 11:33:17 PM
RCISFUN
Status: online
KW,
Your T-45 looks great, you have the same set-up as mine, i.e. Falcon for the push.
Did you find that you needed to cut you mounting rails for the Falcon to be centered in the inlet?
I made a short set of rails that bolted up to the bottom of the main rails, that put the engine directly in center with the inlet duct, I used a FOD screen like you described.
Did you add any extra fuel tanks?
What kind of flight time are you getting?
I added a Dubro 16 oz tank that is fed from the 78 oz main tank, the 16 oz feeds the UAT that gives me 94 oz + UAT.
I also made a equipment tray graphics, I think it adds a bit of extra class.
Congratulations on your flights
Rich
Click for fullsize
