My home built giant scale    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> My home built giant scale Page: [1] 2   next >   >>
Tower Hobbies Today's Special Offer! Brands Products
Login
My home built giant scale - 11/5/2006 4:07 PM
rcollector
Score: 100
Last Login: 11/30/2011
Status: offline
I have never posted anything here in the giant scale car section before but have read a lot an was inspired by other people's creations. Here is something I built. I know it is A bit crude but it seems to work quite well so far. It uses a water cooled 40 cc pocket bike engine for power. The biggest problem I had was radio glitching problems but a spektrum radio solved that problem.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: My home built giant scale - 11/5/2006 4:22 PM
JQuest64
Score: 100
Last Login: 2/7/2012
Status: online
Man, that looks really nice. Great work.
Hide Signatures
(in reply to rcollector)
       Post #: 2
RE: My home built giant scale - 11/5/2006 5:06 PM
SELWA
Score: 100
Last Login: 3/20/2011
Status: offline
Very nice indeed! Put the kids inside when they've mis-behaved and take them for a ride! With helmets of course!
< Message edited by SELWA -- 11/5/2006 6:16 PM >
_____________________________
ELCON CLEON with air brakes
FG 4WD w/30.5 ESP Race ported
Hide Signatures
(in reply to JQuest64)
       Post #: 3
RE: My home built giant scale - 11/5/2006 5:31 PM
DaBoo75
Score: 100
Last Login: 5/17/2007
Status: offline
Looks real nice did you make the chassis your self
Hide Signatures
(in reply to SELWA)
       Post #: 4
RE: My home built giant scale - 11/5/2006 5:59 PM
Acs_guitars
Score: 100
Last Login: 1/17/2012
Status: offline
Very nice..... Similar to my custom 1/4 scale buggy a few years back. I found it hard to find a large enough area to run. I still have it, but it is stripped of the motor and radio, waiting for me to someday bring it back to life.
AMA # 880471
Hide Signatures
       Post #: 5
RE: My home built giant scale - 11/5/2006 6:04 PM
BuggZy99
Score: 100
Last Login: 6/7/2008
Status: offline
looks fricken cool, but pretty big to haul around though.
the reason why a divorce is so expencive is because its well worth every penny your gonna spend on it
Hide Signatures
(in reply to Acs_guitars)
       Post #: 6
RE: My home built giant scale - 11/5/2006 6:23 PM
Earth Surfer
Score: 100
Last Login: 12/3/2007
Status: offline
It is cool---can I drive in it? Nooo---why not?
Go RC---Because you really can't learn much from throwing a ball around.
Hide Signatures
(in reply to BuggZy99)
       Post #: 7
RE: My home built giant scale - 11/5/2006 7:11 PM
hndaman1
Score: 100
Last Login: 2/3/2012
Status: offline
AWESOME....is that chain driven?or belt?
creator of rock ridge raceway
Hide Signatures
(in reply to Earth Surfer)
       Post #: 8
RE: My home built giant scale - 11/5/2006 7:16 PM
rcollector
Score: 100
Status: offline
Acs_guitars, I believe that it was your buggy that I had seen posted a while back that gave me the Idea. And I do know what you mean about it being hard to find a place large enough to run it. It is a bit large but with the nearly 10 horsepower at about 16000 RPM and the way the powerband hits on this engine the size is needed to keep itself right side up. This thing is not underpowered. To describe how it runs around the yard it is sort of like a KX80 in first or second gear.
< Message edited by rcollector -- 11/5/2006 7:36 PM >
Hide Signatures
       Post #: 9
RE: My home built giant scale - 11/5/2006 7:21 PM
rcollector
Score: 100
Status: offline
It is chain drive. I tried to find the largest #25 sprocket I could for the rear to keep the gear ratio low. The sprocket on the engine is, if I remember right, 5 tooth that came stock on the engine and the rear is 80.
Hide Signatures
       Post #: 10
RE: My home built giant scale - 11/5/2006 9:34 PM
original.mb
Score: 100
Last Login: 12/23/2007
Status: offline
awesome, nice work the tube frame is a top notch design
As long as its LARGE-SCALE who cares what you drive!
Hide Signatures
       Post #: 11
RE: My home built giant scale - 11/5/2006 11:19 PM
Anomie
Score: 188
Last Login: 1/16/2012
Status: offline
Wow, great job! Looks like lots of fun :-)
~Reiko~
It may be that your sole purpose in life is simply to serve as a warning to others.
Hide Signatures
(in reply to original.mb)
       Post #: 12
RE: My home built giant scale - 11/6/2006 12:40 AM
Acs_guitars
Score: 100
Status: offline
I am glad I have inspired you in your design. How about some up-close pics of your steering and brake set-ups? Steering was one of my biggest obstacles in the design.
