modestone
UT, USA Status: offline
Wow! I have been trolling the forums here for a few days, and have read ALOT of your posts poor judgment. I feel honored to be of assistance. Yea the Magnum NX (and the MT Spec 3.0) come with the NX 3.0 .18 motor. Seems to be a pretty good little motor, but I have no real experience owning anything else. I guess my main thing is the whole "allegedly dealt with" thing. I have yet to find any direct comparison of specific parts that were known to be lacking. It's the small things I am wondering about. Is there anything in specific I would be able to check and report back to you guys here, as far as something that *should* have been changed? I can take all the pictures needed, measure things, whatever. Keep in mind, my rc terminology is still being developed The terrain I will be mostly using this in, is anything but forgiving, so I am looking toward any strengthening modifications I can. Really the only thing I have noticed as taking on some wear immediately are the two aluminum gears from the clutch (pinion gears?). After breaking it in, and having some initial bashing, I found that they had taken more damage then the plastic ones did. I assume it was either from the gravel parking lot I was ripping to shreds, or the very hard, sharp and pokey, desert plant that got ran over and sucked up into the gears, locking them up. I know now to avoid them like the plague, and I also think I would like to cover up the hole under the gears in the aluminum. Why are there holes under the gears and flywheel anyway? The plant ordeal was not really a problem though, just pulled it out and all was good.
< Message edited by modestone -- 11/16/2006 1:07:28 AM >
