DarZeelon
Joined: 4/9/2003 From: Rosh-Ha'Ayin, ISRAEL Status: offline
quote:
ORIGINAL: Sport_Pilot ...The tank center line should be below the carburettor, how much depends on the muffler pressure and carburettor suction. Not true, Hugh. The choice of the fuel-tank center-line as the carburettor venturi level, is used because it is supposed you would fly until your fuel tank is nearly empty and also to make the engine behave identically, whether the model is flying upright, or inverted. I had a model that if adjusted perfectly for upright flight, would become so rich when inverted that the engine would begin to four-cycle and would even die rich, if a high negative-G maneuver was added to boot. You guessed it! The fuel-tank center-line was about 1.5" lower than the carburettor spray-bar and with the tank nearly full, the engine would simply be drowned when performing/attempting an outside-loop... The muffler pressure has absolutely no bearing on fuel tank level, since at full throttle it adds a given, small number of psis to the fuel pressure, whether the tank is full, half-full, or empty. The exhaust pressure addition does not change between positive and negative-G flight, since the pressure addition remains the same whether the pressure tube is bubbling in the fuel, or spewing in the free gas over the fuel. The mixture will become leaner as fuel level declines and as the nose is raised, but the tank level is not supposed to compensate for this.
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com MVVS - Jett - Nelson - Bolly - Mejzlik
