RE: Top Flite Cessna 310 posted    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Top Flite Cessna 310 posted
Page: <<   < prev  114 115 [116] 117 118 119 120 121 122 123   next >   >>
Login
RE: Top Flite Cessna 310 posted - 5/14/2009 11:11 PM
Pete737
Score: 105
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: MMallory
Pete,
Go with the twin sync. It gives you onboad glow drivers, engine out warning and the cool sound of perfectly sync'd engines.
It includes onboards glows too?? That's awesome!
Ill look into it right now!
Thanks! Pete
_____________________________
Life is too short to not have the right jets..
Hide Signatures
(in reply to MMallory)
       Post #: 2876
RE: Top Flite Cessna 310 posted - 5/15/2009 7:47 AM
RADCON
Score: 100
Last Login: 10/19/2012
Status: offline
Ther is one in Towers S&D, Missing right wing and fuse.
Hide Signatures
(in reply to cstevenpeterson)
       Post #: 2877
RE: Top Flite Cessna 310 posted - 5/15/2009 3:39 PM
cstevenpeterson
Score: 105
Last Login: 5/24/2013
Status: offline
I did see that one. If it had the entire wing I would have purchased it.
Steve
Hide Signatures
(in reply to RADCON)
       Post #: 2878
RE: Top Flite Cessna 310 posted - 5/15/2009 10:22 PM
Pete737
Score: 105
Status: offline
Picking up servo's today, Do you think I should go digital?
Thanks! Pete
Hide Signatures
       Post #: 2879
RE: Top Flite Cessna 310 posted - 5/16/2009 4:54 AM
Pete737
Score: 105
Status: offline
Anyone notice that in the instructions it shows the hole to insert the wing bolt on the right wing, It also mentions it a few times, My ARF has the hole in the left wing
Pete
Hide Signatures
(in reply to Pete737)
       Post #: 2880
RE: Top Flite Cessna 310 posted - 5/16/2009 5:57 AM
n6iap
Score: 100
Last Login: 5/17/2013
Status: offline
Not as a recommendation but what I did -> I had some Spektrum DS821's (72oz-in) digital servos that I used for everything except the JR NES-537's on the throttle. The throttle should not be an issue and they are 40 oz-in as recommended. That leaves money for the TwinSync, retracts, strobelites, etc. If anyone has other ideas or reasons why I may regret my decision I would like to hear it.
< Message edited by n6iap -- 5/16/2009 5:59 AM >
The two most useless things a pilot has; the runway behind you and the altitude above you.
CORSAIR Brotherhood # 71 / Club Saito Member #704 / Waco Brotherhood#205
Hide Signatures
       Post #: 2881
RE: Top Flite Cessna 310 posted - 5/17/2009 3:30 AM
Pete737
Score: 105
Status: offline
Does the retract kit come with everything you need? (airlines, tank, fittings, valves)
Thanks, Pete
Hide Signatures
(in reply to n6iap)
       Post #: 2882
RE: Top Flite Cessna 310 posted - 5/17/2009 7:58 AM
orygg
Score: 100
Last Login: 10/14/2012
Status: offline
 Hi robart retract kit dont  come with everything, you need airlines, tank, fittings, valves+++ best regards olav
Hide Signatures
       Post #: 2883
RE: Top Flite Cessna 310 posted - 5/17/2009 8:22 AM
Pete737
Score: 105
Status: offline
Thanks Olav.
To anyone who used Saito 82's, I don't have mine yet but ones shipping from CO this week and the others at my LHS, So Ill have them by this weekend. Im curious, Did you mount the throttle servos per the instructions? Looking at a pic of the saito 82 it looks like I'll have to drill my own throttle hole through the firewall and possibly mount the servo differently, Also did you run the flex exhausts? Looks like the muffler might be too close to the side of the nacelle. Again, I don't have the engines yet, I'm going by the pictures on horizon.
Thanks! Pete
Hide Signatures
(in reply to orygg)
       Post #: 2884
RE: Top Flite Cessna 310 posted - 5/18/2009 5:41 AM
n6iap
Score: 100
Status: offline
I'm using the Robart retract kit (there are other brands) and it is just the gear, none of the air equipment required to drive the gear.  You can order the Robart Delux Kit and a pump to get most of what you need.  I needed extra 190 connectors and more tubing but that could have been me.  I also have the doors activated with cylinders like some others have done.  Working retracts for this bird are expensive but very nice and I would not do it any other way.
Hide Signatures
       Post #: 2885
RE: Top Flite Cessna 310 posted - 5/18/2009 11:10 PM
Pete737
Score: 105
Status: offline
I found a post on the 82's. Guess I'll be getting some flex exhaust and making my own throttle servo mount. Thats kind of lame that the retract kit doesn't come with everything you need .
