RE: Official Thread for the Go 21 Engine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Official Thread for the Go 21 Engine
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Official Thread for the Go 21 Engine - 1/27/2007 10:50:14 AM
Hincappe
Status: offline
the cooling head fit.
the button head may be different but.
_____________________________
Hincappe Made in France. The best country in the World. So you think you can Drive? France has got Talent.
(in reply to nigrugt)
       Post #: 51
RE: Official Thread for the Go 21 Engine - 1/27/2007 7:38:02 PM
Jerseyboy
Status: offline
quote:
ORIGINAL: nigrugt
other question, Can some gice me the measurement of the head(where the plug is inserted). I need the measurement from one bolt to another so I can check if the Vspec turbo head will fit the Go engine. Sry for my english but I am not english man!
Yes it will fit. I check it, its the same as the Vspec.
       Post #: 52
RE: Official Thread for the Go 21 Engine - 1/27/2007 8:47:15 PM
nigrugt
Status: offline
Yes its great that it will fit!! Thanks, now which glow plug do you think is the best to be used on the Go? The os turbo P3 ultra hot or the P6?
(in reply to Jerseyboy)
       Post #: 53
RE: Official Thread for the Go 21 Engine - 1/28/2007 1:58:02 AM
Nathan9492
Status: offline
well what % of nitro u using?
       Post #: 54
RE: Official Thread for the Go 21 Engine - 1/28/2007 2:23:40 AM
Kemo
Status: offline
anyone have a close up of their idle set screw on the carb?
There are only 10 types of people in this world: those that understand binary, and those that don''t.
AMA: 722748
(in reply to Nathan9492)
       Post #: 55
RE: Official Thread for the Go 21 Engine - 1/28/2007 3:31:43 AM
russj
Status: offline
Hello everyone I am the owner of racefactor industries the U.S. dist. for Go Tech. engines. I thought i would come on here to answer any questions about the Go Tech line of engines. So if anyone has any questions fire away and i will try to get on here as often as possible.
Regarding the O.S. turbo button head, even if the o.s. turbo button head fits the bolt pattern of the go engine i would reccomend against it. There is .2mm of shimming machined into the go tech turbo button head, this coupled with two shims (1x.1mm, 1x.2mm) to give you .5mm of head clearance, If you were to use the o.s. head you may end up with an improperly shimmed head and that can cause all kind of tunning and performance issues. Best way to check is to open up the engine and check for detonation. If you do have detonation i reccomend a complete teardown and cleanup of the engine to help get any metal chips out of the engine. All this is uneccesary if you just purchase a Go Tech Turbo head button part no. 21-0207 (please see your local dealer)
also the o.s. p3 plug seems to work great
< Message edited by russj -- 1/28/2007 6:48:18 AM >
(in reply to Kemo)
       Post #: 56
RE: Official Thread for the Go 21 Engine - 1/28/2007 11:18:47 AM
nigrugt
Status: offline
Anyone tried to measure exactly the os and go turbo heads?? Anyone tried to fit the OS head??
(in reply to russj)
       Post #: 57
RE: Official Thread for the Go 21 Engine - 1/29/2007 5:58:01 AM
Jerseyboy
Status: offline
Sorry! the OS cooling head fits, but the button will not fit.
       Post #: 58
RE: Official Thread for the Go 21 Engine - 1/29/2007 10:38:35 PM
nigrugt
Status: offline
Its ok, I ordered a turbo head... about the graph of the dyno test, What is the maximum bhp? Because I don't understand what OBS Hp is..... can someone tel me?
       Post #: 59
RE: Official Thread for the Go 21 Engine - 1/30/2007 7:27:28 AM
Nathan9492
Status: offline
has anyone got a vid that they wanna share with us PLEASE!, I REALLY WANNA SEE ONE 'GO'
       Post #: 60
RE: Official Thread for the Go 21 Engine - 1/31/2007 11:00:44 AM
nigrugt
Status: offline
another question, which head you think is more effecient to radiat heat, the Blu OS heAD or the GO head??
       Post #: 61
RE: Official Thread for the Go 21 Engine - 1/31/2007 9:10:14 PM
JJJEEEFFFFFF
Status: offline
Are you having a temp problem? i wouldn't think there would be alot of difference but the OS is probably the better of the two.
If your engine is running hot a really big cooling head might treat the sympton but it wont treat the problem.
       Post #: 62
RE: Official Thread for the Go 21 Engine - 2/2/2007 12:02:34 PM
Jerseyboy
Status: offline
The Go head is definitely better for cooling. You can compare size, fins and area. It is bigger in size.
(in reply to JJJEEEFFFFFF)
       Post #: 63
RE: Official Thread for the Go 21 Engine - 2/5/2007 3:59:59 PM
nigrugt
Status: offline
any news on this engine?? Someone faced bearing problems or something?
       Post #: 64
RE: Official Thread for the Go 21 Engine - 2/6/2007 5:55:02 AM
Jerseyboy
Status: offline
Ive had acople of practises and a race meeting. So far no issues.
       Post #: 65
RE: Official Thread for the Go 21 Engine - 2/9/2007 8:49:55 PM
satoch
Status: offline
Finished break in and after about 16 tanks had the motor set at race tune yesterday at practice. I'm running Byron's %30 and a Sportwerks HT pipe with the short "U" header and a 13t bell in my Mayhem Pro. It was really cold at the track-about 25 degrees f on the track but the motor stayed rock solid at 225 and idled all day.
I drag raced my buddy with a modded RB WS72 in a Losi 8 down the 110' back straight repeatedly and he had nothing on me. I know he had better traction however. I had to brake before the motor topped out so I can't wait for summer so I can hit the 215' straight.
The motor had no problems getting me over the somewhat tight but flowing in field with no problems. So far so good. For the price I'd say it's a winner. Longevity is the next question but I'm confident.
Rides:
Losi 8 Pro buggy w/Go Tech 5 port .21
