RE: Pentathlon
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: Pentathlon Page: <<   < prev  1 2 [3]
Login
RE: Pentathlon - 12/18/2006 12:30 AM
Ryan Smith
Score: 100
Last Login: 11/8/2009
Status: offline
I've got a new bipe stick plane designed by Naruke. You should see the finishes that the Japanese put on these things.
I tried the 09 and 11 sequence proposals with it and it was effortless.
Bring it.
_____________________________
Team Horizon, Evil-R/C Products, YS
Hide Signatures
(in reply to MHester)
       Post #: 51
RE: Pentathlon - 12/18/2006 4:08 AM
flyintexan
Score: 100
Last Login: 11/4/2009
Status: offline
Looking for more help again.....
Scott,
I think I have the axi 5330 approximated, but I do not have a dimensioned print or sketch for the motor mounting plate....the scanned file you tried to send did not come through....for some reason shows up on my puter as a blank page in word....??? If anyone can help or direct me to help, it would be much appreciated.
I'm also wondering if the prop mounts directly to the small boss on the front end of the motor?...seems like a small diameter...am I missing something?
The axi firewall should tab in just like the original, but will be located right behind the axi.
Mark
p.s. The e-version stick plane will have extra long gear.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by flyintexan -- 12/18/2006 4:09 AM >
NSRCA 3656
www.NSRCA.us
Hide Signatures
(in reply to Ryan Smith)
       Post #: 52
RE: Pentathlon - 12/18/2006 4:39 AM
flyintexan
Score: 100
Status: offline
After searching on the e-pattern forum a bit I found a pic with a mount. I also see a prop adaptor that I do not think I have drawn on the front end of the motor....still need real dimensions to get it right.
-mark
Click for fullsize
NSRCA 3656
www.NSRCA.us
Hide Signatures
(in reply to flyintexan)
       Post #: 53
RE: Pentathlon - 12/18/2006 11:19 AM
PatternPilot
Score: 100
Status: offline
Hi Mark,
I will try to rescan the mounting info and send.. There are two ways to mount the motor.. On is nose ring mount and you slide the 12mm shaft over the smaller shaft with 2 allen screws. or the other way is to back plate mount which with your plane I would think would be better.. I would make out of 2mm carbon plate, and you can mount it further back from the nose.. I will get some pics and send them thru RCU and your private email.. By doing this way the prop shaft is bolted to the outter can with some samll screws..
What do you think about a honeycomb wing and carbon tube and such?
Keep in touch.
Scott Anderson
Team Castle Creations
Team Tanicpacks.com
Hide Signatures
       Post #: 54
RE: Pentathlon - 12/18/2006 11:31 AM
PatternPilot
Score: 100
Status: offline
Mark,
Here are some quick pics of the back plate type mount.. and one of the nose mount from my old Focus..
Scott
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to PatternPilot)
       Post #: 55
RE: Pentathlon - 12/18/2006 1:11 PM
flyintexan
Score: 100
Status: offline
Scott,
Thank you. Maybe I modeled the axi wrong on the back....I drew two sets of bolt circles on the back of the motor. The outer one was a tight fit at the 44mm diameter. Is it just the inner bolt pattern that is supposed to be on the motor? Then the both the inner and outer bolt patterns are on the aluminum adapter plate that your standoffs screw into?
I assume the outer pattern of holes in the adapter plate are threaded and your long standoffs shown in your pic have a threaded stud type end that then screws into the adapter plate?
We should be able to simply position the firewall behind the adapter plate that is mounted to the back of the motor.....?
-mark
NSRCA 3656
www.NSRCA.us
Hide Signatures
       Post #: 56
RE: Pentathlon - 12/18/2006 2:44 PM
PatternPilot
Score: 100
Status: offline
Hey Mark,
I'm going to be out and about all day, send me your number by PM and I'll call you with info..
scott
Hide Signatures
       Post #: 57
RE: Pentathlon - 12/21/2006 3:30 AM
flyintexan
Score: 100
Status: offline
I got a chance to get back on the computer and play a bit. I added in an AXI firewall, but right now it is directly behind the motor without any sort of adaptor plate. If an adaptor plate with grommet type mount would be better, I will need to move the firewall back a touch and add the proper bolt pattern for the adaptor plate.
I can also later add some gussets that will match the curvature of the fuse side and mate to the axi firewall for a great deal of added strength.
I did not put in any lightening holes at this time...but that is easy to do at a later time.
Ducting should not be a big issue if thought about carefully. The cheeks could even be moved forward and enlarged if necessary to add inlet air.
-mark
Click for fullsize
Click for fullsize
NSRCA 3656
www.NSRCA.us
Hide Signatures
       Post #: 58
RE: Pentathlon - 12/21/2006 3:34 AM
flyintexan
Score: 100
Status: offline
I found dimensions for the C50XL and made a simplified model to see how it would look. Obviously lots of room. The bolt pattern located at the front of the gearbox would actually mate up with the back surface of my F2 former. This former could be re-done and made from something much stronger with the front bolt pattern laser cut directly into it. A new, rear firewall support can also be added.
