Semi Retired Aviator
Joined: 9/20/2003 From: Melbourne Victoria, AUSTRALIA Status: offline
Now this may seem like a dumb question, but sometimes the human brain gets in a loop and can't see a way out; a little like not being able to see the methanol for the nitro. As a general rule, do high compression engines require more or less nitro than low compression engines?? What's the answer? If an engine detonates when using, say, 15% nitro, that can be reduced/eliminated by reducing the compression by putting a shim under the head, but that doesn't mean that lower compression engines REQUIRE higher nitro. It just means that detonation will be less if you lower the compression for a given % nitro. My understanding was that the lower compression, the higher nitro content required, but now I'm not so sure, e.g. YS 4 strokes are high compression, but they run best on 15-30% nitro, and 30% nitro is a high content. Detonation can be a problem if you're not careful. I thought that nitro was similar to ether in diesel fuels, that is, it assists in getting combustion started, and is therefore most beneficial in a low compression engine. Diesels have high compression, and in theory, therefore, shouldn't require ether to assist combustion starting, but let's leave diesels out of this for now. Somebody give me the facts, as I've seen a lot written that would suggest both sides of this argument/discussion are valid, including on these forums.
< Message edited by Semi Retired Aviator -- 11/13/2006 6:08:45 AM >
_____________________________
Giver her some more power.......She won't take any more!