Pete
Hide Signatures
(in reply to n6iap)
       Post #: 2886
RE: Top Flite Cessna 310 posted - 5/19/2009 6:23 AM
dbkvn
Score: 100
Last Login: 5/11/2013
Status: offline
Hello all, Looking back at the review of this aircraft noting that they said it would be interesting to stop it on an asphalt runway...What about using one of the Du-Bro nose wheel brakes ?  Is this possible, and has anyone put the OS .55's in one....Looking for just a little more power for the rarified air here in Denver...Thanks for reading...Kevin
Hide Signatures
       Post #: 2887
RE: Top Flite Cessna 310 posted - 5/19/2009 6:27 AM
dbkvn
Score: 100
Status: offline
Hello again, what about some of those English four strokes...RCVP ?...Kevin in Denver
Hide Signatures
       Post #: 2888
RE: Top Flite Cessna 310 posted - 5/19/2009 9:39 PM
Pete737
Score: 105
Status: offline
Yes, I read that some guys put 55's in it without cutting the cowl.
Did you guys use 6" extentions on the throttle and flap servo's as the instruction book recommends? Just seems like it may come up short to me?
Pete
Hide Signatures
(in reply to dbkvn)
       Post #: 2889
RE: Top Flite Cessna 310 posted - 5/21/2009 7:48 AM
orvel
Score: 105
Last Login: 5/22/2013
Status: offline
In addition to being more powerful than the 46s, the 55's share the same mount dimensions and fit right in within the cowl!
Hide Signatures
(in reply to dbkvn)
       Post #: 2890
RE: Top Flite Cessna 310 posted - 5/21/2009 8:02 AM
orygg
Score: 100
Status: offline
Hi   55's fits in without cutting the cowl i have it on mine
Hide Signatures
(in reply to orvel)
       Post #: 2891
RE: Top Flite Cessna 310 posted - 5/21/2009 7:21 PM
Pete737
Score: 105
Status: offline
Any info on that 6" extention on the throttle and flaps?
Mainly just the throttle concerns me, It looks like there would only be about 2 or 3 inches coming out of the wing, Seems like it may not be enough since I am not using any wye's.
I would appreciate some help since im gonna be finishing the wings this weekend.
Thanks, Pete
Hide Signatures
(in reply to orygg)
       Post #: 2892
RE: Top Flite Cessna 310 posted - 5/21/2009 7:36 PM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
If you're not using "Y" cords, you might want to add a 6" extension to each of the throttle inputs on the Rx.
It's much easier to plug a servo wire into an extension than into the Rx.
But, if you want to do it the hard way, use 12" extensions on the servos instead of 6".
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
       Post #: 2893
RE: Top Flite Cessna 310 posted - 5/21/2009 10:50 PM
Pete737
Score: 105
Status: offline
Thanks Mike, I don't know why the instructions didn't mention that. So basically Im plugging my 6" extention from the servo to a 6" extension from the RX. Makes me a bit nervous..
Pete
Hide Signatures
(in reply to MinnFlyer)
       Post #: 2894
RE: Top Flite Cessna 310 posted - 5/21/2009 11:01 PM
MinnFlyer
Score: 390
Status: offline
Why? It's no different than plugging a 6" extension into a "Y" cord.
If having two connections really bothers you, do what I usually do. Buy a roll of servo wire, cut the wire from the servo and solder in 6, 8, 12, 18 or however many inches of new wire you need.
Hide Signatures
       Post #: 2895
RE: Top Flite Cessna 310 posted - 5/22/2009 12:26 AM
Pete737
Score: 105
Status: offline
"Why? It's no different than plugging a 6" extension into a "Y" cord.
If having two connections really bothers you, do what I usually do. Buy a roll of servo wire, cut the wire from the servo and solder in 6, 8, 12, 18 or however many inches of new wire you need."
Thanks Mike, I don't really feel like doing that either, Ill go with the extensions. Looks like Ill be putting them into the throttle, Flaps and aileron channels since Im not using any wye's at all.
Thanks again, Peter
Hide Signatures
       Post #: 2896
RE: Top Flite Cessna 310 posted - 5/22/2009 12:55 AM
Pete737
Score: 105
Status: offline
Im curious now, Since the book calls for 4 - 6" extensions and 3 - y's. Do they automatically assume the builder is going to y the flaps, throttle and aileron channels? If this is the case Ill need 6 more 6" extensions.
Thanks! Pete
Hide Signatures
       Post #: 2897
RE: Top Flite Cessna 310 posted - 5/22/2009 1:38 AM
MinnFlyer
Score: 390
Status: offline
Yes, three, "Y" cords are assumed
Hide Signatures
       Post #: 2898
RE: Top Flite Cessna 310 posted - 5/22/2009 2:07 AM
Pete737
Score: 105
Status: offline
Thanks Mike.
Pete
Hide Signatures
       Post #: 2899
RE: Top Flite Cessna 310 posted - 5/22/2009 6:02 AM
Tom in Cincy
Score: 110
Status: offline
Ok I finally got to maiden my TF 310. It flew very nice as was expected after reading all the great reviews and watching many vids on YouTube. The power plants are 2 OS FS70"s  swinging 13x7 APC Props @ 9500rpm. I did foam the wings and have retracts. The plane definitely pitches up when flaps are lowered. I had 8% down elevator mixed in on my Futaba but need at least another 5% or so .I noticed some elevator trim change when the retracts go up -  That was alittle surprising.  The OS 70's have plenty of power and sound great in the air. Not overpowering but I would say they fly the plane in a proper manner.  TF made a nice plane.
Tp
"Nosen Cessna 310 Club #10"
Hide Signatures
       Post #: 2900
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
