Nosen P-47 Build Marathon
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Nosen P-47 Build Marathon
Page: [1] 2 3 4 5 6   next >   >>
Login
Nosen P-47 Build Marathon - 11/6/2006 6:24:42 PM
x3heimmr
Status: offline
This is the beginning of a marathon build. I have started a Bud Nosen P-47 kit. It will have a Q-100, Annco retracts and wheels and fiberglass cowl. It will probably get a Meister razor back and canopy. Also will most likely have a retractable tail wheel. The progress so far is pretty straight forward. The first changes to be made will involve modifying the formers to accept an engine mount box that will extend back to the wing. Comments and suggestions will be appreciated ( as long as you are nice )
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: Nosen P-47 Build Marathon - 11/6/2006 6:29:24 PM
p-47 razorback pilot
Status: offline
AWSOME!!!!!!!!!!!!!!!! love the jugs... keep us posted looking to gather parts myself for a don smith 122"w/s razorback soon
(in reply to x3heimmr)
       Post #: 2
RE: Nosen P-47 Build Marathon - 11/6/2006 9:47:08 PM
x3heimmr
Status: offline
OK , how do I post the pics so there is a small icon, not a big one?????
(in reply to p-47 razorback pilot)
       Post #: 3
RE: Nosen P-47 Build Marathon - 11/6/2006 10:05:50 PM
funfly-RCU
Status: offline
I will be keeping my eye on this as I have that k same kit, Just as soon as I move into my new home, (two more weeks) I will be starting mine.
What do you think of the gear, I have the same ones and will also be useing the Q100.
Can you tell me were you are getting your cowl from as Im looking for one.
       Post #: 4
RE: Nosen P-47 Build Marathon - 11/6/2006 10:31:13 PM
x3heimmr
Status: offline
The Annco gear looks very good. It positive locks both up and down. I do not know where this cowl comes from, but I have read several other posts that say the Meister cowl should work.
(in reply to funfly-RCU)
       Post #: 5
RE: Nosen P-47 Build Marathon - 11/6/2006 10:43:05 PM
funfly-RCU
Status: offline
Looking at yours in look like it came from precision fiberglass, here is the site. http://www.precision-fiberglass-prod.com/index.php?cat=7
I will have to give them a call and get one.
       Post #: 6
RE: Nosen P-47 Build Marathon - 11/10/2006 12:31:14 AM
funfly-RCU
Status: offline
So how is the build coming, have you got much done.
       Post #: 7
RE: Nosen P-47 Build Marathon - 11/10/2006 1:44:55 AM
foodstick
Status: online
A buddy of mine had one of these framed up, ITS FREAKIN HUGE! I hope you have a building to store it in at your field! can't wait to see how it comes along. I would own one if I had a acreage..
       Post #: 8
RE: Nosen P-47 Build Marathon - 11/10/2006 2:27:42 AM
cochinito77
Status: offline
is that a conversion engine? i hope so...
(in reply to foodstick)
       Post #: 9
RE: Nosen P-47 Build Marathon - 11/13/2006 3:38:14 PM
x3heimmr
Status: offline
Here is the cowl in position before mounting it. There is a cowl ring that glues to the inside of the cowl. Then there are 1/2" dia x 2" long dowels that go from the fire wall to the cowl ring.
Click for fullsize
Click for fullsize
(in reply to cochinito77)
       Post #: 10
RE: Nosen P-47 Build Marathon - 11/13/2006 3:40:18 PM
x3heimmr
Status: offline
These pics show the cowl after the initial mounting. I will be adding more braces between the cowl and cowl ring later.
Click for fullsize
Click for fullsize
       Post #: 11
RE: Nosen P-47 Build Marathon - 11/13/2006 3:42:29 PM
x3heimmr
Status: offline
This is the horizontal stab tacked together. I still need to glue in hinge points. Then sand the leading and trailing edge to shape.
Click for fullsize
       Post #: 12
RE: Nosen P-47 Build Marathon - 11/13/2006 3:44:35 PM
x3heimmr
Status: offline
Here is the Vertical fin. Like the stab it still needs hings points and the leading and trailing edges shaped.
Click for fullsize
       Post #: 13
RE: Nosen P-47 Build Marathon - 11/13/2006 3:52:18 PM
x3heimmr
Status: offline
Looking ahead, here is a pic of the wing ribs. There is also a pic of the wing plan. I will be doubling the supplied balsa ribs with 1/8" ply in the areas marked in red. These ribs will be cut out to accept the retracts and wheels. Does anyone have any suggestions for getting the gear to line up so the wheels point straight ahead?
Click for fullsize
Click for fullsize
