RE: carden 35% 260 liftoff
Tower Hobbies
Logged in as Guest
  Printable Version
C-130 Hercules 108" span Gas or Electric! - Kit
Seller:  penceaviation
Details:   $245.00   |  8/4/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: carden 35% 260 liftoff
Page: <<   < prev  1 2 3 4 5 [6] 7   next >   >>
Login
RE: carden 35% 260 liftoff - 5/6/2007 2:54:19 AM
Scoubidou
Status: online
Thanks for the photos Bobt.
There is plenty of room to fit tuned pipes in that plane.
I have looked at the 35% Dalton and i prefer to go with Carden even it's not scale. The Carden plane looks like a big pattern plane with its strechy tail moment.. It might explains why they fly so good?
Daniel
_____________________________
Seneca Engineering
http://www.seneca.ca/
(in reply to Bobt2)
       Post #: 126
RE: carden 35% 260 liftoff - 5/13/2007 1:22:50 PM
RobT
Status: offline
I took Dad's 35% 260 through the Unlimited Sequence again this weekend, and then played some 3D with it. If I had to go back to a 35% due to cost / transportation I would order one of these in a second and not look back. It would be competitive in any class no questions asked. It goes though a sequence faster than a 40%, however it does it as smooth and easy. Rollers seem easier with this than with my 40% 300 . . . Is that setup ? ? If so where??
(in reply to Scoubidou)
       Post #: 127
RE: carden 35% 260 liftoff - 5/13/2007 3:25:24 PM
Scoubidou
Status: online
Hello robt
Thanks for the IMAC flight review. Can you do the unlimited sequence under 50% throttle with the DA-100 on canisters or you need to play in 75%-100% throttle for specific figures like vertical snaps for those windy days?
Daniel
Seneca Engineering
(in reply to RobT)
       Post #: 128
RE: carden 35% 260 liftoff - 5/13/2007 3:38:41 PM
RobT
Status: offline
Dan,
The real question will be how much throttle will be needed on a hot summer day! But as of now at sea level on a 70 degree day I think I could go through unlimited with a 70% restriction on throttle.
Rob
       Post #: 129
RE: carden 35% 260 liftoff - 5/13/2007 3:45:28 PM
Scoubidou
Status: online
Well, no need for tuned pipes in that plane I'll go with canisters .
Daniel
Seneca Engineering
(in reply to RobT)
       Post #: 130
RE: carden 35% 260 liftoff - 5/13/2007 4:03:45 PM
Bobt2
Status: offline
heres a picture of it on the flight line sitting next to my reconditioned 40% 330
Click to see fullsize image.
Click for fullsize
       Post #: 131
RE: carden 35% 260 liftoff - 5/14/2007 5:41:52 PM
zzw26n
Status: offline
sweet looking ............
(in reply to Bobt2)
       Post #: 132
RE: carden 35% 260 liftoff - 5/27/2007 1:37:58 AM
Bobt2
Status: offline
latest update, somewhere between 40-50 flights. still pulls to the canopy on long uplines so i,m going to increase to downthrust even more and i,m going to try moving the cg back a little so i need less down when inverted. still very pleased with the plane. they say it takes 100 flight to really trim it just right.i,m starting to believe it!
(in reply to Bobt2)
       Post #: 133
RE: carden 35% 260 liftoff - 5/27/2007 2:16:24 AM
Scoubidou
Status: online
I know what mean. Most of pilots do not take the time to trim their planes and fights againts it to fly straight. Only IMAC fliers understand how it's important to get a trimmed plane to fly good sequences.
Daniel
Seneca Engineering
(in reply to Bobt2)
       Post #: 134
RE: carden 35% 260 liftoff - 10/3/2007 12:54:46 PM
Scoubidou
Status: online
Hi guys
I am building mine and the recommended ailerons dimensions are HUGE with 5'' 3/4'' at the root and 4''1/2 at the tips. Are they overkill or may i reduce it to 5'' a the root and 4'' at the tip?? I'll fly mostly IMAC.
Daniel
Seneca Engineering
       Post #: 135
RE: carden 35% 260 liftoff - 10/3/2007 5:13:04 PM
swk550
Status: online
I used straight ailerons at approx. 4.75 in width. The straight ailerons have an almost constant thickness at the hinge line. I did not need any matchboxes for the two aileron servos.
swk550
Click for fullsize
       Post #: 136
RE: carden 35% 260 liftoff - 10/3/2007 8:20:10 PM
Scoubidou
Status: online
Nice color scheme!
Seneca Engineering
(in reply to swk550)
       Post #: 137
RE: carden 35% 260 liftoff - 10/4/2007 12:03:32 AM
RobT
Status: offline
Do not second guess Dennis . . . just use less throw.
       Post #: 138
RE: carden 35% 260 liftoff - 12/15/2007 3:17:59 PM
Scoubidou
Status: online
Hello
I decided to go with taper ailerons 5 3/4 at the root and 4'' at the tip.
One 3/8'' balsa sheet do not allow more than 40 degres throw on the ailerons. Did you use 2 sheets to get more throw or is 40 degres enough for IMAC and 3D?
Daniel
Click for fullsize
Seneca Engineering
(in reply to RobT)
       Post #: 139
RE: carden 35% 260 liftoff - 1/21/2008 5:26:01 PM
Bobt2
Status: offline
i havn't checked in in a while, working on my 40%300. no, you do not need
