RE: Composite-ARF Integral, kinda build thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: Composite-ARF Integral, kinda build thread Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Composite-ARF Integral, kinda build thread - 11/29/2006 8:03 PM
schroedm
Score: 103
Last Login: 5/22/2013
Status: offline
rgreen,
Warnings against using ball links on the sides of the phenolic arms have been in the manuals of all our kits for at least 10 years. This setup is a definite no-no on our large aerobatic models and a clevis works perfectly well. On a 2m pattern model with reduced loads(?) you may well get away with it but why risk it?
Your Otop may well a similar but different material OR it may be the same material and manufacturer has not have experienced its twisting limitations as Comp-ARF have on their larger models.
If you have to use a ball link we recommend you use the supplied arms as a template and cut your own from a different material.
Rgds,
Mark
Hide Signatures
(in reply to rgreen24)
       Post #: 76
RE: Composite-ARF Integral, kinda build thread - 11/29/2006 9:48 PM
Angus Balfour
Score: 100
Status: offline
Any idea of a price yet Mark?
Angus
Hide Signatures
(in reply to schroedm)
       Post #: 77
RE: Composite-ARF Integral, kinda build thread - 11/29/2006 11:15 PM
rgreen24
Score: 100
Status: online
Hey Don check of this forum, it may help you.
http://www.rcuniverse.com/forum/m_2227831/mpage_1/key_/tm.htm
Hide Signatures
(in reply to flyinghamiltons)
       Post #: 78
RE: Composite-ARF Integral, kinda build thread - 11/29/2006 11:17 PM
apereira
Score: 100
Status: offline
Dear Jason, thank for sharing with us the construction of the Integral, I was waiting to hear from this new model, do you think that glow engines behave better with strong winds than electrics?, or is just the way an individual flies it?
Alejandro
Hide Signatures
(in reply to RC_Pattern_Flyer)
       Post #: 79
RE: Composite-ARF Integral, kinda build thread - 11/29/2006 11:48 PM
Torben Parsberg
Score: 100
Last Login: 3/14/2013
Status: offline
hi JASON..
Dont forget the video camera
WE LOOOVe Video
keep on the good Woork
Hide Signatures
(in reply to apereira)
       Post #: 80
RE: Composite-ARF Integral, kinda build thread - 11/30/2006 12:25 AM
flyguy667355
Score: 100
Last Login: 11/21/2007
Status: offline
rgreen24 thks, however when i read this post i read about a fuselage failure etc... how's yours doing?? Also, no pictures of the setup etc.. i can call you via phone, etc if you like, just looking for some information.. thks don
Hide Signatures
(in reply to Torben Parsberg)
       Post #: 81
RE: Composite-ARF Integral, kinda build thread - 11/30/2006 12:39 AM
rgreen24
Score: 100
Status: online
I do not want to Hi-jack this thread with talk of the Otop. that being said, I have not had any issues with my OTOP. I still contend that it is one of the best planes that I have ever flown right out of the box. I am switching to go with something having a wider body for more constant speed.
< Message edited by rgreen24 -- 11/30/2006 3:47 AM >
Hide Signatures
(in reply to flyguy667355)
       Post #: 82
RE: Composite-ARF Integral, kinda build thread - 11/30/2006 2:44 AM
JAS
Score: 111
Last Login: 4/24/2013
Status: offline
Here's how I have the linkages on the Integral.
Unless someone has a video camera....
Glow/Electric... it's all in how the individual sets-up/flies the plane.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by JAS -- 11/30/2006 2:45 AM >
_____________________________
Uncle JAS x 2
Shulman Aviation
Check us ^^^ out for US Team stuff
Hide Signatures
       Post #: 83
RE: Composite-ARF Integral, kinda build thread - 11/30/2006 3:03 AM
flyguy667355
Score: 100
Status: offline
rgreen 24, Agree 100% on the hijack thread issue, that's why i sent you my personal email.Thks, and we too are awaiting the test flight of the Integral... Come on Jason,you have us all captive.
Looks to be a great ship!
Don
Hide Signatures
(in reply to JAS)
       Post #: 84
RE: Composite-ARF Integral, kinda build thread - 11/30/2006 3:12 AM
PeterP
Score: 100
Status: offline
Jason,
Not sure if you agree but I would be telling comp-ARF to move the horn locations on wing and stab to get everything as close to 90 degrees as possible on the production versions. Those arms sure look long on your servos?
Peter
Hide Signatures
       Post #: 85
RE: Composite-ARF Integral, kinda build thread - 11/30/2006 3:24 AM
JAS
Score: 111
Status: offline
Peter,
There are no slots cut for the horns in case one chooses not to use them, I cut them there. I, however, will continue to mount mine like this. The reason- at full deflection, the pushrod is straight there-by not loosing any “mechanical advantage” (might not the right choice of words here). Personal preference. Although after I figure out what throws I want on the surfaces, I will try and move the pushrods in on the arms and down on the surface to achieve the same thing. Currently this is the identical set-up from my Impacts.
Rain, rain go away, I want to race at Tangerine (this weekend) http://www.rcuniverse.com/forum/m_5060082/tm.htm
< Message edited by JAS -- 12/2/2006 8:55 AM >
Uncle JAS x 2
Shulman Aviation
Hide Signatures
(in reply to PeterP)
       Post #: 86
RE: Composite-ARF Integral, kinda build thread - 12/1/2006 5:35 PM
rgreen24
Score: 100
Status: online
Jason, quick question about your nose ring set up. Do you have to remove the nose ring from the plane, the remove the engine or does it just slide out? And also who makes the nose ring that you are using?
