RE: Postal Plane Project
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Postal Plane Project
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Postal Plane Project - 11/11/2006 3:27 PM
dieFluggeister
Score: 102
Last Login: 3/8/2010
Status: offline
I was thinking the same thing Hog. I had thought about stickers but should the plane have to be re-covered then they would all be gone. I also thought a paper "pilots log book" would be included with the plane and fun to record who, what, where, when, etc. Then I thought an online 'log book' would give a chance for everyone to check in and read. I guess I'm open.
As for donating engines, servos etc, I would love for you all to take part but that's really up to you. I cant say if the thing will even ever come back, so dont commit anything that you wouldn't want to lose.
I'm working to get a design sketch up today. Will need your critical eye on that before it can be outfitted with equipment.
Hide Signatures
(in reply to hogflyer)
       Post #: 26
RE: Postal Plane Project - 11/11/2006 6:15 PM
jerusha
Score: 100
Last Login: 10/2/2007
Status: offline
thats a great idea. i would definitely fly it for the midwest region. (Iowa) however i think that it would be a good idea to keep the plane easy to fly. a shrike sounds kind of hot. otherwise theirs a good chance this plane wont make it very far.
_____________________________
-BS has the same mathematical properties as the number 1; that is, BS raised to any power is still BS
- Albert Einstein
Hide Signatures
       Post #: 27
RE: Postal Plane Project - 11/11/2006 9:47 PM
dieFluggeister
Score: 102
Status: offline
Ok guys, here's my first thought. Since I want a plane flyable by the masses let's go for simple, rugged, easy to fly. Just a sketch so I still have to add detail.
High wing, Rudder / Elevator only, simple box fuse. It uses a Jedelsky type airfoil for easy construction of the wing and is resistant to damage. Rubber band wing hold down, and a basic Cox 049 engine.
Span 28" Area 165 squares, Aspect 4.8, MAC 6", Dihedral 5 degrees
Length 26" Total Estimated AUW 11.5 oz.
Wing Loading 9.6 oz
Alright all you aerodynamicists, critiques?
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to jerusha)
       Post #: 28
RE: Postal Plane Project - 11/11/2006 10:48 PM
rainedave
Score: 100
Last Login: 2/23/2010
Status: offline
That looks really nice! But, I'm betting it will come out less than 11oz.
Hide Signatures
(in reply to dieFluggeister)
       Post #: 29
RE: Postal Plane Project - 11/11/2006 11:46 PM
eroc144
Score: 100
Last Login: 3/20/2010
Status: online
God no, don't put a Cox on it. We want everyone to be able to fly it!
Nothing is impossible when you don''t know what you''re talking about
Hide Signatures
(in reply to rainedave)
       Post #: 30
RE: Postal Plane Project - 11/12/2006 12:05 AM
ptulmer
Score: 100
Last Login: 3/19/2010
Status: offline
dF, did you use a bolt-on or rubberbanded tail group for the suitcase racer?
Looks nice, like a sportster. Could be a bit quick with a Norvel/AP .061. Isn't that pretty much the same basic description as a "Honker"?
Coming soon to a grass field near you...
Hide Signatures
(in reply to eroc144)
       Post #: 31
RE: Postal Plane Project - 11/12/2006 2:23 AM
vicman
Score: 140
Status: offline
If it hits me first I will get a foam box made up that should make it around the world. Also I want it before Rog! No curses on this end . Also I can transport it along the CC I-40 corridor . Deadsitck included.
Sicks and pics are all great ideas.
Make Raymond build it so he quits whinning about not working in his shop that he won't ever finish.
I personally request F brand radio gear.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
(in reply to ptulmer)
       Post #: 32
RE: Postal Plane Project - 11/12/2006 4:10 AM
hogflyer
Score: 105
Last Login: 3/5/2010
Status: offline
quote:
ORIGINAL: dieFluggeister
Wing Loading 9.6 oz
Only problem I see with using a Jedelsky type airfoil is crash repair. You have to consider it will be repaired and need to be sure everybody will be able to construct a new wing similar to the old one. A built-up wing may be better, and a set of plans kept with the plane to facilitate crash repair. I think a flat bottom airfoil like the Bipe's trainer may be better - easier to fly and repair.
