crhammond
Joined: 8/31/2005 From: EdmontonAB, CANADA Status: offline
Success! My wife was kind enough to let me go out to fly yesterday morning (Mothers day!) since Saturday was a blow out. I still had a couple of issues with the range check but after routing the 2nd antenna out the top of the plane all was good. Dead calm, blue skies, nice and warm so up she went! The Panzl is FANTASTIC! It needed 0 clicks of anything to fly straight and level across the box. My CG is neutral - roll inverted on a 45 up line and let off the stick it just keeps going on that line with no pitching at all. Roll inverted and stay off the sticks and it flies level all the way across the box. No down elevator needed on down lines. Needs maybe a touch of right thrust for up lines (I'll probably mix that in the radio.) It is VERY responsive, that could be the CG. It’s not “pitchy” though – just sensitive. I am using much lower rates than the "low" rates - which is good because they were still too much for IMAC low rates. I may add a little more expo as everything is very powerful and tiny, tiny movements are needed around center. My rates are: Ail 20 deg up / 15 deg down (that’s almost axial – needs a little tweaking.) Elevator is 11 deg up and down, Rudder is maybe 25 deg which is too much The rudder and elevator have more authority than anything else I have flown - even the Cap. The rudder is even more effective than my composite Sukhoi which can do 540 deg hammerheads! It does KE with just a small deflection and stall turns are a breeze with no wobble coming out. At 25lbs 9oz (that's what I am at with a Weatronic Rx, no wheel pants, 5" Kavan tires and a PT 27x10 2-blade) "authority" is an understatement with a DA100 up front. It goes vertical at a steady pace at 50% + 1 click of throttle. 75% throttle and it rockets up, 100% and it's almost like a little electric park flyer on a fresh charge - Whoosh LOL!!! I should never get any 0’s for spin entries. To stall it the nose is pointed way up maybe 30 or 35 deg it stops and in the calm it just started to mush forward. The spins are nice – very axial and vertical with the plane rotating around the lower wing tip. Landing was okay. With no wind to help slow it down I went around a couple of times. When I did land I used the whole runway + about 1 inch. Just have to get used to it before I’ll be comfortable slowing it right down. I LOVE THIS AIRPLANE!!!
< Message edited by crhammond -- 5/14/2007 2:34:01 PM >
_____________________________
Wings Level.
