Old heim bell 222 project.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Scale RC Helicopters >> Old heim bell 222 project. Page: [1]
Login
Old heim bell 222 project. - 11/12/2006 6:14 PM
wa1emt
Score: 100
Last Login: 12/10/2012
Status: offline
Hey guys, long time reader first time poster.
I need some really sound advice as I am at a big wall I need to climb. Here it is:
I picked up 2 large old heim bell 222 fuse's at the sulphur fly in a week or so ago. I want to put some modern mechanics in her but have no clue what to use. THe manual ( or what I have of it ) is in german. This thing is very big. I really would like to use something I can get parts for here locally in Houston, Texas. I was going to opt for a raptor 60. THe stumbling block is the boom. I think any mechanics will work but its the boom length thats getting me. If I go with a belt and boom then it has to be right on the money. I was thinking about either flex drive or tail shaft type so that I can adjust it if needed to fit.
Has anyone had any experience with this type of fuse?. I just got done building the skid gear from brake line tubing and that worked great.
Any info that you can give would be most helpful. I went to century's site and their bell 222 will fit the raptor. But this isnt their bird and its 20 years old.
I plan on putting a remote glow system as well as remote start system in her.
Well, thanks for your time and Ill see what comes back.
William
Also, I would like any information in regards to a few other things, such as:
The little hindges for the doors, the best way to attach the mechanics and how to secure the top removable piece of the fuse once its completed to be able to have access to it.
I can however, give you guys the measurements from the german manual.
its 1450mm long, 220mm wide, 480mm height, states the main rotor could be 1400mm (700mm each) rear rotor blades are 140mm.
ANy help would be greatly appreciated.
Hide Signatures
       Post #: 1
RE: Old heim bell 222 project. - 1/9/2007 10:10 PM
RowdyBird
Score: 100
Last Login: 4/14/2007
Status: offline
You got my attention with the Vintage Fuselage's (old heim bell 222 fuse's ). WHAT a great find, glad you bought them.
SO far I don't have any bell 222 fuse's, but maybe someday.
So far I've got the old Kavan JR's and an OLD Agusta 109 Coast Guard, so can't help ya at all I'm afraid (sorry) .
Just wanted to wish you the best of luck, I'm sure you will get it all worked out in the end.
We are going through similar problems with ours as well, we are still very new with the Vintage fuse's and still learning.
Anyway, Good Luck with your project.
Hide Signatures
(in reply to wa1emt)
       Post #: 2
RE: Old heim bell 222 project. - 1/11/2007 6:08 PM
heli_Rod
Score: 100
Last Login: 10/2/2010
Status: offline
The Heim's were .60 powered helicopters. They were also top of the line in quality and price, so you never saw many around. I imagine that most modern .60 or .90 size mechanics may be adaptable to the scale fuselage. CCPM heli's would probably be easier to fit than a Raptor or Stinger type with the large collective arm they have since the 222 slopes down just forward of the swashplate. I am currently building a FunKey Bell 222 .50 size, using Stinger 50 mechanics. It is close on the collective arm, but plenty of room otherwise.
You might have to measure some different mechanics to see what would fit. No matter what you use, you can depend that it won't just drop in. My Hughes MD500 is a ThunderTiger kit that is made for raptors or Stinger 60/90's, but I installed my Minature Aircraft Fury Extreme mechanics in it. Lots of problems to overcome, but it's always possible....note that one of the cyclic servos is sticking out above the canopy....unless I cut the frame and moved it, that was a compromise I made.
Rod
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by heli_Rod -- 1/11/2007 6:10 PM >
_____________________________
AMA# 113287, Amateur Radio WA9H, Synergy N9, Fury Extreme 90, Stinger 50, T-REX 450SE V2, JR & Spektrum Radios
Hide Signatures
(in reply to RowdyBird)
       Post #: 3
RE: Old heim bell 222 project. - 1/11/2007 6:25 PM
heli_Rod
Score: 100
Status: offline
Something else I just remembered. The Heim's were shaft driven tail rotors as were about all .60 size heli's back then. If you go to belt drive mechanics, then you may also have boom length problems. At least with a shaft drive, you can alter the length if needed. Many also used a flex shaft drive on scale heli's that didn't have the tail rotor gear box in line with the drive output shaft on the main frame, but that shouldn't be a problem on the 222.
Rod
Hide Signatures
(in reply to heli_Rod)
       Post #: 4
RE: Old heim bell 222 project. - 1/12/2007 1:07 AM
RowdyBird
Score: 100
Status: offline
Thanks for the Tips Everyone, need all I can get.
Hide Signatures
       Post #: 5
RE: Old heim bell 222 project. - 1/12/2007 1:10 AM
wa1emt
Score: 100
Status: offline
Well, I had been away for a bit but I want to say thanks...i got 2 of these birds and I am selling one of them..As for the other..Still a work in progress..
Hide Signatures
       Post #: 6
RE: Old heim bell 222 project. - 1/21/2007 1:54 PM
111NELLY
Score: 100
Last Login: 5/10/2007
Status: offline
60 or 90 should do the trick with flexy tail drive.good luck.
