RE: Show us your Beaver!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Seaplanes >> RE: Show us your Beaver!
Page: <<   < prev  1 2 3 4 5 6 7 8 [9] 10   next >   >>
Login
RE: Show us your Beaver! - 5/27/2008 3:51:58 PM
khelsea
Status: offline
january 5th till today Maiden coming, Thanks for your help Rich Khelsea
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Warbird Man)
       Post #: 201
RE: Show us your Beaver! - 6/21/2008 11:34:38 AM
beaver180
Status: offline
Hi guys,
Well tomorrows the day my Beaver's Maiden, just land based at the mo. Hope all goes well.... Daughter choose the captain
Click for fullsize
Click for fullsize
_____________________________
Some Kiwi''s CAN fly, just not that good... like me!
(in reply to airportbum)
       Post #: 202
RE: Show us your Beaver! - 6/22/2008 8:07:14 PM
WA Flyer
Status: offline
Here are three of the many Beavers at the Spring float fly at Lake Shuswap this year. They are 22.5% scale at 129" span.
Click for fullsize
(in reply to beaver180)
       Post #: 203
RE: Show us your Beaver! - 6/23/2008 12:08:38 AM
beaver180
Status: offline
Hiya Randy,
Well I finally flew it... Day was a bit crappy but.
Had it all balanced at the 80mm from LE mark ( no fuel, of course ) and throws as manual, running a Saito 180 four stroke with a MAS Classic 18x8 prop.
Flight was a little disappointing apart from the quick take-off, Engine way more powerful than was needed as only 1/2 throttle used. The turns needed heaps of rudder and she climbed like an elevator with more throttle on.
Think I need more ( 2mm thick washer ) down thrust to fix the power up, plane go up trimmings
About the turns... I definately will be adding some aileron - rudder mixing, and do you guys think aileron differential would help too???
What do you guys think??
Cheers,
Paul
Click for fullsize
Click for fullsize
(in reply to cgcrc)
       Post #: 204
RE: Show us your Beaver! - 6/23/2008 6:23:54 PM
Didg
Status: offline
I would get the engine thrust line sorted out first.
Once you have your down thrust sorted, check the side thrust by flying vertical (sounds like you have the power ) then watch for deviations as it slows down. If it veers left add right thrust and vice versa.
Then check lateral balance by flying a reasonably tight loop (one only). If it comes out right wing low shift weight to the left or add weight to the left wingtip.
Having done all that see how it flies.
It is a scale model, and coordinated turns are what you would have to do in the full size as I'm sure you are aware.
I have a 1/4 scale Super Cub that could do with aileron differential and aileron to rudder mix, but I prefer to fly it as per the full size.
I find it more fun and more of a challenge. It's personal preference though.
Having said that, if the adverse yaw is particularly bad, then it will not be much fun to fly.
To check for this, fly a 1/2 roll in the vertical. Best to do this by flying towards yourself then pull to vertical, do a 1/2 roll. If heading veers left after a right 1/2 roll, it needs increased aileron differential.
Good luck and let us know how you get on.
Didg.
WACO Brotherhood #52
       Post #: 205
RE: Show us your Beaver! - 6/23/2008 6:29:07 PM
Didg
Status: offline
Oh, btw.
Choosing not to add aileron to rudder mix and working your left thumb a bit more, dosen't take that long to get used to and it will make you a much better pilot.
Didg.
(in reply to Didg)
       Post #: 206
RE: Show us your Beaver! - 6/25/2008 6:41:02 PM
pjhobbies
Status: offline
I too fly beavers but smaller than most of you... mine are all heavily modded GWS beavers but I will be starting on a new KMP electric beaver shortly... surprised the new 68" KMP electric hasnt been mentioned yet.
Just to answer the inevitable questions: Glass covered, Horizon supercub wing and a custom heat shrunk pop bottle cowl
Click for fullsize
< Message edited by pjhobbies -- 6/25/2008 6:42:33 PM >
(in reply to khelsea)
       Post #: 207
RE: Show us your Beaver! - 6/25/2008 8:15:29 PM
beaver180
Status: offline
Many thanks for your replies Didg...
I don't have an incidence meter for doing the engine thrust, so I have added washers ( 2mm thick ) to the tops of the engine mounts. Pretty sure I have set up the aileron differential right... less aileron down, ie full left aileron turn has left aileron fully up and the right aileron has about half of it.
I have also added more weight to the nose, bringing the CG forward around 5mm.
Got some mixing to the rudder done but on a switch so I can turn this mix off and learn like you suggest to use my thumb.
Anyone using the FEMA Onboard Starters??? or is it easy enough to make your own for cheaper?? Though it'll make useful nose weight seeing as I need quite alot.
Hope to re fly with these alternations the next day or so.
pjhobbies...
Yes am surprised too not a mention of the new electric KMP Beaver, The KMP electric Beaver is showing a 59" Wingspan... where as the E-flite electric Beaver is the 68 inch one. I think I'd actually prefer the E-Flite 68 inch Beaver as it's bigger and has a more pleasing ( to me anyways ) colour scheme
Chow for now, Paul
(in reply to Didg)
       Post #: 208
RE: Show us your Beaver! - 6/27/2008 5:21:18 PM
khelsea
Status: offline
OK Maiden flight accomplished! Went well, put in 30% rudder mix with 3/4 in up with 1/2 in down on the ailerons, was the right combination. Full flap landing was sweet! Great flying airplane
Unionville Turbo Beaver
96 in Span
11 1/2 lbs
Thunder Tiger 91 4 stroke
Brodak dope w/ solartex
Mods wing tube, aluminun struts, removable TNT landing gear, pull pull rudder, Ohio tailwheel assy, drop tips, corrigated surfaces
Now on to the floats!! Thanks to everyone that contributed especially Bald Eagle, great tips
Khelsea Lanny
       Post #: 209
RE: Show us your Beaver! - 6/27/2008 11:41:14 PM
Baldeagle
Status: offline
Way to go Lanny. We got to have pic too. Rich
Rich
       Post #: 210
RE: Show us your Beaver! - 6/28/2008 8:32:17 AM
basman
Status: offline
Here are some pic's..... efite beaver converted saito FA 56
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 211
RE: Show us your Beaver! - 6/28/2008 5:57:23 PM
Didg
Status: offline
I like.
How easy was it to convert to glow, any major problems, balance etc.
I wish H9 would make a big version of this, 1/5th scale or somwhere around that (1.20 size) in blue preferably.
(in reply to basman)
       Post #: 212
RE: Show us your Beaver! - 6/29/2008 9:45:09 AM
basman
Status: offline
No majar problems, balance was perfect nose slightly down when held on cg. Here are some pics of the first set up. bad landing in a creek bed popped fire wall so thewn shifted the wall back 28mm, inproved access to glow plug, will ppost some pic's when I get some.
Click for fullsize
Click for fullsize
(in reply to Didg)
       Post #: 213 <
