gtsum
VA, USA Status: offline
I am by NO means a battery expert (I am pretty much clueless here), but I charge my 2500 ballistic pack at .5 amp max (usually at .30 or so) to really pack the mah in there..I typically get about 2700-2900 mah in there (into a fully discharged pack). If I need a quick charge, I charge em at .70 amps though...also, I noticed that the volts tend to drop down quickly on the ballistic pack (well, relatively quickly), but they tend to stabilize and hold steady (when using them for many hours). Not sure how low they will go, as I have yet to have it dump on me, but I would imagine it would be after about 5-6 hours of runtime (actual run time, which should be more then enough for about any day of racing at any track