-mark
Click for fullsize
Click for fullsize
NSRCA 3656
www.NSRCA.us
Hide Signatures
       Post #: 59
RE: Pentathlon - 1/11/2007 9:30 PM
mmattockx
Score: 100
Last Login: 3/25/2009
Status: offline
Hey Mark,
Any news or updates on the kit production or the engine installation we were discussing?
Mark
Waco Brotherhood #4
Hide Signatures
       Post #: 60
RE: Pentathlon - 1/12/2007 4:11 AM
flyintexan
Score: 100
Status: offline
Mark,
I'm sorry I have not updated anything on this thread lately. However, I have not been completely lazy. I have built a cnc foam machine. I am now working out all the profile programs for the Pentathlon . As slow as things seem, I'm actually on schedule for my mid to late Jan. release. I still have a good bit of work to do to get the foam parts all programmed and get a signigicant amount of stock cut up ahead of release. Should have this done within two weeks. As you can see by the picture of the foam test cut, I'm trying a few things with the foam machine.....not sure yet if all these cuts will work out properly....if not, the wing section will be solid. The bottom turtle deck cut came out beautifully and right on size. When I get everything in order and ready to go, I will make a note here on RCU and update the insightrc website.
As for the solid modeling:
Sorry I have just not had time to switch gears and model the motors (electric and gas) that I have requests for. I do have a more accurate model of the hacker started (thanks JAS).
My prototype Pentathlon now has about 20 flights (6 with a 160DZ) and is starting to feel really comfortable. I still do not have any mix programmed. I need a calm day to add a touch of aileron to rudder, but it still looks like no elevator to rudder mix will be needed at all. I am also waiting on a new scale to re-weigh with the YS installed.
Two other prototypes are still in the build process. One will be electric and we should see more on that soon. The other will be YS and we may see a pic or two of that build soon too.
Regards,
mark
www.insightrc.com
Click for fullsize
Click for fullsize
NSRCA 3656
www.NSRCA.us
Hide Signatures
(in reply to mmattockx)
       Post #: 61
RE: Pentathlon - 1/12/2007 4:41 AM
mmattockx
Score: 100
Status: offline
Mark,
Thanks for taking time to update us, I understand you must be swamped right now. I look forward to seeing a kit in the flesh and seeing it come together on my table.
Mark
Waco Brotherhood #4
Hide Signatures
       Post #: 62
RE: Pentathlon - 1/12/2007 6:21 PM
PatternPilot
Score: 100
Status: offline
Hey Mark,
Don't forget to send me the weight
Scott Anderson
Hide Signatures
       Post #: 63
RE: Pentathlon - 1/12/2007 9:00 PM
Robbidos
Score: 100
Last Login: 11/7/2009
Status: offline
I was looking at that kit and I have a question. What is Anhedral Stab?
- Robert Beaubien
- Sun Valley Fliers
Hide Signatures
       Post #: 64
RE: Pentathlon - 1/12/2007 11:19 PM
flyintexan
Score: 100
Status: offline
Scott,
Will post weights asap. Should have a scale here tomorrow.
Robbidos,
Anhedral is the opposite of dihedral. The stabs on the Pentathlon droop at 6° per side. I believe there are various, small, advantages to doing this, which together, result in less coupling during yaw. The wing on the Pentathlon contributes as well. There are two more prototypes under construction....one of which will have a standard flat stab (no dihedral/anhedral), and the other will have anhedral like mine.
Regards,
Mark
NSRCA 3656
www.NSRCA.us
Hide Signatures
(in reply to Robbidos)
       Post #: 65
RE: Pentathlon - 4/30/2007 11:55 PM
ucakcimurat
Score: 100
Last Login: 5/15/2009
Status: offline
Hi! I need Pentathlon DXF or cad plan.I will buy Pentathlon kit but this kits box big.and cargo very expensive and custom tax very big problem in turkey .
best regard
Murat calisir
Hide Signatures
(in reply to Super D)
       Post #: 66
RE: Pentathlon - 5/1/2007 12:51 AM
flyintexan
Score: 100
Status: offline
Murat,
Thank you for your interest in the Pentathlon .
I have sent laser kits without any foam parts in order to ship overseas and save on shipping costs. These laser parts kits include laser cut foam cutting templates so that the foam parts can be cut by hand with a hot wire bow.
Please email me directly at flyintexan@houston.rr.com and I will be happy to give you more details and pricing.
Best Regards,
Mark
Click for fullsize
Click for fullsize
NSRCA 3656
www.NSRCA.us
Hide Signatures
(in reply to ucakcimurat)
       Post #: 67
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.891RCU1
