RE: carden 35% 260 liftoff
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: carden 35% 260 liftoff
Page: <<   < prev  1 [2] 3 4 5 6 7   next >   >>
Login
RE: carden 35% 260 liftoff - 12/4/2006 7:20:27 PM
jmiracle
Status: offline
Carden is awesome as usual. I already received an email from Caroline informing everyone on the run of the correction. She even sent an addendum of the change and requested a response back to confirm you received the update!
Awesome customer service...
Mine should be here tomorrow....can't wait!!
(in reply to Bobt2)
       Post #: 26
RE: carden 35% 260 liftoff - 12/4/2006 9:25:37 PM
as722
Status: offline
looking good Bob, can't wait to see it .
Albert
_____________________________
Carden Aircraft
(in reply to jmiracle)
       Post #: 27
RE: carden 35% 260 liftoff - 12/5/2006 1:52:42 AM
Bobt2
Status: offline
albert i started bagging last night, guess ill do a part a night. the wing cores get here tomorrow.
(in reply to as722)
       Post #: 28
RE: carden 35% 260 liftoff - 12/6/2006 2:13:44 AM
Bobt2
Status: offline
just a few shots of the bagging process. even tho its not needed i still use a few weights on top to hold the top shuck in place. you can see how tight the bag holds the parts. any shape can be bagged.with the lighter carden foam i,ve reduced the bag pressure to 5 hg. down from the 7 i use to use. i leave each part in the bag for 24 hrs
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Bobt2)
       Post #: 29
RE: carden 35% 260 liftoff - 12/6/2006 2:16:55 AM
Bob101
Status: offline
I've never bagged but I helped a friend do it for his first attempt...I see you added weights too - that's what we should have done because everything came out fine except the hatch curled a little on us.
(in reply to Bobt2)
       Post #: 30
RE: carden 35% 260 liftoff - 12/7/2006 2:42:45 AM
RobT
Status: offline
Bob,
The weights are just for insurance as you pull down the vacuum. Once the vacuum is down in theory you can hang the part up and clear your workbench.
I say in theory as I have seen this done is a pro shop where they had rows of wings hanging in vacuum, but I never had the guts to try it myself. I always leave the bag on the bench (and leave the weights on It wont hurt...)
(in reply to Bob101)
       Post #: 31
RE: carden 35% 260 liftoff - 12/9/2006 2:38:16 AM
kevinc
Status: offline
Christmas came early, I recieved my plane today in all its non flyable form. Wow theres alot of parts. Keep the pics coming guys I will need all the help I can get. Can't wait to get started.
Kevin
(in reply to RobT)
       Post #: 32
RE: carden 35% 260 liftoff - 12/9/2006 2:47:55 AM
Bobt2
Status: offline
anything you need, just ask. pm or e-mail if needed
(in reply to kevinc)
       Post #: 33
RE: carden 35% 260 liftoff - 12/9/2006 3:17:19 AM
Scoubidou
Status: offline
Hi Guys
I have 2 super ZDZ80RVJ and i was wondering if there is enough room to slide a tuned pipe under the wing tube, into the fuse?
The pipe dimensions are 680mm long (without header) by 59mm diameter.
Daniel
Seneca Engineering
http://www.seneca.ca/
(in reply to Bobt2)
       Post #: 34
RE: carden 35% 260 liftoff - 12/9/2006 12:35:31 PM
Bobt2
Status: offline
if your talking about a zdz super 80 in the carden, forget it! i own a super 80 and its a great engine, but it just wouldn't cut it in here. you really need the 100 because of the weight.
(in reply to Scoubidou)
       Post #: 35
RE: carden 35% 260 liftoff - 12/9/2006 1:06:47 PM
Scoubidou
Status: offline
It depends of the final weight. If it's possible to built it at 25 lbs, the super ZDZ80 would be OK with a tuned pipe.
(Mejzlick 27x10 at 6400-6500 RPM, with a tuned pipe)
Seneca Engineering
(in reply to Bobt2)
       Post #: 36
RE: carden 35% 260 liftoff - 12/9/2006 2:47:04 PM
Bobt2
Status: offline
you also have to realize the carden is a big plane, probably the biggest 35% out there. the 80 will just fly the plane. in the summer heat there will not be any vertical to speak of.
       Post #: 37
RE: carden 35% 260 liftoff - 12/9/2006 3:31:08 PM
jmiracle
Status: offline
Scoubidou,
The Super 80 on a tuned pipe would be plenty of power for a 35% of this size....if you keep the weight down. I fly with a guy who has one...and I know on a pipe they make just about the same power as a good 100 on regular muffs.
I think you'd likely end up around 26lbs with the 80 in a Carden unless you swiss-cheesed the sides and foam parts to really knock out some weight....25 may then be possible. It won't have ballistic punch-out, but it should be more than enough.
But the biggest hurdle will be installing a long tuned pipe in the fuse. There's plenty of room under the wing tube, but once you move behind the motor box, you have the fuse truss structure to deal with. At the point where the truss structure meets the back of the motor box, there's only 2.5" of clearance....the bottom foam deck then tapers to meet the truss structure at the tail wheel. The motor box is 20" long from the firewall to the back plate. There's about 7-8" of room under the wing tube...just remember the truss structure splits this space in half just a couple inches behind the tube.
If you're willing to notch the bottom foam out to clear the pipe (basically running the pipe exposed), then you might be able to make it work.
(in reply to Bobt2)
       Post #: 38
RE: carden 35% 260 liftoff - 12/9/2006 4:42:36 PM
as722
Status: offline
I think the bigger question is will it balance with the 80cc ?
Albert
Carden Aircraft
       Post #: 39
RE: carden 35% 260 liftoff - 12/9/2006 6:23:34 PM
imacflyr3
Status: offline
I'd be interested in the balance issue as well. I've got a BME 115 on the way and am contemplating getting this airframe. Would this motor just be too light.....if that's even possible?
gh
(in reply to as722)
       Post #: 40
RE: carden 35% 260 liftoff - 12/9/2006 11:21:28 PM
as722
Status: offline
quote:
ORIGINAL: imacflyr3
gh
yes it is possible, any airplane needs x amount of weight to balance. The 115 is a great engine I'm sure but you'll probably have cg issues specially with stock mufflers.
Albert
Carden Aircraft
(in reply to imacflyr3)