R
Hide Signatures
       Post #: 87
RE: Composite-ARF Integral, kinda build thread - 12/2/2006 4:01 PM
Torben Parsberg
Score: 100
Status: offline
http://www.znline.com/list_photos.php?langue=english&cle_data=1142893342&source=description_entites_1
Nice plane how did it perform????
Hide Signatures
       Post #: 88
RE: Composite-ARF Integral, kinda build thread - 12/2/2006 7:54 PM
Julius-Alexander
Score: 100
Last Login: 1/9/2007
Status: offline
Might not this question be a bit embarrassing for Mr Zardini who is selling this beautiful model? A such nice looking airplane can only fly well, no?
I would appreciate how clean his cockpit setup done. Excellent job Mr Zardini... it sounds like a pleonasm to me.
Bonnes fêtes de fin d'année en Belgique et dans le reste de la francophonie.
J.-A.
< Message edited by Julius-Alexander -- 12/2/2006 8:04 PM >
Hide Signatures
       Post #: 89
RE: Composite-ARF Integral, kinda build thread - 12/2/2006 8:28 PM
JPZ
Score: 100
Last Login: 11/12/2012
Status: offline
Hello Julius
Merci beaucoup, mon anglais n'est pas très bon.
J'ai fait 4 vols aujourd'hui dans le vent et la tempête, et les impressions sont excellentes .
Vous pouvez passer le message si vous voulez ?
JP
Hide Signatures
(in reply to Julius-Alexander)
       Post #: 90
RE: Composite-ARF Integral, kinda build thread - 12/2/2006 9:42 PM
Julius-Alexander
Score: 100
Status: offline
Avec grand plaisir, mais je trouve que vous vous débrouillez fort bien en Anglais.
JP made 4 flights today into a stormy like weather (typical Belgian weather ) and his first impressions are excellent.
I would be very pleased to see the first flights of JAZ Integral in Apopka next week. I guess he is busy pylon racing this WE, no?
rcacf
J-A
Hide Signatures
(in reply to JPZ)
       Post #: 91
RE: Composite-ARF Integral, kinda build thread - 12/3/2006 1:53 AM
JAS
Score: 111
Status: offline
OK, now that this is over for me: http://www.rcuniverse.com/forum/m_5060082/tm.htm I'm going back to work on the Integral. I was hoping to fly it tomorrow, but it looks like rain later in the day (when racing is finished), so I may wait til Monday afternoon when it's supposed to stop (and I have fuel).
Robert, the nose ring comes off with the motor. Its a very tight Speedmax nose ring that I found in a box.
Uncle JAS x 2
Shulman Aviation
Hide Signatures
       Post #: 92
RE: Composite-ARF Integral, kinda build thread - 12/3/2006 3:02 AM
rgreen24
Score: 100
Status: online
Thanks JAS, I really like that set up.
< Message edited by rgreen24 -- 12/3/2006 3:03 AM >
Hide Signatures
(in reply to JAS)
       Post #: 93
RE: Composite-ARF Integral, kinda build thread - 12/6/2006 6:36 PM
walter e
Score: 100
Last Login: 7/23/2012
Status: offline
jason do you have a date when they will be available
thanks
walter
ps let us know how it goes at the contest this week i know a few guys from dist 1 will be there
Hide Signatures
       Post #: 94
RE: Composite-ARF Integral, kinda build thread - 12/7/2006 2:28 AM
Julius-Alexander
Score: 100
Status: offline
How do you like the plane so far? I can just confirm the shape of the plane looks as beautiful in pictures as in real.
Hide Signatures
(in reply to walter e)
       Post #: 95
RE: Composite-ARF Integral, kinda build thread - 12/7/2006 3:20 AM
JAS
Score: 111
Status: offline
The first and 2nd shipments are sold out. So March is where you're probably looking at if you're not already on a reps list.
With 4 flights on it, 3 a bit under-powered with a YS (waiting for new proto OS-200 in a couple of weeks), it goes through P and F fine. F is way easier than it is with my Impact, but not as polished cause of only a few flights. Just playing around with CG and throws now to make it all look good. If it's not windy, I'll fly it in the contest. If it's windy, I'll just fly it afterwards for show. No need for high rate rudder unless you want to do some 3D flying...lol.
Oh yea, 10lbs 2ozs. And I only have 2 runs of CA on the canopy...
< Message edited by JAS -- 12/7/2006 4:08 AM >
Uncle JAS x 2
Shulman Aviation
Hide Signatures
       Post #: 96
RE: Composite-ARF Integral, kinda build thread - 12/7/2006 3:46 AM
Gregg G
Score: 100
Last Login: 2/22/2013
Status: offline
J.
Did you decide on a YS, or is that a typo?
Greg Grigsby
Hide Signatures
(in reply to JAS)
       Post #: 97
RE: Composite-ARF Integral, kinda build thread - 12/7/2006 4:34 AM
BrianB
Score: 100
Last Login: 6/4/2011
Status: offline
Yea, what happend to the OS200 you had at the Jax. contest. I was wanting to here a report on the engine myself.
Brian Billings
Hide Signatures
(in reply to Gregg G)
       Post #: 98
RE: Composite-ARF Integral, kinda build thread - 12/7/2006 6:14 PM
JAS
Score: 111
Status: offline
Here's some pics of my installation in the canopy area
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by JAS -- 12/7/2006 6:15 PM >
Uncle JAS x 2
Shulman Aviation
Hide Signatures
(in reply to BrianB)
       Post #: 99
RE: Composite-ARF Integral, kinda build thread - 12/7/2006 6:28 PM
rgreen24
Score: 100
Status: online
JAS what YS engine were using, to be so underpowered?
Hide Signatures
(in reply to JAS)
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.980RCU1
