RE: Don Smith A-26
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Don Smith A-26
Page: <<   < prev  1 2 3 4 5 6 7 [8]
Login
RE: Don Smith A-26 - 6/10/2008 12:41:38 AM
wingspar
Status: offline
I'm back working on this beast. I'm going to leave the wing center section for now and work on the nose. I need to try to detail the interior as best as I can do. I've never done this before but I'll do my best. Then make the molds for the clear nose section and vacuform them. I've never done this either so it should be a good learning experince.
For those who might be interested I found a great website for the A-26 with alot of pics I've never seen before.
http://napoleon130.tripod.com/index.html
more pics to follow shortly.
Dave
(in reply to Slowjohn)
       Post #: 176
RE: Don Smith A-26 - 6/10/2008 1:08:52 AM
Ichy
Status: offline
Glad your back Dave. Can't wait to see an update!
(in reply to wingspar)
       Post #: 177
RE: Don Smith A-26 - 6/12/2008 2:29:54 AM
wingspar
Status: offline
I got the basic nose section framed in. I just need to seal the wood, prime and paint it with paint I've ordered from Warbircolors.
Then construct the mold in my attempt to make my own nose glass section.
Dave
Click to see fullsize image.
Click for fullsize
(in reply to Ichy)
       Post #: 178
RE: Don Smith A-26 - 6/13/2008 12:34:28 AM
Ichy
Status: offline
Nice! Even got the crawl-through to the pilots cockpit! What gear are you using? I am using CJ. The steering servo will be right in the middle of mine. Highly visible.
       Post #: 179
RE: Don Smith A-26 - 6/13/2008 2:09:10 AM
Eric Brathwaite
Status: offline
Just back from a long vacation and read about your lost; My condolence and regards to you and your family. On the other hand, glad to see you back at work.
_____________________________
Eric B.
(in reply to Ichy)
       Post #: 180
RE: Don Smith A-26 - 6/13/2008 2:53:24 PM
wingspar
Status: offline
Ichy; I still want to put some detail on the opening hatch and was thinking of making it funtional but deceided against it as I would like to fly this one of these days and get onto another projects.
The gear is Sierra and it will be fully hidden with the steering control mounted just inside the bomb bay with the cables running just under the cockpit floor.
Thanks Eric.
Click for fullsize
Click for fullsize
(in reply to Ichy)
       Post #: 181
RE: Don Smith A-26 - 6/15/2008 3:11:24 PM
wingspar
Status: offline
I made the top glass nose section out of 1/4" balsa and pink foam. I glued the pink foam in rather large blocks to the balsa form. I first tried to trim it with a sharp knife. Not alot of success. The blade kept getting stuck. Then I tried 50 grit sand paper. Could be done but this would take a week. Then I tried a thin 1/5" piece of brass heated on the gas stove. This worked ok but got the house stinky. Then I got the idea of using the electric knife and voila, success. It allowed me to trim it very close to its final shape. Alittle fine sanding and some filler and it's done. It also made it slightly undersized to compensate for the fiberglass top coat and the plastic itself. Note to self.. when using things from the kitchen insure wife is not at home.
Fiberglass it and make a vacuum box and see if it works.
Click for fullsize
Click for fullsize
< Message edited by wingspar -- 6/15/2008 3:13:34 PM >
       Post #: 182
RE: Don Smith A-26 - 6/16/2008 5:08:25 PM
Ichy
Status: offline
Looking good Dave! I'll be playing catch-up here before too long.
       Post #: 183
RE: Don Smith A-26 - 6/21/2008 2:28:39 AM
wingspar
Status: offline
I got the bottom part done on the glass nose section. The plastic has arrived and I should be able to pull a nose section by next week. I also got the inside sealed and primed and will add a few more details before spraying it.
Dave
Click for fullsize
(in reply to Ichy)
       Post #: 184
RE: Don Smith A-26 - 6/21/2008 2:50:22 AM
Slowjohn
Status: offline
Really looking good there Dave. I'm looking forward to seeing how your nose cone turns out. I got my molds made, just need to clean them up some more. The 1st pour didn't turn out so good so I tried again and they came out okay. Then a few weeks back the wife called me from a yard sale saying they had some compressors. Turns out one of them was a medical vacuum pump so I'll be making a set up to make my own canopies now. Thanks for the offer, I sure appreciated it.
Thanks Again &
Standing By,
SJ
       Post #: 185
RE: Don Smith A-26 - 7/17/2008 4:35:48 PM
Ichy
Status: offline
Dave, I found this photo of the underside of an A-26 for detail.
http://www.flickr.com/photos/si558/2672207012/sizes/o/
I have reinstalled the tail group back on mine. I had to cut a large hole in the fuse to do this, as well as redo the linkages for the rudder and elevators. I need to plank that hole up and then it's time to install the main gear. Our club is having a scale fun fly on the 26th and I intend to get it out into the sunshine and show it off!
       Post #: 186
RE: Don Smith A-26 - 7/17/2008 6:38:44 PM
Slowjohn
Status: offline
quote:
ORIGINAL: Ichy
Very nice shot indeed!!!
SJ
(in reply to Ichy)
       Post #: 187
RE: Don Smith A-26 - 7/20/2008 4:29:24 PM
FliteMetal
Status: offline
quote:
ORIGINAL: aubreyinhouston Has anyone used or Considered using FLITE-METAL Aluminum Covering from flitemetal.com on your A-26?
I overlooked this inquiry when originally posted. Enjoy the pix... : ) http://004edc4.netsolhost.com/FliteMetalimages/clare_reeseys_a26.htm
Clair Reesey's A-26 Invader:
< Message edited by FliteMetal -- 7/20/2008 4:37:50 PM >
Ed Clayman
http://www.FliteMetal.com
(in reply to aubreyinhouston)
       Post #: 188
RE: Don Smith A-26 - 7/20/2008 5:05:12 PM
wingspar
Status: offline
Just got back today from a business trip.:-)
Great shots of the underside!!!. Thanks Ichy.
Darell........ WHERE ARE MY WHEELS AND BRAKES????????
Ed, it's amazing what can be done with your fine product. Anybody know where he got that pilot??
Dave
(in reply to FliteMetal)
