fancman
SC, USA Status: offline
I really don't see the purpose of your post. No way are kit MFG's going to look at this and all of a sudden start to redesign all their kits. I've had many ARF's and while the fuel tank location isn't optimal, it really isn't a big deal. My engines run jus t fine when the carbs are needled in correctly. quote:
ORIGINAL: DarZeelon Most glow engine models; at least 98%, I believe, do not use a fuel pump. But all the kits/ARFs I have ever seen mount the engine at the wrong height in relationship to the fuel-tank. I.e. the tank is mounted so the fuel tube(s) exits the firewall in the middle of the engine mount, which for most engines means the tank center-line is at the crankshaft level; about 1.5" below the carburettor. This does not apply to those 'rear intake' racing engines, with their carburettors mounted onto the back-plate drum/disk valve, but one of how many engines are like that? A solution is to mount the engine sideways... Another solution is to mount the engine upright under the engine-bearers, or inverted, over the bearers (according the what the model is designed for). But most engines are wider over the mounting-lugs than they are under them... Could be a problem. ...But there is another problem there; as the thrust-line would be lower (not as the model was designed) and so would the propeller ground-clearance... Another solution is to use one of those rectangular 'slant-tanks' (that is wider than it is tall) and mount it, for an upright engine, inverted and snug against the top of the tank-compartment, or for an inverted engine, upright and snug against the bottom of the tank-compartment. But that would usually mean having to use a smaller fuel-tank... The obvious last solution is to use an on-board pump/regulator... But, how many kits/ARFs did you ever see with such tank-mounting (or engine mounting) instructions? So, will all those of us that are not scratch builders have to 'bite the bullet' and just live with an incorrectly leveled power-system??? Or will ALL kit/ARF manufacturers ever GET SMART? Or will future engine mounts be designed so the hole in the firewall will be at carburettor level?
