RE: Buiding pics Waco YMF-5 Barth Modellbau
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Buiding pics Waco YMF-5 Barth Modellbau
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/2/2007 9:41:05 AM
redcesar
Status: offline
Yes I now wat you mean I think it is for major adjust on the real Waco , i have also seen it on a lot of pictures.
I have made the stab only removable (see earlier pictures), i think if you made the first sadle adjustable in height you are close to the solution.
Cesar.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to BigBoy99)
       Post #: 51
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/6/2007 2:22:10 PM
redcesar
Status: offline
The two fairings on the fuse/wing are put in place and the folie is covering on the fuse.
Cesar
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to redcesar)
       Post #: 52
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/8/2007 7:30:33 AM
Alexzzz
Status: offline
I've seen this project in real, and it's going to be a very nice looking plane
Keep up the good work Ruud!
Greetz.
_____________________________
TX: T14MZ. Flying: Giant Scale 3D.
       Post #: 53
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/10/2007 10:45:51 AM
redcesar
Status: offline
Thank you Alex, i will try to keep the spirit up.
I have finished the panels on the fuse. i think that after the paintjob it looks better, the screws are now to much visible.
Cesar.
Click for fullsize
Click for fullsize
< Message edited by redcesar -- 2/11/2007 5:57:18 PM >
(in reply to Alexzzz)
       Post #: 54
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/10/2007 7:46:32 PM
BigBoy99
Status: offline
Hi Cesar,
Compliment, your plane looks "GREAT"!!!
Which Covering material do you use? And is it easy to handle?
In my opinion the screwheads will get more in the background after painting, same mind like you!
What kind of paint are you planing to use,1K or 2K ?
I have to wait two weeks more, until I will recieve my kit, so told me Peter Barth
I´ve gived up my plans, to make the stab pretendable, because of reasons of stability.
What´s a Servo is it, in the rear of the cockpit?
Regards
Bernie
Waco Brotherhood #63
       Post #: 55
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/10/2007 8:18:45 PM
BigBoy99
Status: offline
quote:
ORIGINAL: SoCalSal
I used a HiTec 5955 digital that puts out 333oz @ 6 volts. .................. Cost is about $96 U.S. each.
If you have any questions , please let me know and I will try to help.
Steve
Be glad Steve, this Servo costs here in Germany 117€, nearly 150 USD !!!!!!!
I will use 4 Hitec HS-645MG, one for every aileron.
Bernie
(in reply to SoCalSal)
       Post #: 56
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/11/2007 2:32:54 AM
SoCalSal
Status: offline
Well one servo on each will be very good. I'm sorry that the 5955's cost so much in Germany. That just seems unfair to you over in Germany to have to pay almost two times the price for the same thing. there may be a way to order them here in the States and have them shipped to your home for far less than buying them from a German hobby supplier.
Steve
Let''s be open minded.... But not so open that your brain falls out
       Post #: 57
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/11/2007 10:07:41 AM
redcesar
Status: offline
quote:
ORIGINAL: BigBoy99
Regards
Bernie
Hi Bernie,
The covering material is Oratex it is a polyester fabric and it is verry easy to aply.
Look at http://www.oracover.de/xml/frames.xml?onav=onav.xml?node_id=273&site=site_blau2.xml?node_id=273&lanav=lanav.xml?node_id=273
I wil use 1K paint, that's a litle bit easyer for me to use. The color i wil be use is RAL 9001. I have not the possibility to spray the the paint so iI wil be use a felt roller.
I hope for you that you not have to waite to long for your Waco, let me now when you recieved it.
The servo's I wil be used are the 645MG and the 755HB for rudder.
You say"not pretendable" okee but for transport it is better to make it removable I think.
Regards,
Cesar.
       Post #: 58
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/11/2007 4:15:34 PM
BigBoy99
Status: offline
Hi Ruud,
thanks for your quick reply. Oratex is also the material I want to do the covering, I see, I had a good choice
I think. the HS 755HB is a little bit too small for the rudder and elevator. Elevator is the most important rudder in the model,
and if you loose the elevator, you loose the model!!!! I would recommend the HS 5745, for the elevator and the rudder.
It has a power of nearly 19 Kg!!! But this is only my opinion. If anybody else think otherwise.....post!
Or the HS 5955´s, but they are more expansive
I prefer a color, something between RAL 1018 and RAL 1023, I´m a yellow fan.
Chuck sent me the the dwg files for the decals, thanks to him...good fellow Thanks to him!
Now I wish you for the rest of the weekend best success for your work
Bernie
       Post #: 59
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/11/2007 5:17:13 PM
SoCalSal
Status: offline
Bernie, You say you like yellow?? Here is my Yellow Waco.
Steve
Click for fullsize
Click for fullsize
       Post #: 60
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/11/2007 5:54:40 PM
redcesar
Status: offline
Hi Bernie
I wil work with 6 V on the servo's. the 755HB is than 13,2 kG.
I wil use for the elevator two servo's, for each flap one servo that's a total of aprox. 21 kG. I dont no if you wil use two servo's on the elevator?
Cesar.
       Post #: 61
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/11/2007 6:39:17 PM
BigBoy99
Status: offline
Hi Steve,
IT LOOK´S GREAT, compliment !!!
Is it you, on the photo?
Yes, I like yellöw, but I prefer more Yellow with red
@cesar
Thats good, it´s a solution, if one servo failure, you have a second on the other flap.
but in this case, I think so, it works like a little aileron and you have to steer against with the ailerons?
Greeetz to both and all
Bernie
       Post #: 62
RE: Buiding pics Waco YMF-5 Barth Modellbau - 2/12/2007 2:23:57 AM
