RE: Official Thread for the Go 21 Engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Official Thread for the Go 21 Engine
Page: <<   < prev  18 19 [20] 21 22 23 24 25 26 27   next >   >>
Login
RE: Official Thread for the Go 21 Engine - 5/12/2008 7:27 PM
Tree1
Score: 100
Last Login: 4/5/2011
Status: offline
053 pipe for the 7 port
_____________________________
Nomadio Sensor, BCE Cen Matrix FRE / GO TECH .21 7P, BCE Cen TR Arena FRE / GO TECH .21 5P, "N-Tune" Nitro Engine Tuning Dia
Hide Signatures
(in reply to Jatohulk)
       Post #: 476
RE: Official Thread for the Go 21 Engine - 5/12/2008 10:54 PM
*FULL-REVS*
Score: 100
Last Login: 1/8/2010
Status: offline
or the "GO" 2047 the 053 is pretty cheep though....
Life is all about ass,Your either coverin it,Kissin it,bustin it,kickin it,tryin to get a piece of it,or just behavin like 1
Hide Signatures
(in reply to Tree1)
       Post #: 477
RE: Official Thread for the Go 21 Engine - 5/17/2008 3:08 AM
JSRacer
Score: 100
Last Login: 1/23/2009
Status: offline
Hey guys, the OS P6 should be fine for the turbo 7 port right? It was the only hot plug the LHS had. It fits fine correct?
Hide Signatures
(in reply to *FULL-REVS*)
       Post #: 478
RE: Official Thread for the Go 21 Engine - 5/17/2008 6:29 AM
Tree1
Score: 100
Status: offline
the P6 should do fine.
Hide Signatures
(in reply to JSRacer)
       Post #: 479
RE: Official Thread for the Go 21 Engine - 5/17/2008 2:55 PM
ecocav04
Score: 100
Last Login: 5/11/2012
Status: offline
Well ill add my input ive had best luck tuning the 5 port turbo engine with the bottom end needle to get it in the ballpark i set the high end needle flush and tune the bottom end and give and take a bit out of the top and i get a perfect tune with temps around 230-250 ive been running it in my buggy and its a little too much on the bottom so im looking to go to the 7 port turbo for buggy and putting the 5 port in my truggy
Caster Racing Fusion EX-1 Pro
Hide Signatures
(in reply to Tree1)
       Post #: 480
RE: Official Thread for the Go 21 Engine - 5/17/2008 5:07 PM
Safety Hawk
Score: 100
Last Login: 2/17/2012
Status: offline
You could pop a carb reducer in their to calm things down a bit.
Hide Signatures
(in reply to ecocav04)
       Post #: 481
RE: Official Thread for the Go 21 Engine - 5/18/2008 4:49 AM
JSRacer
Score: 100
Status: offline
Well, I put around 10 tanks through the 7 port today and a buddy has around 20 tanks through his and we're having identical problems. When we began to lean a little for a better tune we saw temps jump up around 300 degrees F! We then tried to fatten them up and find that we can get temps down around 230-240 but they run like crap. Way too rich. We both have years of expericence and have broken in many many engines and we're both stumped. I know they are tight, very tight engine but wow! Is this a common experience with GO engines? I've never had an engine want to run so hot. I'm not diggin' the high temps. I'm wondering if we both got a batch of the "bad carb" engines. My serial number is US0000624, and his is only about 6 down the line from mine. They have composite carbs. But anyway, I'm wondering what you all think.
Hide Signatures
(in reply to Safety Hawk)
       Post #: 482
RE: Official Thread for the Go 21 Engine - 5/18/2008 6:29 AM
Vigilante212
Score: 100
Last Login: 1/8/2012
Status: offline
I am not having any issue with mine. What exactly is your doing? Is it lean bogging? This happened to me about a week ago. I had to richen up the HSN about an 1/8th of a turn and lean out the LSN and increase my idle a bit. The Go techs like a fat high speed and a lean low speed needle. The 2008 carbs are diffrent so you might be able to order those and its possible those will be more like standard tuning, but its hard to say.
I ran my engine all day today and it stayed between 220-240 and ran like a raped ape . I have about 3/4 of a gallon on it.
Hide Signatures
       Post #: 483
RE: Official Thread for the Go 21 Engine - 5/18/2008 6:32 AM
vnmsgt
Score: 101
Last Login: 12/30/2011
Status: offline
quote:
ORIGINAL: Vigilante212
DUDE I cannot stand you pic under your name!!! LOL! Everytime I see it, it annoys me Anyway I am going to the track with my new 7-port for the first time in the morning. Hope to have some butt whipping fun!
Don''t jump on the bandwagon...CRUSH IT
Hide Signatures
(in reply to Vigilante212)
       Post #: 484
RE: Official Thread for the Go 21 Engine - 5/18/2008 11:26 AM
supertib
Score: 302
Last Login: 5/23/2013
Status: online
quote:
ORIGINAL: JSRacer
what brand of temp gun are you using ???? most likely your gun is out of calibration and giving you false readings..... Next time you run the motor do the spit test on the cooling head, if the motor really is 300F the spit will vaporize almost instantly !!!!
Neal Smith..owner Clockwork Racing Engines
Hide Signatures
       Post #: 485
RE: Official Thread for the Go 21 Engine - 5/18/2008 3:42 PM
Vigilante212
Score: 100
Status: offline
quote:
ORIGINAL: vnmsgt
It gets your attention though doesnt it
Hide Signatures
(in reply to vnmsgt)
       Post #: 486
RE: Official Thread for the Go 21 Engine - 5/18/2008 4:37 PM
JSRacer
Score: 100
Status: offline
We have 2 other temp guns confirming the temps. Another guy was running a SW .26 and it was reading around 215F the whole day. I actually did use the spit test but it took a few seconds to vaporize. Since my last post I've switched the carb out with my OS carb but haven't tried it yet. So I'll report back.