Hide Signatures
       Post #: 7
RE: Old heim bell 222 project. - 1/22/2007 4:39 AM
wa1emt
Score: 100
Status: offline
Sorry all. Just wanted to let you all know that this bird is sold...thanks for all the info...
Hide Signatures
(in reply to 111NELLY)
       Post #: 8
RE: Old heim bell 222 project. - 1/22/2007 6:02 PM
111NELLY
Score: 100
Status: offline
never mind happy flying.
Hide Signatures
       Post #: 9
RE: Old heim bell 222 project. - 2/5/2007 9:19 AM
Rotor13B
Score: 100
Last Login: 3/4/2009
Status: offline
Never mind the bird (Just kidding!!) let me see that paddle in the window, lol.
< Message edited by Rotor13B -- 2/5/2007 9:20 AM >
Hide Signatures
       Post #: 10
RE: Old heim bell 222 project. - 2/10/2007 4:13 PM
heli_Rod
Score: 100
Status: offline
Ahhh...you mean the CW Bug? I scratch built that one and another for a friend about 22 years ago. I borrowed an original off a friend, took it apart and made blueprints so I could build one. Since I'm a machinist, it wasn't a problem to build at all. The hardest part was the spring steel it used for the oscillator. That took a little experimentation. I finally made them from a piece of banding strap, ground to the thickness that gave the same response as the originals.
If you have never used a "Bug", they are quite interesting and each has it's own accent, so to speak.
Rod
< Message edited by heli_Rod -- 2/10/2007 4:15 PM >
Hide Signatures
(in reply to Rotor13B)
       Post #: 11
RE: Old heim bell 222 project. - 3/7/2007 5:58 AM
heli_Rod
Score: 100
Status: offline
I posted earlier i this forum that I was building FunKey Bell 222 heli. Well..i'ts finally finished except for the side windows and I'll do that after I get all the testing and trimming done. It's always good to have some easy access to the mechanics.
So, here are a few pics of my 222 and a pic of the full scale I modeled it after.
Rod
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by heli_Rod -- 3/7/2007 6:19 AM >
Hide Signatures
       Post #: 12
RE: Old heim bell 222 project. - 3/7/2007 6:22 AM
Rotor13B
Score: 100
Status: offline
That heli is absolutely beautiful. Fantastic job!!!
Hide Signatures
       Post #: 13
RE: Old heim bell 222 project. - 3/29/2007 10:40 AM
Bing117
Score: 100
Last Login: 8/15/2008
Status: offline
Dear heli Rod,
CONGRATULATIONS on an amazing scale job - really beautiful. I am currently in the early stages of a 222 scale project based on a Darth fuselage for a Corona. My chosen model has a similar pattern of lines. Therefore, I should very much like to learn how you did the fine line part of the paint job on your model.
Best regards,
Bing117, Copenhagen, Denmark
PS: attached a picture of the full-scale I am trying to model and of my Corona before the beginning of the scale project.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 14
RE: Old heim bell 222 project. - 3/30/2007 3:29 AM
heli_Rod
Score: 100
Status: offline
It isn't difficult to do, but does require a lot of patience. The fuselage was painted white first with automotive basecoat/ clearcoat paint and wet sanded with 600 grit. The strips are all done with 1/8" (3.174mm) blue plastic automotive stripe tape made by 3M. The stuff is expensive, about $6 US a roll and it took about 1 1/2 rolls to complete.
I used a carpenters laser level to align the straight lines, using a soft pencil to put light marks as a reference. That helps a lot getting the lines straight and even. The curved lines are done just by looking at the pictures and trying to get them as close as possible. The spacing between the lines at the narrowest part is also about 1/8". I layed out all the trim lines with the 1/8" stripe tape before anything else was done. Take your time and if your not satisfied with the lines, pull the tape off and re-do them. This tape is quite flexible and easily goes around corners..however, try not to pull and stretch the tape. Allow it to follow the curves, gently pressing down as you apply the tape. The inside curves are where you will have the most problems. if you stretch the tape at all doing the inside corners, it will lift off the surface, allowing paint to get under the tape. I still had some lifting occur, but I used a very fine paint brush to touch up those areas after the colors were applied.
After the 1/8" tape has been completed, mask off any area you don't want to paint. You will have to do this for each color you apply. I had to mask mine 3 times. Again I use automotive materials (green masking paper and 3M 1/2" green low tack tape). I left all the 1/8" trim tape on the model until I finished the color paints. The color paints on my 222 are Createx or Fascolor water based paints, sprayed with an airbrush. After all the colors are applied, touch up any imperfections with a small brush. The model is then finished with clearcoat automotive paint.
I hope that helps a little,
Rod
Hide Signatures
(in reply to Bing117)
       Post #: 15
RE: Old heim bell 222 project. - 3/30/2007 11:04 PM
BarracudaHockey
Score: 280
Last Login: 5/17/2013
Status: offline
Dude! You just saved me I dont even know how much agrivation, I wouldn't have thought of that in a million years!!!
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 16
RE: Old heim bell 222 project. - 3/31/2007 12:06 AM
Bing117
Score: 100
Status: offline
Hello Rod,
Thank you for a most illuminative answer. I appreciate that - and I will try to follow your example.
Attached should be some brand-new pics. When my scale job is finished I shall present it here in the forum.
Best regards,
Bing117
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
