RE: Official Thread for the Go 21 Engine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Official Thread for the Go 21 Engine
Page: <<   < prev  18 19 20 21 22 [23] 24 25 26 27   next >   >>
Login
RE: Official Thread for the Go 21 Engine - 6/2/2008 2:11:48 PM
slayerphonics
Status: offline
What I've seen from this new 3 port R-spec,
I used 2 diffrent pipes,
A low end
and an 086
The low end pipe gave a nice crackle and a quick power on the blips, but top end felt really choked, like the RPMs just hit a wall,
on the 086, didn't have as much quick low power but the repsonse was smoother, but the top end still lacks, again RPMS just hit a wall,
_____________________________
There's a right way and wrong way to do everything and the wrong way is trying to make everybody else do it the right way
(in reply to gizmatron)
       Post #: 551
RE: Official Thread for the Go 21 Engine - 6/2/2008 3:41:36 PM
supertib
Status: offline
quote:
ORIGINAL: slayerphonics
A low end
and an 086
I am not impressed with the 3 port R.... i am actually curious why Go even made one... it doesnt have the power of either the 5 or the 7 port, yet it costs just as much.......... most people are reporting the 3 port is somewhat of a dog....
seeing is believing !
(in reply to slayerphonics)
       Post #: 552
RE: Official Thread for the Go 21 Engine - 6/2/2008 4:19:50 PM
slayerphonics
Status: offline
Id agree, its bottom is okay, but it really has no top,
I go from driving a sirio in a truggy that has more weight and bigger tires and it still out powers the R-spec by miles,
Luckly they changed our track around so the r-spec works fine, but I wouldn't buy it again.
(in reply to supertib)
       Post #: 553
RE: Official Thread for the Go 21 Engine - 6/3/2008 2:17:42 AM
Vigilante212
Status: offline
Try the 0801 pipe from go tech for the 3 port r. Go tech made the 3r for a more linear powerband like a v-spec. And the 3 port r is actually cheaper then the 5 or 7 ports.
I really like my 5 port though. Low end is insane in my buggy. and i managed to outrun a moded O.S. .30 on a 200 foot straight that was also in a buggy. He couldnt control it worth a damn on the corners and jumps though
< Message edited by Vigilante212 -- 6/3/2008 2:22:03 AM >
www.rcfreak.com - SavageX SS axial RR powered. - Xray 808 Go tech 5 port Turbo
O.C.C. Director
       Post #: 554
RE: Official Thread for the Go 21 Engine - 6/3/2008 7:51:56 AM
gizmatron
Status: offline
well I'm running in a massive mods 3 port R stage 5 modded and its seems to have as much power as the 7 port I also own...haven't got to the point of opening it wide yet but will report as soon as the rain stops and play resumes....
Kyosho sp2 WC with fioroni and k-factory upgrades.GO tech 3 and & 7 port engines.. massive mods stage 5 on both ..LET em RIP
(in reply to Vigilante212)
       Post #: 555
RE: Official Thread for the Go 21 Engine - 6/3/2008 1:56:59 PM
supertib
Status: offline
quote:
ORIGINAL: Vigilante212
I would not put the words 3R and VSpec in the same sentence.... the V-Spec absolutely rips on the Go engines, all of them ( as long as its a 2007 Spec).............there were rumours the 3 port was to compete with the V-Spec, but its applaes and oranges comparing those 2 mills.
       Post #: 556
RE: Official Thread for the Go 21 Engine - 6/3/2008 2:02:55 PM
slayerphonics
Status: offline
Lol Rspec compete with the vspec?! its not even close.
       Post #: 557
RE: Official Thread for the Go 21 Engine - 6/3/2008 11:09:41 PM
Vigilante212
Status: offline
Thats what I was told so.
O.C.C. Director
       Post #: 558
RE: Official Thread for the Go 21 Engine - 6/4/2008 2:49:50 AM
hrdcoreglf
Status: offline
I think the 3R and the VSpec are both good engines. I did it, I put both of them in the same sentence. In the right hands either engine could win a race. In the wrong hands either one is uncontrollable. I own several engines ( not as many as some , and for the price a slightly modified 3R runs pretty well. I do have to say this is the best idling engine I have ever had. The only time it has died is from being upside down for 30 sec on a track with only 3 turn marshals (when every one is running almost every class, there is no one left to turn marshal, anyway complaint for another post someday), by the time the air bubble hit the carb it was to big to keep fuel flowing. Really for the price you can't beat the performance you can get out of the 3R.
Wisdom is only as good as the person you give it to.
       Post #: 559
RE: Official Thread for the Go 21 Engine - 6/4/2008 4:17:56 PM
CtK
Status: offline
quote:
ORIGINAL: CtK
quote:
ORIGINAL: Safety Hawk
quote:
ORIGINAL: CtK
Took my car out to the track last nite. Has about 8 gas tanks through it now. Ran pretty well, except for the last couple of gas tanks, when I was leaning it out a bit. The temp shot all the way up to 280.
Before the last couple of tanks it was running in the 240 range. Was going about half throttle most of the time.
Is something wrong with it??
thanks!!
Check for air leaks. Might be causing it to lean out too much.
Will do, thanks!!
Was at the track last night. Was able to start it up without having to heat it up. Just loosen the glow plug a bit.
The temps were about 220-240, but still lots of smoke and groggy at the start. Its about half a turn from the stock setting.
Should I just keep on leaning it out more??
Losi 8ight Roller with Go Tech .21 5 Port
I AiM tO MiSBeHaVe!!
(in reply to CtK)
       Post #: 560
RE: Official Thread for the Go 21 Engine - 6/4/2008 5:25:13 PM
hrdcoreglf
Status: offline
Yes you can lean it out more as long as you have good temps and a good trail of smoke. Just keep checking your glow plug. If it is real wet looking, you are rich, if it is bone dry and the filiment is grey and distorted your to lean.
(in reply to CtK)
       Post #: 561
RE: Official Thread for the Go 21 Engine - 6/4/2008 7:12:54 PM
slayerphonics
Status: offline
Id lean the low speed out some,
Don't worry about temps to much,
If it has good performance, and you see smoke, and no lean bogs let it rip
(in reply to CtK)
       Post #: 562
RE: Official Thread for the Go 21 Engine - 6/5/2008 3:33:28 PM
slayerphonics
Status: offline
Here are the guts minus the crankshaft, Just didn't feel like removing the clutch
3port R-spec
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to hrdcoreglf)
       Post #: 563
RE: Official Thread for the Go 21 Engine - 6/5/2008 10:33:14 PM
Vigilante212
Status: offline
wow thats alot of carrbon buildup what kind of fuel are you running?
O.C.C. Director
       Post #: 564
RE: Official Thread for the Go 21 Engine - 6/5/2008 11:15:28 PM
