RE: Jetlegend T-45 Hawk
Tower Hobbies
Logged in as Guest
  Printable Version
Fei Bao F-4 Phantom - ARF
Seller:  rcjetmodels
Details:   $2,490.00   |  6/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Jetlegend T-45 Hawk
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Jetlegend T-45 Hawk - 11/27/2006 9:00:59 AM
JLSE
Status: offline
Congratulations Eric, I have ordered another one.
(in reply to Pantherman)
       Post #: 76
RE: Jetlegend T-45 Hawk - 11/27/2006 9:41:13 AM
The Bush
Status: offline
Sounds great, all some of us need now is some wings !!!!!!!!
< Message edited by The Bush -- 11/27/2006 3:23:25 PM >
(in reply to JLSE)
       Post #: 77
RE: Jetlegend T-45 Hawk - 11/27/2006 1:39:47 PM
EASYTIGER
Status: offline
Well done! I knew the plane was a winner all along!
You know, that first flight shot, with the tailhook and the gear up and all, the plane looks hot, really nice, much better looking than a regular Hawk.
Thinking about doing gear doors?
       Post #: 78
RE: Jetlegend T-45 Hawk - 11/27/2006 5:36:47 PM
mikedenilin
Status: online
Hi All,
Eric, do you think An Artes Falcon is too much (22lbs) for this bird?
I just received a new T45 with the new wing, but I have been traveling and no time to build it during this winter. Anyone in the USA would like to buy it from me? I will sell it at the factory price but no shipping within USA. I am going to focus on flying JLF15 when I get back to the States.
Give me a PM if you are interested in this proposal.
Mike
(in reply to EASYTIGER)
       Post #: 79
RE: Jetlegend T-45 Hawk - 11/27/2006 6:21:20 PM
jeff sewell
Status: offline
They're coming...I'm told!
Jeff
_____________________________
Exclusive UK JetLegend Dealer
Digitech Turbines UK
(in reply to The Bush)
       Post #: 80
RE: Jetlegend T-45 Hawk - 11/27/2006 6:58:11 PM
Eric Banner
Status: offline
Hi Mike,
It's very difficult comparing like-for-like and I'm bound to get into trouble for this, but:-
Thrust Weight All in lbs
Jet Central Super Bee 14 1.9 http://www.jetcentral.com.mx/docs/bee.pdf
Wren Super Sport 18 2.2 http://www.wrenturbines.co.uk/product.php?pid=4
MW54 Mk3 14.5 2.2 http://www.wrenturbines.co.uk/product.php?pid=2
Jetcat P70 17.5 2.6 http://alshobbies.bpweb.net/jetcat.html
Jetcat P80 20 2.9 http://alshobbies.bpweb.net/jetcat.html
Jet Central Falcon 22 3.3 http://www.jetcentral.com.mx/docs/falcon.pdf
The difference between top and bottom of this list is 8lb thrust for an increase in weight of 1.4lbs.
You've got to go your own way...
Eric
(in reply to mikedenilin)
       Post #: 81
RE: Jetlegend T-45 Hawk - 11/27/2006 7:04:44 PM
Eric Banner
Status: offline
quote:
ORIGINAL: EASYTIGER
Hi Curtis,
Yes and air brakes but not just yet. Want to get a few hours flying in!
Eric
       Post #: 82
RE: Jetlegend T-45 Hawk - 11/27/2006 7:24:06 PM
EASYTIGER
Status: offline
The gear doors are nicely done. It's not that I mind the holes in the bottom of the fuse, it's that the gear legs look so naked and stalky without them when they are out. I may just put the doors on the legs for now, I know, like you, I don't want to deal with the complete door system until mine is flown a bit. The airbrakes, I don't think I will bother. But I may do a simple microservo on the tailhook slaved to the flaps. For the moment, mine is glued into place.
Where did you put your second air bottle? I found out last night they won't both go under the radio tray without one tank protruding into the fuel tank, so I put the second tank above the intakes.
(in reply to Eric Banner)
       Post #: 83
RE: Jetlegend T-45 Hawk - 11/27/2006 8:13:33 PM
Jascat100
Status: offline
ET. Use two tanks the same height as the shortest one & fit them upright behind the air intake.
Regards
Jim
JET FLYING:- Resistance is futile. You will be assimilated.
       Post #: 84
RE: Jetlegend T-45 Hawk - 11/27/2006 8:44:46 PM
EASYTIGER
Status: offline
One will indeed fit under the radio tray, on the right side. But your internal former layout may be different than mine, the plane was revised a bit recently....
(in reply to Jascat100)
       Post #: 85
RE: Jetlegend T-45 Hawk - 11/27/2006 8:48:19 PM
Eric Banner
Status: offline
quote:
ORIGINAL: EASYTIGER
...Where did you put your second air bottle? I found out last night they won't both go under the radio tray without one tank protruding into the fuel tank, so I put the second tank above the intakes.
I only fitted one tank...
Eric
       Post #: 86
RE: Jetlegend T-45 Hawk - 11/27/2006 8:54:29 PM
EASYTIGER
Status: offline
That was the other solution that occoured to me. One should be plenty for a few gear cycles and still have enough for brakes. The other solution would be a shorter tank for brakes that will still fit under the radio tray.
       Post #: 87
RE: Jetlegend T-45 Hawk - 11/27/2006 9:20:24 PM
Eric Banner
Status: offline
quote:
ORIGINAL: EASYTIGER
From 7bar I get 4 gear cycles then Tam puts my wheels down.
       Post #: 88
RE: Jetlegend T-45 Hawk - 11/27/2006 9:24:53 PM
EASYTIGER
Status: offline
Well...you only need ONE full cycle, plus something left over for taxying out and braking after landing and taxying back, and, yeah, one tank feels like enough.
We don't use bars here, only PSI, which are much more powerful!
       Post #: 89
RE: Jetlegend T-45 Hawk - 11/27/2006 9:26:27 PM
EASYTIGER
Status: offline
If you PM me your adress, I can send you some good old American PSI to fill your air tanks with, and a package of my patented new lightening holes.
       Post #: 90
RE: Jetlegend T-45 Hawk - 11/27/2006 9:47:52 PM
john agnew
Status: offline
ET
Thanks for the kind offer,air is something you have in abundant supply.
John
