Jerseyboy
Joined: 11/1/2006 From: SA Buggy Racer, SOUTH AFRICA Status: offline
The engine is abit of a b!tch to run in. If you follow this you will be on the nose. Important information for the operation of your new GO Technology engine. - Go engines are made to extremely tight tolerances. If you turn over the engine, it will feel as if the piston gets stuck in the liner. - GO engines are high performance racing engines, and beginners should seek the assistance of an experienced modeler or dealer in the running-in of the engine. Running-in procedure - Take note of the factory needle settings and do not adjust until after about 1 litre of fuel has been run through the engine. - Pre-heat the engine with a hairdryer to about 60-80 degree C. - Prime the carb with fuel - Make sure that the engine is at idle. - Start the engine with a start-box and leave the glow warmer on for about 30sec. - Let the engine idle for 1 tank. If the engine sounds like it wants to die, then pinch the fuel line briefly. This will increase the idle RPM - Do not REV the engine for the first 3 tanks - After each tank of fuel, let the engine cool down with the piston at BDC. - Repeat the whole process for a total of 3 tanks of fuel. - For the remainder of the fuel (about 1.5litres) start to drive the car around a track. - Do not blip the throttle, but use smooth acceleration only briefly letting the engine be at full RPM. - Run the engine at about 100-110 deg. Failing to run at these temperatures, will not allow the engine to run-in properly. Full run in is complete after 3 litres of fuel. - After the first 9 litres of fuel, we suggest to change the conrod. General Information Due to the tight production tolerances you might find that your engine temperature rises above 145 deg C. Start by opening the LSN by ¼ turn and then the HSN by ¼ turn. If you find that after running continuously for more than 15 min the pull away power (bottom end) seems to bog down, then there may a slight crank rub. Occasionally engines develop crank rub due to the production process. It can be seen by fine lines on the crank. This condition is easily cured by removing the crank and polishing the crank between the bearings with 400 grit water paper, used dry, and then 1000 grit water paper (used dry). Ask your dealer to assist if you are unsure. Alternatively, ask your dealer to send the engine to the importer where we will do the crank polish free of charge. A well tuned GO engine will have power equivalent to engines that are twice the price and longevity to meet.