Hogflyer
Flight Training Coordinator - Wichita Radio Control Club - AMA Intro Pilot
www.wichitaradiocontrolclub.org AMA 47317
Hide Signatures
       Post #: 33
RE: Postal Plane Project - 11/12/2006 4:44 AM
combatpigg
Score: 221
Last Login: 3/21/2010
Status: offline
How about having a mass exchange of planes, drawn from a hat?. Everybody submits a trimmed out plane that some lucky guy at the receiving end has to deal with until it has been flown? Within reason, I mean the plane has to be at least worth the cost of the postage. If you throw your hat in the ring, you are fair game. Then at some predetermined date, the game of musical chairs goes into round 2? just a slight twist on the original idea.
...all beach yo hayed ****!
Hide Signatures
       Post #: 34
RE: Postal Plane Project - 11/12/2006 5:17 AM
Andrew
Score: 100
Status: offline
quote:
ORIGINAL: ptulmer
The Honker is bigger: 36" span, 7" chord, 252 sq. in.
Mine is 22 oz. RTF -- monokote covered, one repair, NORVEL .061 with tank mount, Futaba s133's, Standard RX, 400 mAH NiCAD
< Message edited by Andrew -- 11/12/2006 5:21 AM >
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
       Post #: 35
RE: Postal Plane Project - 11/12/2006 3:31 PM
dieFluggeister
Score: 102
Status: offline
PT, my suitcase racer used a friction fit tube assy. with a shear pin to align it. I like the idea of the tail group be removed here too, thanks for pointing that out. Honestly, this one was inspired by my Honker simply because it has always been a tough little flyer. This one is somewhat smaller, with different moments and incidences. I worked to make it an original.
Hogflyer, I picked the Jedelsky because it was so easy to replace. And super tough too. You could whip one out in about 30 min with no jigs or templates, and no fussy rib cutting and alignment.
Well, I'm not hearing things like "too hot", or "too mild" so unless I hear some big objections to the design I'll go ahead and build a prototype for a flight test. Still appreciate any input though.
< Message edited by dieFluggeister -- 11/13/2006 1:15 AM >
Hide Signatures
       Post #: 36
RE: Postal Plane Project - 11/12/2006 5:36 PM
Bipe Flyer
Score: 100
Status: offline
It might be worthwhile to try and make it fit in a box that is under the maximum size for a small packet. Shipping a large box to Australia or Japan could be fairly expensive.
1/2A all the way!
Club Saito #151
Hide Signatures
       Post #: 37
RE: Postal Plane Project - 11/13/2006 12:11 AM
jerusha
Score: 100
Status: offline
sounds great but i dont think you should put a cox on the plane. i have only had bad experiences with them. also i think you should add strip ailerons. if the people dont want to use them than thats fine
- Albert Einstein
Hide Signatures
(in reply to Bipe Flyer)
       Post #: 38
RE: Postal Plane Project - 11/13/2006 12:51 AM
Andrew
Score: 100
Status: offline
Another possibility might be the 1/2A SST. Uses the ACE foam wing, 33" span, 252" area, can be flown as A/E or A/E/T. The stab could be mounted with nylon screws for ease of shipping. I'm sure this group could design a simple, effective means of splitting the wing in half.
The gray SST belonged to Lynn Sipe; the yellow plane was posted here or on RCG some time ago -- it is a SST lookalike.
DF's Jedelsky wing is pretty tough, takes two sheets of wood and can be built flat with a simple spacer. It does require some planeing and shaping to reach the final airfoil.
Click for fullsize
Click for fullsize
the "other" andrew
Hide Signatures
       Post #: 39
RE: Postal Plane Project - 11/13/2006 12:59 AM
flyinrog
Score: 100
Status: offline
maybe a simple series Cub? with no landing gear for postal reasons, the box would end up being about the size of the kit box anyway....Rog
Ever walk into a room and forget what you went in for?...ADHD, welcome to my world,it happens everyday!
