IRC vulcan SE problems
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> IRC Racing Support >> IRC vulcan SE problems
Page: [1] 2   next >   >>
Login
IRC vulcan SE problems - 11/3/2006 6:15:16 PM
rc51racer0023
Status: offline
I have a IRC Vulcan Se and let me just say this little nitro buggy is a piece of crap. I ran about 4 tanks of gas through it before the steering servo stripped out. this happened just runnung it on the street to break it in. The little motor leaks nitro like a pig in heat from the front bearing area. Nitro fuel is way to expensive to just have run out of the motor and besides what a mess it makes. The rear differential out drivers were wobbly and seemed to be falling out of the rear differential right out of the box from the manufacture, this cause the rear wheels to shimmy up and down. Its like the cheep plastic out drives are warped. I have not had time to tear into the rear differentail to see what the heck is going on yet. Are any of these problems and defects covered under warranty from IRC, and is anybody else have any of these same issues?
       Post #: 1
RE: IRC vulcan SE problems - 11/6/2006 7:22:23 PM
Mindcrime
Status: offline
A sure fire way to not get help is to start your post with "this thing is a piece of crap", the engine leaking is normal, you can put a washer behind the collet to help with it. most of the leaking is actaully oil, not un burnt fuel, if you are getting unburt fuel then chances are you have the engine way too rich. (this is also the same engine that is in the Xray, and Caos)
The outdrives, I can't really tell you what is going on, that is not a problem I have heard of before, but the way the outdrives mount I can't see how they would be "falling off", they also have a metal band molded into them so they are strong, they are not "cheap plastic"
I would suggest taking it to the dealer you bought it from and have them contact us.
_____________________________
IRC Racing
(in reply to rc51racer0023)
       Post #: 2
RE: IRC vulcan SE problems - 11/8/2006 5:40:40 PM
rc51racer0023
Status: offline
Mindcrime.
It seems like i am not the only on disapointed in the IRC Vulcan Se. From reading the posts on hear it seems like there are alot of disapointed people having the sam problems over and over again. Is the steering servo covered under any type of warranty? It seems like the servo is very week and the gears strip easly. Maybe the entire vehicle is not a piece of crap but certainly there are certain aspects of the vehicle that are. this is my opinion of the vehicle and if you don't like it too bad.
(in reply to Mindcrime)
       Post #: 3
RE: IRC vulcan SE problems - 11/8/2006 5:55:42 PM
pre98zetec
Status: offline
If my vulcan isn't a peice of crap I don't know what is. I've had more run time out of my 2.5 Rustler in 1 day then I have with my IRC vulcan in the 2 months I've owned it.. The truck itself looks pretty well engineerd, the motor, is JUNK.
Nitro Rustler 2.5, HPI Nitro RS4 w/Peak Diablo .12, Losi mini-T with a few hop-ups, Stock Mini-t, Micro RS4 hopped up
       Post #: 4
RE: IRC vulcan SE problems - 11/8/2006 6:44:14 PM
Mindcrime
Status: offline
I'm sorry you guys are having issues and do not like the product....the standard servo is not generaly covered under warranty, however there may be something else causing the servo problem as with most RTR's I would suggest upgrading to a better servo if you continue to have problems with the stock one..
Like I said before, take it to the dealer you bought it from and have tham contact us, if there is a problem we will get it sorted out with together.
pre98zetec: glad you like the Rustler
IRC Racing
(in reply to pre98zetec)
       Post #: 5
RE: IRC vulcan SE problems - 11/8/2006 6:51:58 PM
Mr. Mugen
Status: offline
quote:
ORIGINAL: Mindcrime
If this is not a good reason to stay away from their products what is? If a guy says it is a piece of crap.......he's being honest. Isn't that what people want? Honesty? You guys need to do some customer relation homework. I have not met or heard of a single person that is happy with their vulcan in either form. Maybe you's should pull it and make the nessessary changes. Then again I don't know if that would help at all due to the first attempt being so ugly. Good Luck
Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
       Post #: 6
RE: IRC vulcan SE problems - 11/8/2006 10:13:06 PM
pre98zetec
Status: offline
quote:
ORIGINAL: Mindcrime
Don't get me wrong, You guys engineered a great truck. Your motor choice was deffinetly not the best. Someday I plan on doing a .12 conversion to it just so I can get some use out of it.
