RE: HBX, Who else owns one??
Tower Hobbies
Logged in as Guest
Users viewing this topic: Davemeal, 02ram4by4
  Printable Version
HIMOTO Mamba or Eldorada 12MM HEX Wheel Extensions
Seller:  wheelextensions
Details:   $20.00   |  8/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: HBX, Who else owns one??
Page: <<   < prev  104 105 [106] 107 108 109 110 111 112 113   next >   >>
Login
RE: HBX, Who else owns one?? - 7/13/2008 8:30:54 PM
double00
Status: offline
http://cgi.ebay.com.au/GPM-ALLOY-SPUR-42-PITCH-34T-fits-TAMIYA-TL-01-TL14234T_W0QQitemZ170238267204QQihZ007QQcategoryZ1200QQrdZ1QQssPageNameZWD2VQQcmdZViewItemQQ_trksidZp1638Q2em122
Here it is! I too have heard about the b5, b6 and b8 chargers/balancers, apparantly the b5 has the least problems, i was going to get the b8 which also charges a123 but they have worse balancing issues. I didnt want to spend $150 on a charger, see how it goes, I'll look up the resistor mod.
(in reply to ludeman)
       Post #: 2626
RE: HBX, Who else owns one?? - 7/13/2008 11:03:24 PM
HSVXU6
Status: offline
Is brushless that much better? absolutely no doubt about. Less maintenance, better runs times, more power, a larger range of motors, better ESC's, no skimming of armatures, 5mm pinion shafts and the list goes on. If you want to rock crawl there is a motor to suit everyone's tastes if you want to blow nitros off there is a motor to suit, if you want to run at the top of touring cars there is a motor to suit, if you want to off road there is a motor to suit if you want to bash there is a motor to suit and the list goes on. You can buy ESC's to run brushed or brushless with either Nimh or lipos, what more could a boy want?
Re Imax chargers. I have always had a B6 in my arsenal of chargers and gear and I have never had a problem with it. It has always charged, balanced, discharged and cycled Nicd, Nimh and 2s and 3s lipos without a problem. Some will say that the tolerances are too broad, I don't think so, I find them to be quite good. We as people are funny creatures, so will comment on something they have never owned and some love what they own. You will find that some will give you voltage readings etc without even knowing how to use a multi meter, when to take the readings and what they mean and they also expect a charger and multi meter to give you the same readings without knowing how a charger works and how batteries work. You could buy a Chev and it's great I could buy one and it could be a lemon, that's LIFE.
(in reply to phmaximus)
       Post #: 2627
RE: HBX, Who else owns o... - 7/14/2008 7:53:41 AM
double00
Status: offline
Im glad hsvxu6 has an imax and likes it, more chance that i will like mine!
(in reply to HSVXU6)
       Post #: 2628
RE: HBX, Who else owns o... - 7/14/2008 8:03:45 AM
double00
Status: offline
If anyone wants to see brushless in action just jump on youtube, it full, look for mamba max, 3s lipo, or check out this rustler, its insane!!!
http://www.youtube.com/watch?v=3AsY-x_iArI
he runs the mamba max 5700 with 3s lipo 11.1v, ill be running the 4600 with the same power source. I was going for the 5700 but the 4600 is supposed to be better for bonzers!
(in reply to double00)
       Post #: 2629
RE: HBX, Who else owns o... - 7/14/2008 8:20:24 AM
magnat
Status: offline
http://au.youtube.com/watch?v=k-3ZFp5MBnI
Bonzers with 3300kv
_____________________________
Traction: What a drag.....
       Post #: 2630
RE: HBX, Who else owns o... - 7/14/2008 12:42:22 PM
phmaximus
Status: offline
does that mean the imax chargers are a bit of a risk? i dont want to get a lemon, & i guss there is no way of testing them, ive been reading a bit some people say thay have no problems, but some people say u can replace a clutch pressureplate without maching the flywheel. yeah shure it works but will it last as long?
im tossing up against the imax b5 & the e-STATION BC6 Digital Charger from reviews im leaning to the BC6 & it comes with a mains power plug/lead, just with a quick look on ebay for a b5 & mains lead u are looking at about $100 including postage & about $169 all up for the BC6 is it worth the extra $69?
< Message edited by phmaximus -- 7/14/2008 12:44:38 PM >
(in reply to magnat)
       Post #: 2631
RE: HBX, Who else owns o... - 7/14/2008 2:04:21 PM
magnat
Status: offline
My LHS Sold the B5's none came back... In fact I looked at getting one (only for the Nimh aspect and I like having an info screen when charging)
       Post #: 2632
RE: HBX, Who else owns o... - 7/14/2008 11:10:26 PM
HSVXU6
Status: offline
I would always go for a charger that is capable of charging all types of batteries, can charge 6s, has balance built in, discharge function and a screen that shows what has happened and what is going on I don't use mains supply at all I always use a 12v deep cycle 93amp sealed battery. We take the battery to all our race meets and it runs a power distribution box with 5/30amp capable ports. That runs all our charges, the dyno, cooling fans etc, there is normally at least 3 of us using it. When we come home we put the battery in the workshop and on a charger and charge all the last lot of batteries that we used at the meet and top up all the others
       Post #: 2633
RE: HBX, Who else owns o... - 7/14/2008 11:43:32 PM
magnat
Status: offline
I use a Converter/Power supply.. there handy for when its too wet to use the car battery..
       Post #: 2634
RE: HBX, Who else owns o... - 7/15/2008 10:12:20 AM
phmaximus
Status: offline
humm still not to shure what to get?
i guss thay both charge all batterys, the BC6 "it can charge up to 16 cells of NiCd/NiMH and 6 series of Lithium batteries with maximum current of 5.0A." that sound cool & "PC based analysis using USB communication""For technical expert, BC6 offers PC based program can analysis the characteristic of the battery by USB port. It shows a graph of voltage, current, capacity and temperature curves. It also shows the individual voltage of each cell in the Lithium battery pack" wow problary over kill for me now, but might come in handy in the future.
oh oh oh well me tax refund is on the way, maby i should just bite the bullet & get the BC6
       Post #: 2635
RE: HBX, Who else owns o... - 7/15/2008 8:28:06 PM
Big Z
Status: offline
so im cruisin round ebay and i find something interesting. looks like its a tamiya mad bison.... and it looks VERY similar to a bonzer. I would post a link but the mods dont like ebay links here.... just search for "mad bison" and you should find it
       Post #: 2636
RE: HBX, Who else owns o... - 7/16/2008 10:36:27 AM
phmaximus
Status: offline
prity cool aint thay. thay share the same parts with the bonzer, wild dagger,& baja king. but these interchangable parts are only the suspension & dog bones
(in reply to Big Z)
       Post #: 2637
RE: HBX, Who else owns o... - 7/16/2008 1:23:52 PM
phmaximus
Status: offline
ive got to stay off ebay lol, i couldent help getting the alloy spur gear sounded good at the time, also got the alloy motor mount gezz... my wife is not happy with me, she doesent want to know about it, lol oh well what can ya do.
i guss i better not tell her i still want to get the hollow carbon gear box shafts, ball diff for the rear, One-Way Diff Unit for the front , shockers & sway bars. oh yeah not to forget the lipo charger & a brushless setup. hummmm... migh get her some flowers & a night out.
       Post #: 2638
RE: HBX, Who else owns o... - 7/17/2008 8:43:26 PM
