Question about different balance plugs?
Tower Hobbies
Logged in as Guest
  Printable Version
Slimline Boxxer Fuel Pump
Seller:  Erick Royer
Details:   $50.00   |  9/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Question about different balance plugs?
Page: [1]
Login
Question about different balance plugs? - 11/9/2006 5:47:47 PM
Xtremespeed
Status: offline
I am running Xtreme power 3s li-po's right now.
I'm a little confused about what fits what.
I want to use a LBA6 Hyperion balancer. Will
my plugs fit? They are the 4 pin, flat, white connetors
with the 2 notches on the top. Do all the different
packs use the same connectors with a different wiring
configuration, or are the connectors different?
       Post #: 1
RE: Question about different balance plugs? - 11/10/2006 1:28:35 AM
Xtremespeed
Status: offline
Looks like the Align and E-sky packs have the same plug as mine.
None of the balancers seem to have this type plug, but the plug
seems very common on a lot of batteries. Even the no name packs
I used for my Walkera 22e had the same type. No one knows if
these will work or can be adapted to work with the LBA6 balancer?
(in reply to Xtremespeed)
       Post #: 2
RE: Question about different balance plugs? - 11/10/2006 4:33:31 AM
KB9STD
Status: offline
Xtremespeed,I don't know.I haven't used any of the three brands You mentioned.From what I can find out,it looks like the same connector used on the Great Planes 20C packs I'm using Does the connector look like this?
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMDN1&P=
If so.the adapters for the "Equinox" balancer will fit the connector and the LBA6.Be careful and double check the polarity though.I know that "Common Sense RC" is using the same connector;But the polarity is reversed.
       Post #: 3
RE: Question about different balance plugs? - 11/10/2006 4:53:00 AM
Xtremespeed
Status: offline
Thanks for the reply. That looks exactly like the connector I have.
I've read in a few places that the Equinox balancer is actually
a Hyperion re-labled for Great Planes.
Where can I get the adapter set?
< Message edited by Xtremespeed -- 11/10/2006 5:25:44 AM >
(in reply to KB9STD)
       Post #: 4
RE: Question about different balance plugs? - 11/10/2006 11:07:20 AM
RC Accessory
Status: offline
As far as I know the Hyperion line does not have an Align adpater set. I carry the LBA10 and was able to get a TP adapter for 3S packs. Right now Hyperion only supports their Hyperion/Polyquest packs.
The e-Station PB-5 and PB-6 offers an Align wiring board. Your choice of wiring set is included with the balancer. Other wiring sets include Kokam, Polyquest/Hyperion, and Thunderpower.
Evan Chapkis
RC Accessory
www.rcaccessory.com
Auth US Bantam Importer
       Post #: 5
RE: Question about different balance plugs? - 11/11/2006 1:06:41 AM
KB9STD
Status: offline
Xtremespeed,The connectors/adaprters for the equinox are sold seperately(in addition to the included 2 and 3 cell).
here are links to Tower
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXNGC4&P=V
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXNGC5&P=V
I ordered a set through my local Hobbtown USA,and use them with my LBA6.
Do check that Your batteries are the same polarity.I wouldn't get any joy from having to say "I told You!".
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
