ProBroJoe -> RE: Postal Plane Project (2/29/2008 2:56 AM)
We lost another elevator servo? Sounds almost like the same symptoms too... quote:
ProBroJoe: The not so good news... We somehow lost a elevator servo. While I was adjusting the pushrods and setting the trims, I noticed that when I pressed on the output shaft of the elevator servo it would go into serious jitters (back and forth to each extreme). Not wanting to take a chance, I swapped it out for a brand new HS-55 (fresh out of the box). No biggie, stuff happens... I put a brand new servo in place just before Christmas - I wonder if something is happening in shipping? I noticed the elevator control rod sticks out past the fuse a bit - maybe it's getting banged around in transit and taking out the servo's potentiometer? Perhaps part of the shipping S.O.P. can be to disconnect the elevator pushrod at the elevator and then retract the pushrod so it doesn't stick past the fuse? It's just a thought - but it does seem a little more than a coincidence... I can't speak for the rest, but I usually don't mess with a failsafe - I'd rather the receiver "take a hit" and get over it, then go into failsafe at a real inopportune time. I flew Grace in 10-15 MPH winds and was happy to get 'er down and put 'er away. If it were my plane, I may have felt differently, but I didn't want to be the first to dork Grace in! Oh, the RX pack is a 270 mAh NiCAD, and it was cycling a bit over that, more like 280-290... but of course the standard disclaimer applies, you results may very, etc... [;)] Looking forward to the flight report / video! -Joe
