RE: Postal Plane Project
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Postal Plane Project Page: <<   < prev  23 24 25 26 27 28 29 30 31 [32]
Login
RE: Postal Plane Project - 2/8/2010 10:25 PM  1 votes
Live Wire
Score: 5700
Last Login: 3/20/2010
Status: online
That just what I wanted to here.
Larry
< Message edited by Live Wire -- 2/11/2010 12:01 AM >
_____________________________
Larry K AMA 36417
WACO Brotherhood #34
Hide Signatures
(in reply to ndb8fxe)
       Post #: 776
RE: Postal Plane Project - 2/9/2010 1:18 AM  1 votes
Live Wire
Score: 5700
Status: online
Larry
Larry K AMA 36417
Hide Signatures
(in reply to Live Wire)
       Post #: 777
RE: Postal Plane Project - 2/11/2010 3:37 PM
dieFluggeister
Score: 102
Last Login: 3/8/2010
Status: offline
I just logged on to RCU for the first time in a couple of weeks and I just about fell off my chair! I am apparently not getting notifications of thread updates. Live Wire has obviously been real busy cutting wood and you Rcartf.co.uk as well for putting a site together. THIS is what I imagined when I started this project! I am going to get together all my files and pics from Grace and send them to you. I should have quite a bit of info in various formats so it may take a little bit to decipher. But, if you need something, or want it converted in a different format then drop me a line.
Where would you like the info sent? Would you prefer it be burned on a CD or sent over email?
My attempts so far for contacting Flybug for the original Grace have not gotten a response yet. I have contacted his club and I have a few more avenues so don't give up hope yet.
Mike Geister
'DieFluggeister'
New London, MN USA
Hide Signatures
(in reply to rcartf.co.uk)
       Post #: 778
RE: Postal Plane Project - 2/11/2010 3:46 PM
Live Wire
Score: 5700
Status: online
Well I had a good fire going but some one called the fire department, I am not really that good on the PC. and hell who knows I may get lost Maybe some one will take on grace after Chuck finds her MIA.
Larry
Larry K AMA 36417
Hide Signatures
(in reply to dieFluggeister)
       Post #: 779
RE: Postal Plane Project - 2/12/2010 2:36 AM
vicman
Score: 140
Last Login: 3/19/2010
Status: offline
Good to see you back Mike.
If you shoot me an email with as much stuff as possible I'll keep back-ups for you and future interested parties.
Hope things are going well for you.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
       Post #: 780
RE: Postal Plane Project - 2/13/2010 4:44 PM
Live Wire
Score: 5700
Status: online
Lesson learned
Can you believe shipping to places is more than the plane is worth, short hops are not bad. Last one left for Liberal Kansas
Larry K AMA 36417
Hide Signatures
(in reply to vicman)
       Post #: 781
RE: Postal Plane Project - 2/18/2010 10:51 PM
RR24
Score: 105
Status: offline
Got the plane from Live Wire, and we will see if we can make it a E-Grace.
Wes
Hide Signatures
       Post #: 782
RE: Postal Plane Project - 2/19/2010 3:36 AM
RR24
Score: 105
Status: offline
Here are some pics, just need to put in esc, and rx
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Wes
Hide Signatures
(in reply to RR24)
       Post #: 783
RE: Postal Plane Project - 2/19/2010 2:07 PM
Live Wire
Score: 5700
Status: online
Wes
You must have been off work Looking great
Larry K
Now for the maiden flight of the new plane.
Larry K AMA 36417
Hide Signatures
(in reply to RR24)
       Post #: 784
RE: Postal Plane Project - 2/19/2010 4:11 PM
dieFluggeister
Score: 102
Status: offline
I have set her up as a "Grace-E" before and it works well. The larger prop requires a little adjustment for torque but other than that I find it has great climb and overall good performance. Here is it running a BM-2408-21 swinging an 8x4 on 11.1v.
Click for fullsize
Hide Signatures
       Post #: 785
RE: Postal Plane Project - 2/19/2010 9:57 PM
RR24
Score: 105
Status: offline
quote:
ORIGINAL: dieFluggeister
I have set her up as a ''Grace-E'' before and it works well. The larger prop requires a little adjustment for torque but other than that I find it has great climb and overall good performance. Here is it running a BM-2408-21 swinging an 8x4 on 11.1v.
Well "Grace-E" sounds better than "E-Grace", so that whats she shall be if thats ok with you. The only thing i am not sure of, is will the motor i have be able to fly her. it is only about 70 watts at 7 amps. I was thinking of 2S 500 ma battery. mainly because i already have all of this, to try.
Wes
Hide Signatures
       Post #: 786
RE: Postal Plane Project - 2/20/2010 12:56 AM
dieFluggeister
Score: 102
Status: offline
70W should be adequate for trainer style flying. To fly at 7 amps though, I think your battery should be rated at 15C to be safe. Is that right all you lekky guys?
Hide Signatures
(in reply to RR24)
       Post #: 787
RE: Postal Plane Project - 2/20/2010 1:09 AM
rcartf.co.uk
Score: 100
Last Login: 3/15/2010
Status: offline
it's a bit tight on a 500mah @15c for 7ah. if this is static then it should drop when in the air, but i think i'd go at least 20c or 750mah to be on the safe side myself. then agian, i normally fly petrol so what do i know
http://www.graceusa.info http://www.graceuk.info
http://www.rcartf.co.uk
Hide Signatures
       Post #: 788
RE: Postal Plane Project - 2/20/2010 2:44 AM
RR24
Score: 105
Status: offline
the 500 is 20c, i also have a 900 ma and i think it is going to need it, it is tail heavy, the little motor is to light. it is going to weigh 12.5 oz with the bigger battery. I now have it ready to fly, but not good weather for a few days or week. Good job Larry
Wes
Hide Signatures
       Post #: 789
RE: Postal Plane Project - 2/24/2010 6:32 AM
airservices
Score: 100
Last Login: 2/25/2010
Status: offline
This is my latest project it is from uncle willies plans a cessna 180 with a .06 paw diesel up front
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to RR24)
       Post #: 790
RE: Postal Plane Project - 3/6/2010 3:31 AM
RR24
Score: 105
Status: offline
Larry, got a test flite acouple of days ago , it was a lttle windy for this little plane. it flew a little tail heavy, which is what it showed. I didnt want to add any weight, but i may have to.
Wes
Hide Signatures
(in reply to airservices)
       Post #: 791
RE: Postal Plane Project - 3/6/2010 4:34 AM
Live Wire
Score: 5700
Status: online
Wes
Just put some stand offs on the motor and move it out a little. Check the thrust angle of your motor. Once you get it set up it will fly OK.
Larry
Larry K AMA 36417
Hide Signatures
(in reply to RR24)
       Post #: 792
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
