Custom G-Rafix
IA, USA Status: offline
The only concern I have with the rattle can is that is urethane/lacquer based. You can spray water based paints ontop of lacquer/urethane, but not viceversa without any adverse affects. The water based paints are so easily manipulated, even after they dry. That's why I hate faskolor paints, but they work well when all you have to paint in, is your house. And you have nothing but water base paints. How did you like that cold spell that came through last night? -1, wind chill -20, I don't suppose we will be doing any painting outside today. So answering your primary question, it may or may not work... you will have to try a scrap piece somewhere. You will have to lay that silver down thick enough to be able to get your saran wrap in place before it dries, and it may eat away at the faslucent candy base that you're using. I would practice on a 2 liter bottle before you lay it down on a body. As far as your color combo with the carbon fiber, it should work. I always try a 'crash run' on a scrap piece of lexan (wheel cut out, or bottom cut out off the same body). I always cut my bodies out before I paint them. I've got pretty large hands, and its little easier to maneuver that way, plus I will have scrap pieces of lexan to play with if I'm in question with something. It depends what red and blue you're using. If they are darker spray them last and back it with white, that will help them pop out. If they're just the basic red and blue, it doesn't really matter. If it were me, using black as the dark of the two colors, I would spray that first, then the lighter red or blue second. I would back all of it with white after I was done. My $.02, hope it helps.
_____________________________
Visit my website at www.customg-rafix.com