AMA # 880471
Hide Signatures
       Post #: 13
RE: My home built giant scale - 11/6/2006 3:17 AM
rcollector
Score: 100
Status: offline
The steering is done with two tower hobbies ts-80 servos running on 6 volts. One on each side with a tie rod to each spindle and a rod hooking the two servos together in the middle. Just think of the servo arms being in place of the idler arm and pitman arm of a real car. No servo savers or any other protection. I have banged it around quite a bit and they still work. The plastic servo arms are a bit flexable and I think this gives some protection from breakage. I do have some spares on hand in case of breakage but have not needed them yet. The steering system works pretty well considering the job the servos have to do. I suppose it's stearing action is just a little slower than I would like but it seems just good enough. I am very happy with the results for the price of the servos.
The brake system is just a pocket bike caliper on a disk mounted on the axle. This is also actuated by a TS-80. It seems fine for running around the yard. I would say if I got out in the open and really got moving it may be somewhat lacking in stopping power, but as I said bouncing around in the yard it is fine.
I will get some close up pictures soon.
Hide Signatures
       Post #: 14
RE: My home built giant scale - 11/6/2006 3:24 AM
J_D
Score: 100
Last Login: 5/10/2007
Status: offline
looks awesome, and i love the size
Zenoah Powered FG Marder
Hide Signatures
       Post #: 15
RE: My home built giant scale - 11/6/2006 11:42 PM
garygit
Score: 100
Last Login: 4/20/2010
Status: offline
Where in florida? I really would love to see that thing run. Looks great..
Hide Signatures
(in reply to J_D)
       Post #: 16
RE: My home built giant scale - 11/7/2006 12:08 AM
kengentry5000
Score: 100
Last Login: 11/1/2010
Status: offline
That thing looks ready for the DARPA Grand Challenge!
Firehammer with Zen 26cc and FG 8485 limited slip diff (no more "sit and spin" - just hooks up and goes).
Hide Signatures
(in reply to garygit)
       Post #: 17
RE: My home built giant scale - 11/7/2006 12:12 AM
Oneill Brothers Racing
Score: 100
Last Login: 8/7/2008
Status: offline
Looks good
Sean Oneill webmaster@oneillbrothersracing.com
www.oneillbrothers.com
Hide Signatures
(in reply to kengentry5000)
       Post #: 18
RE: My home built giant scale - 11/7/2006 3:46 AM
Mike@Accurate
Score: 100
Last Login: 9/11/2009
Status: offline
Looks great. The steering is just about like what I built for mine. I guess that means mine may work too (if I ever get finished). I like the size and scooter motor, very cool. Do you have a differential ? If so, what kind? If not, how's it steer? Keep it up, I like it. Enjoy, MIKE
Hide Signatures
(in reply to Oneill Brothers Racing)
       Post #: 19
RE: My home built giant scale - 11/7/2006 6:25 AM
snooptalian
Score: 100
Last Login: 5/30/2009
Status: offline
That thing is huge. Is that a Raco Jackrabbit 1/4 scale sitting next to it looking like a toy? It would be great to see some video of that beast in action...
Hide Signatures
(in reply to Mike@Accurate)
       Post #: 20
RE: My home built giant scale - 11/8/2006 4:24 AM
rcollector
Score: 100
Status: offline
It has a go kart differential because I wanted to be sure it would steer easily in tight spots.
Hide Signatures
(in reply to snooptalian)
       Post #: 21
RE: My home built giant scale - 11/10/2006 3:05 AM
So Cal
Score: 105
Last Login: 6/29/2011
Status: offline
That is soo cool!!! i want one!!!!
Axial AX10, Brushless sc10, Rc18t2, SC18, Nitro X-cell, electric converted X-cell, 2 micto-t''s, Tamiya Frog.
Hide Signatures
       Post #: 22
RE: My home built giant scale - 11/11/2006 5:29 AM
quarterscalelegends
Score: 105
Last Login: 12/25/2011
Status: offline
nice work, looks pretty awesome!!
For the awesome history of 1/4 scale including New Era, Raco and yankee visit www.quarterscalelegends.com
Hide Signatures
(in reply to So Cal)
       Post #: 23
RE: My home built giant scale - 11/11/2006 7:01 PM
broncobill
Score: 100
Last Login: 1/28/2012
Status: offline
Would love to see a video or two of it running.
GIVE ME FUEL GIVE ME FIRE GIVE ME THAT WHICH I DESIRE
Hide Signatures
(in reply to quarterscalelegends)
       Post #: 24
RE: My home built giant scale - 11/14/2006 5:46 AM
So Cal
Score: 105
Status: offline
quote:
ORIGINAL: broncobill
video would be nice...
Hide Signatures
(in reply to broncobill)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
1.969RCU1