Hide Signatures
(in reply to Andrew)
       Post #: 40
RE: Postal Plane Project - 11/13/2006 10:39 AM
Boomerang1
Score: 100
Status: online
Just stumbled upon this post, cool idea, count me in! Just one thing, will it fly upside down? I'm sure if the servos are brand H they will work fine with brand F & J, probably the most poular world wide. Don't bother with the reciever as frequencies vary around the world, where will the pics be posted, on the thread? - John.
< Message edited by Boomerang1 -- 11/13/2006 10:47 AM >
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
(in reply to flyinrog)
       Post #: 41
RE: Postal Plane Project - 11/13/2006 4:52 PM
KidEpoxy
Score: 205
Status: offline
take down Wing?
2 wing halves with a pin/screw at the root & a mid-half rigid strut ala Cub/cesna152 to the fuse bottom
AMA had Optional MA, lets do it AGAIN
:( "the public can fly there, since the public can purchase an AMA card" -804
Hide Signatures
(in reply to Boomerang1)
       Post #: 42
RE: Postal Plane Project - 11/13/2006 10:50 PM
ptulmer
Score: 100
Status: offline
I was mis-remembering, anyway. (thanks for the reminder Andrew) Heck, no matter what the inspiration, starting with a blank sheet of paper makes it an original. I was thinking that with a "good" engine this might be kinda hot. You know what you're up to, though. Can't wait to see the end result!
Hide Signatures
       Post #: 43
RE: Postal Plane Project - 11/13/2006 11:14 PM
Lomcevak Duck
Score: 105
Status: offline
When this plane comes through the heartland I want to be on the list of pilots
This is a great idea. Most likely will get stuck overseas somewhere, and no one will ever see the plane more than once, but I like the idea.
When someone loses a plane in the pits, you do a lomcevak duck.
www.georgiacarry.org
Hide Signatures
       Post #: 44
RE: Postal Plane Project - 11/13/2006 11:37 PM
MajorTomski
Score: 100
Status: offline
Have a look around here for the Tiger Moth World Tour.
We've already sent the same tiger moth to all 50 states and now it's starting its trip around Canada.
Have a look at the box and the packing, save you some time in reinventing the wheel
Tom
Hide Signatures
(in reply to Lomcevak Duck)
       Post #: 45
RE: Postal Plane Project - 11/14/2006 12:53 AM
skaliwag
Score: 100
Status: offline
There are postal sizes in Europe that determine the price and how quick it gets there . I think a major factor is that the total of the 3 sides must be less than 150cm and the long side be less than 90cm. Could be their sorting (Krunching) machings.
Real Airplanes have Round Engines and Two Wings.
Hide Signatures
(in reply to MajorTomski)
       Post #: 46
RE: Postal Plane Project - 11/14/2006 5:03 AM
Mr67Stang
Score: 140
Status: offline
quote:
ORIGINAL: flyinrog
Rog, everyone here knows that you have an extream predjudice against landing gear. You don't have to make excuses about it.
He who dies with the most toys wins!
Hide Signatures
       Post #: 47
RE: Postal Plane Project - 11/14/2006 5:07 AM
vicman
Score: 140
Status: offline
LOL, he hates planes that fly too.
Hide Signatures
(in reply to Mr67Stang)
       Post #: 48
RE: Postal Plane Project - 11/14/2006 2:38 PM
flyinrog
Score: 100
Status: offline
Great, I didnt realize that the annual Jump in Rogers &^%$ day had gone statewide, thought it was still a local thing...Fine, go ahead and add landing gear and make sure its a wood wing, I wanna send plenty 'o' splinters on to Vicmanmefirstmefirstbratboy since he has so much time on his hands he can rebuild it for Mr. car guy....who should then pay to ship it to Japanman....Rog
Hide Signatures
       Post #: 49
RE: Postal Plane Project - 11/14/2006 4:18 PM
dieFluggeister
Score: 102
Status: offline
quote:
ORIGINAL: ptulmer
quote:
ORIGINAL: jerusha
Suggestions? Remember availability of replacement plugs, tools, etc.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.594RCU1
