Can any one help me with my RS4 3 evo?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> HPI Racing >> HPI On-Road >> Can any one help me with my RS4 3 evo?
Page: [1]
Login
Can any one help me with my RS4 3 evo? - 11/7/2006 4:35:17 PM
Laurence Kemsley
Status: offline
hi, i have got a very big problem, my cars gears keep stripping and i do not know what the problem is. I just bought a set of gears and on the first day they where already striped so i bought a new gear, and once again one the first day that i got them they got striped so please can some one tell me what i am doing rough.
       Post #: 1
RE: Can any one help me with my RS4 3 evo? - 11/7/2006 4:52:01 PM
SpikeX
Status: offline
Which gears? The spur gears on your 2-speed or the differential gears?
If you keep stripping SPUR GEARS, you need to adjust your gear mesh. Loosen the engine mount screws and move the engine until the clutch bell and spur gears have a very small amount of play between them. Then threadlock the engine screws and put them in tight.
(in reply to Laurence Kemsley)
       Post #: 2
RE: Can any one help me with my RS4 3 evo? - 11/8/2006 10:29:54 AM
Laurence Kemsley
Status: offline
Its the spur gears, and i can not do that because the hole where the screw goes in is so small that the screws can not move to the side, and next to the screw holes is another pare of holes that are much bigger but i can not fit my engine screws in there.
(in reply to SpikeX)
       Post #: 3
RE: Can any one help me with my RS4 3 evo? - 11/8/2006 1:01:47 PM
hpi apollo
Status: offline
get some new engine mounts
_____________________________
95% of statistics are made up on the spot
       Post #: 4
RE: Can any one help me with my RS4 3 evo? - 11/9/2006 12:18:29 PM
Flaming Tire
Status: offline
Ok, yours probably uses the tapered engine holes, from what I understand by reading this. Just buy the engine mount that will use the other pair of mounting holes (as hpi apollo said) and adjust away...
It should be no more than $10.
Check out www.maxamps.com
(in reply to hpi apollo)
       Post #: 5
RE: Can any one help me with my RS4 3 evo? - 11/9/2006 12:46:28 PM
Laurence Kemsley
Status: offline
Where can i buy them? because i live in South Africa and it is realy hard to get models and parts at such a cheep prise. Here they are at lest 200 bucks and if there is a good store will they deliver to South Africa? I would like to see this engine mount, so if you have picture of it please send it to me on: lollykem@telkomsa.net
Thats if you can?
(in reply to Flaming Tire)
       Post #: 6
RE: Can any one help me with my RS4 3 evo? - 11/9/2006 1:08:46 PM
hpi apollo
Status: offline
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLR3&P=ML
       Post #: 7
RE: Can any one help me with my RS4 3 evo? - 11/9/2006 3:54:22 PM
HimotoRacingUSA
Status: online
if you have the nitro star .15, you cant use the engine mounts, the engine has the mount built onto it so they wont work, i just swapped my hpi .15 for an os .18 cv-r and had to buy the mounts to put the os engine in and use the elongated screw holes on the chassis, the hpi .15 is in a fix position on the rs4 3 evo. maybe your cluch bell has a problem??
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
       Post #: 8
RE: Can any one help me with my RS4 3 evo? - 11/10/2006 8:12:32 AM
Laurence Kemsley
Status: offline
So tell me more about the os.18 cv-r? Can it fit on my car and if it can how much would i cost? and how powerful is it to the T-15?
(in reply to HimotoRacingUSA)
       Post #: 9
RE: Can any one help me with my RS4 3 evo? - 11/10/2006 1:09:27 PM
hpi apollo
Status: offline
it will fit in the car, its about $110usd and it rapes the T-15 in power
       Post #: 10
RE: Can any one help me with my RS4 3 evo? - 11/10/2006 7:51:56 PM
HimotoRacingUSA
Status: online
ditto, its like nite and day difference
       Post #: 11
RE: Can any one help me with my RS4 3 evo? - 11/12/2006 3:27:12 AM
talontsiawd
Status: offline
quote:
ORIGINAL: ehroof
Yeah, with the original engine, there really is nothing to adjust. The mounts are on the engine and it would be almost imposible to move either the spur gears or the way the engine sits unless you made the holes bigger or slotted.
       Post #: 12
RE: Can any one help me with my RS4 3 evo? - 12/20/2006 4:04:21 AM
flow41
Status: offline
does the hpi 18ss engine comes with the 4 holes underneath it as the t-15? can any1 tell me that ?
Revo 3.3 4 Life!
(in reply to talontsiawd)
       Post #: 13
RE: Can any one help me with my RS4 3 evo? - 12/20/2006 5:05:38 AM
hpi apollo
Status: offline
yea the 18ss comes with the T-15 holes too ebcause its the same chassis
(in reply to flow41)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
