RE: HBX, Who else owns one??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: HBX, Who else owns one??
Page: <<   < prev  100 101 [102] 103 104 105 106 107 108 109   next >   >>
Login
RE: HBX, Who else owns one?? - 6/18/2008 1:25:07 PM
AVIV123
Status: online
quote:
ORIGINAL: double00
HSVXU6, im looking at about $200-$250, i can get a 6-12xl feigao for $69, the mm esc for $105, or the mm combo esc and motor (4600kv or 5700kv) for $200. I was thinki9ng about getting the 7xl as it draws 95 amps and the mambamax esc can handle 100, and if i blew the bonzer up then i'd spend some buck on something stronger with lipos. But for now its the bonzer, see how far i can take it!
LOOK HSVXU6 IS MY teacher HE HELP ME A LOT
I AM TRING TO HELP YOU FROM MY experiment I SPEND A LOT OF MONY ON THE BONZER
I USE TO HAVE TZ TR MAMBA 4600 5700
1 WHEN YOU SAY 95 AND 100 AMP YOU HAVE TO KNOW THAT MOST OF THE NiMH BATT ARE ONLT 10 C AND ITS 40 AMP
THERE IS ONLY 1 BATT THAT CAN hold 20C THAT ITS 80 AMP
THIS IS THE 7 CELL BAT YOU CAN FIND 6 CELL I KNOW THAT BECUSE I KILL MY FIRST BATT
SO YOU WILL HAVE TO BUY LIPO BATT
2 The 5700 is too low on Torque for the Bonzers
3 THE 4600 IS BETTER
4 THE feigao IS TO STRONG AWAY TO STRONG AND IF YOU WILL TAKE THIS MOTOR YOU WILL NEED LIPO
http://www.youtube.com/watch?v=QNI_2LAb6hU&feature=user
http://www.youtube.com/watch?v=9utrq6OIFEs
< Message edited by Lightfoot -- 6/20/2008 10:49:46 PM >
(in reply to double00)
       Post #: 2526
RE: HBX, Who else owns one?? - 6/19/2008 1:19:29 AM
magnat
Status: offline
V3 Shocks Installed!
Man what a Difference.. I mean my Mates V3 has lower ground clearance then my V2 but now.. I have another 10mm more!
V2 owners... Hunt down a set of 75mm V3 Shocks for your V2 It makes a Big Ride height difference !
Its about as High as a V2 can go without running the risk of popping dog bones..(although it still may occur)
_____________________________
Traction: What a drag.....
(in reply to AVIV123)
       Post #: 2527
RE: HBX, Who else owns one?? - 6/19/2008 1:11:15 PM
fisheydude
Status: offline
Hey magnat, when I set my Bonzer up that high it just took a few runs to strip out the drive cups. I didn't know it was happening until a dogbone jumped out !
Just keep an eye on it.
If it''s a monster truck, drive it like a monster truck!
(in reply to magnat)
       Post #: 2528
RE: HBX, Who else owns one?? - 6/19/2008 2:28:36 PM
magnat
Status: offline
It does have side effects like being top heavy..
Tends to want to flip onto the tailgate on the shell when the climbing grade increases....
(in reply to fisheydude)
       Post #: 2529
RE: HBX, Who else owns one?? - 6/20/2008 10:56:01 PM
HSVXU6
Status: offline
Good morning to all on RC Universe that are in the southern part of the world Is that better?
       Post #: 2530
RE: HBX, Who else owns one?? - 6/20/2008 11:03:39 PM
HSVXU6
Status: offline
HI AVIV123, the battery is fine but as SMJ said it is only 10C, good for what? the price of the battery is cheap but the postage is expensive to make up for the cheap battery price, an old eBay trick from way back sucks the impulse buyers in, then they give neg feedback because they did not read the fine print.
(in reply to HSVXU6)
       Post #: 2531
RE: HBX, Who else owns one?? - 6/21/2008 8:13:01 AM
AVIV123
Status: online
HERE IS THE BATT 21$ Worldwide
Specification:
Model : 7.4V 4000mAh 10C
Dimension : 142 * 49 * 12mm
Weight : 180g
Capacity : 4000mAh
Continuous Discharge Rate : 10C
Connector : with Deans connector and balance charge plug
Suitable : RC Car & RC Truck
Package Contents:
7.4V 4000mAh 10C Li-Po Battery with female deans connector x 1
Male Deans Connector x 1
Heat Shrink Tubing x 2
#5 Aluminum carabiner keychain x 1
Click to see fullsize image.
Click for fullsize
< Message edited by AVIV123 -- 6/21/2008 8:14:04 AM >
       Post #: 2532
RE: HBX, Who else owns one?? - 6/22/2008 2:14:22 AM
magnat
Status: offline
Can anyone Get me a Part number for alloy Shock mounts to suite the Stock Bonzer!
I am in need of getting alloy shock mounts as the Plastic Chassis mounts keep breaking!
EDIT : its OK.. I think I have found the Solution!!!!!
M-03 Carbon Damper Plates !!!
So they Bolt infront of the plastic mounts and re-inforce the chassis..
< Message edited by magnat -- 6/22/2008 2:42:29 AM >
       Post #: 2533
RE: HBX, Who else owns one?? - 6/22/2008 5:32:49 PM
syncronized77
Status: offline
Hey Magnat...found this....
Blue Alloy Shock Tower
       Post #: 2534
RE: HBX, Who else owns one?? - 6/23/2008 3:01:50 AM
magnat
Status: offline
Thanks Syncro but I looked at it before, and there the Standard Alloy Suspension for the buggy, Not sure how they would go on a V2,... So I am looking at the Carbon End plates..
(in reply to syncronized77)
       Post #: 2535
RE: HBX, Who else owns one?? - 6/23/2008 10:54:03 AM
case_sense
Status: offline
wow i see this post has been going for a while.
im new to hbx though. I got myself the buggy (max 4)
so far its seems like a descent buggy for the price planning on doing a few amods to it
ie: bigger motor for starters
any ideas on descent mods for it?
here it is with my other un-known buggy
Click for fullsize
(in reply to C.A.R.)
       Post #: 2536
RE: HBX, Who else owns one?? - 6/23/2008 3:41:37 PM
magnat
Status: offline
Case Sense.... You have a V3 Buggy so what ever mods you see done to a Tamiya Baja king is exactly what you can do with yours... mind you, your already ahead as you have a v3 which should have oil filled shocks..
For a Quick Boost, Replace the ESC with a Suitable 15T esc and wack in a Tamiya RZ... unlike the Bonzers, you wont have an over gearing problem as your tyres are not much bigger then an onroad car which all HBX Vehicles were based on : the Tamiya TL-01...
(in reply to case_sense)
       Post #: 2537
RE: HBX, Who else owns one?? - 6/23/2008 3:46:44 PM
case_sense
Status: offline
Magnat thanx for the response.
do by any off chance know what the other buggy is that i have as i have no idea and no one else really seems to know
got a prob with one of the diff gears and no one seems to be able to assist with the replacement part
laters
CS
       Post #: 2538
RE: HBX, Who else owns one?? - 6/23/2008 4:19:23 PM
phmaximus
Status: offline
hows im so excited, i just won a baja king for only $50 its in 8 lots of part bags tho & a unpainted body, cant wait to get it & build it the way i want. just need to get some radio gear (might borrow the one of the nitro car for now), & some wheels
what motor should i get??? same as bonzer & gear it to 23t?
