RE: Himoto Racing 1/10 Official Support
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> RE: Himoto Racing 1/10 Official Support
Page: <<   < prev  17 18 19 20 21 22 23 [24] 25 26   next >   >>
Login
RE: Himoto Racing 1/10 Official Support - 3/14/2008 3:21:18 AM
kenali
Status: offline
Yes pictures will be excellent if you don't mind .
_____________________________
Motor Saver Filter, Picco.26 max, RPM A-arms, VG Roll Cage, THS Pipe, Acncm Bulkheads, Traxxas Big B Shocks, HS645MGx2 and D
(in reply to KeithjV)
       Post #: 576
RE: Himoto Racing 1/10 Official Support - 3/14/2008 3:21:43 AM
KeithjV
Status: offline
Anytime bio. Let us know how it works out.
(in reply to bio8o)
       Post #: 577
RE: Himoto Racing 1/10 Official Support - 3/14/2008 3:52:15 AM
bio8o
Status: offline
g'day keithjv,
seems to b working well, unfortuantly its 39 celcius outside with a strong northerly cant wait to give it a hard run 2night,
any suggestions on how i could change the accelerate/reverse problem without resorting to changing the reverse switch?
Cheers
       Post #: 578
RE: Himoto Racing 1/10 Official Support - 3/14/2008 3:53:36 AM
KeithjV
Status: offline
bio thats pretty much the only way to do it. Thats what the switch is for. It wont damage anything.
(in reply to bio8o)
       Post #: 579
RE: Himoto Racing 1/10 Official Support - 3/14/2008 3:55:59 AM
KeithjV
Status: offline
quote:
ORIGINAL: kenali
kenali, unscrew the cap where the red arrow is. Drain out the oil thats in the shock. Then replace it with the heavier oil. As you add the oil slowly move the piston up and down to get all the air bubbles out. Be careful not to over fill the shock or you'll have trouble closing it.
Click to see fullsize image.
Click for fullsize
(in reply to kenali)
       Post #: 580
RE: Himoto Racing 1/10 Official Support - 3/14/2008 3:58:09 AM
bio8o
Status: offline
thankyou once again
u have eased my concerns
(i realise this is inapropiately takin up space on this forum, but think its important to thank some1 that helps)
Cheers
       Post #: 581
RE: Himoto Racing 1/10 Official Support - 3/14/2008 4:08:51 AM
kenali
Status: offline
Oh I see. Do you know the stock oil is lighter or heavier? Do you think 50wt is good for my Viper or too much?
(in reply to bio8o)
       Post #: 582
RE: Himoto Racing 1/10 Official Support - 3/14/2008 4:15:50 AM
KeithjV
Status: offline
The stock oil is probably lighter. I think 50 would be a good weight. You might want to just check with your LHS to see what they think for your weather conditions up there. It also depends on the way you drive and the terrain you are driving on. Its fairly easy to change the oil if it ends up being too heavy or too light.
       Post #: 583
RE: Himoto Racing 1/10 Official Support - 3/14/2008 4:36:00 AM
kenali
Status: offline
Thank you for your advise, I think I know what I need to do now.
       Post #: 584
RE: Himoto Racing 1/10 Official Support - 3/14/2008 11:05:24 PM
kenali
Status: offline
Where can I find a good air filter for my Viper? Also can the brake adjust?
< Message edited by kenali -- 3/15/2008 1:13:20 AM >
       Post #: 585
RE: Himoto Racing 1/10 Official Support - 3/15/2008 3:50:11 AM
KeithjV
Status: offline
The stock air filter isnt bad. Just be sure to oil to lower filter.
Here is a another option http://cgi.ebay.com/NEW-HPI-NITRO-MT2-Air-Filter-3-0-Engine_W0QQitemZ150224722903QQihZ005QQcategoryZ34061QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The brake can be adjusted by turning the screw on the end of the shaft. You should tighten just enough that the wheels still roll freely without any drag.
       Post #: 586
RE: Himoto Racing 1/10 Official Support - 3/15/2008 4:29:49 AM
kenali
Status: offline
Very sorry, where is the screw and the shaft??
       Post #: 587
RE: Himoto Racing 1/10 Official Support - 3/15/2008 4:34:01 AM
KeithjV
Status: offline
The brake adjustment screw is where the pen tip is. Just turn this screw to tighten it up to the point where the tires start to drag. Then back it off a little so they spin freely
Click for fullsize
< Message edited by KeithjV -- 3/15/2008 4:40:54 AM >
       Post #: 588
RE: Himoto Racing 1/10 Official Support - 3/15/2008 4:39:23 AM
kenali
Status: offline
Yeah..
       Post #: 589
RE: Himoto Racing 1/10 Official Support - 3/15/2008 4:42:34 AM
kenali
Status: offline
What is the little purple thinging in between your tube? What is that for??
       Post #: 590
RE: Himoto Racing 1/10 Official Support - 3/15/2008 4:46:40 AM
KeithjV
Status: offline
Its a fuel filter. Just like on your regular car. Its there to catch anything that might get into the fuel tank before it gets to the carb.
       Post #: 591
RE: Himoto Racing 1/10 Official Support - 3/15/2008 4:49:33 AM