Hide Signatures
       Post #: 487
RE: Official Thread for the Go 21 Engine - 5/18/2008 5:13 PM
supertib
Score: 302
Status: online
quote:
ORIGINAL: JSRacer
if it took a few seconds then its not 300F.......... 300F vaporizes instantly....
Another case of tuning by temps..motor is running great, good smoke trail yet people panic because a little Hobby Grade temp gun reads 300F.....chances are you are not 300F
Hide Signatures
       Post #: 488
RE: Official Thread for the Go 21 Engine - 5/18/2008 11:29 PM
*FULL-REVS*
Score: 100
Status: offline
the other thing that will spike a high temp with a go motor is a air leak.... just the smallest leak will cause it....have you sealed the motor??? also if there is still ALOT of pinch this will cause it too.... the added friction causes a high temp.... as a rough guide keep it rich and happy till you can turn the flywheel over with your finger... oh and check your head bolts.... ive had two turn up from factory with loose bolts.... let us know how you get on....
Hide Signatures
(in reply to supertib)
       Post #: 489
RE: Official Thread for the Go 21 Engine - 5/18/2008 11:50 PM
JSRacer
Score: 100
Status: offline
Ok, a little update. I threw on the carb from my old OS 21 VG and it cut the temps down a bunch. I let the GO rip up and down the street for a while and leaned it out to a decent tune. The highest temp I have yet to see is 262F. It's running fairly consistant around 230-240F. I think I found the culprit, but I'll continue to test it out and report back.
Hide Signatures
       Post #: 490
RE: Official Thread for the Go 21 Engine - 5/19/2008 2:20 AM
Vigilante212
Score: 100
Status: offline
Check the o rings on the go carb one of them is probably damaged.
Hide Signatures
       Post #: 491
RE: Official Thread for the Go 21 Engine - 5/19/2008 2:59 AM
vnmsgt
Score: 101
Status: offline
Just ran my .21 7-port today on the track for the first time today and WOW! The more I ran it throughout the day the more power it got and that was with the 7.5 carb restrictor in it too. I was using only a quarter throttle all day long with the my ZX1-R buggy and it was ripping! Temps were around 235-245 most of the day. Power delivery is very smooth the not abrupt. Easy to drive. My other friend ran his 2 NEW Go techs .28 6-port and .21 7-port and we had a blast all day long. Both of us went from OS .21 V-specs and Picco .28 and OS .21 VG and could not be happier making the switch.
Hide Signatures
       Post #: 492
RE: Official Thread for the Go 21 Engine - 5/19/2008 9:14 AM
*FULL-REVS*
Score: 100
Status: offline
well my two "GO" babies did me proud on the weekend.... 2nd in buggy and a 2nd place in truggy.....over the moon
Hide Signatures
       Post #: 493
RE: Official Thread for the Go 21 Engine - 5/19/2008 9:52 AM
smracer31
Score: 100
Last Login: 5/27/2009
Status: offline
quote:
ORIGINAL: ecocav04
you want to try the 3 port race, i just finished breaking mine in and the power band is very nice on it, i have yet to take it to the track hower. I also have a 7 port with a little less than a gallon on it, and i am going to see which one i like more for racing, and use the other for practicing.
Hide Signatures
       Post #: 494
RE: Official Thread for the Go 21 Engine - 5/19/2008 11:32 AM
supertib
Score: 302
Status: online
Go engines will leak at the carb... the carb body will spring a leak at the seam between the composite body and the metal endbell... this requires a bead of JB weld to fix..
Hide Signatures
(in reply to smracer31)
       Post #: 495
RE: Official Thread for the Go 21 Engine - 5/19/2008 5:31 PM
nucular
Score: 100
Last Login: 11/27/2010
Status: offline
I started breaking my 3 port in this weekend and was having a lot of trouble keeping it running for the 1st 2 break-in tanks. I had the HSN out 2 turns (according to the sheet that came with it) but i have heard other people say 1 turn out from flush which is a huge difference. It would stay running if i left the ignitor on it. The entire time it was just spitting fuel out the exhaust which tells me it was way too rich. I tried to turn the lsn in a little but then it would just run erratically. Are these pretty finicky during breakin?
Hide Signatures
       Post #: 496
RE: Official Thread for the Go 21 Engine - 5/19/2008 5:43 PM
slayerphonics
Score: 100
Last Login: 8/20/2009
Status: offline
quote:
ORIGINAL: nucular
Is it the Race version?
There's a right way and wrong way to do everything and the wrong way is trying to make everybody else do it the right way
Hide Signatures
(in reply to nucular)
       Post #: 497
RE: Official Thread for the Go 21 Engine - 5/19/2008 5:46 PM
nucular
Score: 100
Status: offline
Yes, the race version. Also, i did not have the additional shim installed. I put it in yesterday but haven't had time to try again. I am using O.S. P6 turbo Hot plugs too.
Hide Signatures
(in reply to slayerphonics)
       Post #: 498
RE: Official Thread for the Go 21 Engine - 5/19/2008 6:04 PM
slayerphonics
Score: 100
Status: offline
quote:
ORIGINAL: nucular
I'm debating on buying this engine, your post has me worried though
Hide Signatures
       Post #: 499
RE: Official Thread for the Go 21 Engine - 5/19/2008 6:18 PM
nucular
Score: 100
Status: offline
well, don't worry too much yet. I have broken in several engines but this is my first 'race' class so it could be user error.
Hide Signatures
       Post #: 500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.781RCU1