And I can't really return it, I traded stuff with a guy (it was brand new when i got it). Otherwise I'd have it looked at.
       Post #: 7
RE: IRC vulcan SE problems - 11/8/2006 10:40:54 PM
new-guy
Status: offline
I will come out and say that I like my Vulcan. I can't say it has been anywhere near perfect.
It was my first RTR and will probably be my last RTR.
In general it has a lot of good design features. However like most people I have found several shortcomings.
1) needle settings and idle stop are not set properly from factory.
It took me forever to finally find good needle settings and the proper idle gap
2) I could not get the Vulcan to go very fast.
Turns out the flywheel was loose. Remove flywheel, scrape excessive threadlock and retighten everything
3) I think my piston sleeve was not lined up right in the crankcase.
4) If you dont like the motor, upgrade it to the pico
5) Kyosho mini-inferno parts will fit on the Vulcan.. Upgrade with those. Find them on Ebay
6) Although it is an RTR, I dont think it is fit for a beginner. Had it been my first model I would have given up long ago. There is fun to be had with the Vulcan but unfortunately you need to know your stuff and have some wrenching experience.
I have been reading the posts here and I feel that there is not very good support for the product. For me this is a shame because there are problems, but they are fixable.
Mindcrime and RC-BOSS, I hope you can look into some of the issues I experienced and share the solutions with your customers and your assembly people. Maybe this way the product can be improved and customers can be happy with this product.
       Post #: 8
RE: IRC vulcan SE problems - 11/9/2006 12:09:09 AM
Mindcrime
Status: offline
New-Guy,
Thanks for the post, I agree maybe this is not the best car for a first time user...as for the support we are always avaiable by email and phone, we try to keep up with the RCU and some of the other message boards, but there is only so many hours in a day..we do try our best.
pre98zetec,
keep in mind that we had the first 1/16th nitro car on the market, at that time there was NO choices in engines, that is the reason you see the same engine in the Xray and Sportwerks car...
Mr. Mugen,
I bent over backwards to help you with your issues. I'm sorry that we could not make you happy.
rc51racer0023,
I'm sorry if my reply to your post seemed rude, I did not mean for it to sound that way. but in the future ask for some help before opening with "this thing is a piece of crap" lol
We have been improving the product since the day it was released and will continue to do so. we have sold over 5000 of the Vulcan and Vulcan SE's worldwide, and most people are very happy with them, it seems that you generaly only hear about the un-happy ones on these forums.
IRC Racing
(in reply to new-guy)
       Post #: 9
RE: IRC vulcan SE problems - 11/9/2006 4:58:43 AM
rc51racer0023
Status: offline
Mindcrime.
well maybe i was a little out of line saying the vulcan was a piece of crap. The big issues that i have had with it have been the servos and the leaking fuel from the engine. I placed an order today for 2 new hitec hs-65mg servos this should cure those problems. I ordered them from Tom at pythonmotorsports he is a very knowledgable dealer and is always willing to help. I checked out the out drives and it looks like the wobbley one has some sort of defect and is not flat on the side it mounts to the differential. I also ordered some cvds and a two speed tranny. I am an experienced nitro hobbiest and am willing to work the bugs out on this thing to make it bullet proof.
       Post #: 10
RE: IRC vulcan SE problems - 11/9/2006 2:33:18 PM
new-guy
Status: offline
rc51racer0023,
Check out the december issue of RC Car Action magazine. They have a review of the Vulcan and the writer had some tips on how to tweak your steering. Since you are getting new servos, this would be a good time to tune the sterring.
       Post #: 11
RE: IRC vulcan SE problems - 11/9/2006 3:19:09 PM
rc51racer0023
Status: offline
thanks for the advice i will check the article out.
       Post #: 12
RE: IRC vulcan SE problems - 12/13/2006 2:07:33 AM
Dannn
Status: offline
so, do we have a fix for the stripping diffs yet or what?
       Post #: 13
RE: IRC vulcan SE problems - 12/13/2006 4:14:29 AM
Mindcrime
Status: offline
If you are still having problems you can go to the metal diff gears.
IRC Racing
(in reply to Dannn)
       Post #: 14
