RE: Which lipo charger?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Common Sense RC Support >> RE: Which lipo charger?
Page: <<   < prev  1 [2]
Login
RE: Which lipo charger? - 12/15/2006 4:45:12 PM
Tram
Status: offline
Mike-
Here is a pick of the simple adapter I am using on our charger to charge a 2 cell battery without balancing taps..
Jeff
Click to see fullsize image.
Click for fullsize
_____________________________
Jeff Williams
www.CommonSenseRC.com
(in reply to mikeang)
       Post #: 26
RE: Which lipo charger? - 12/16/2006 12:20:29 PM
mikeang
Status: offline
Jeff, thanks for the pic.
If i understand correct, you used the charger adapter shown in the pic below and removed the middle red wire. Or no?
I also thought that the adapter must be modified like this for a 2cell
I was thinking; instead of removing the middle wire (because i am afraid of damaging the adapter), to cut it short, and put a heat srhink on its tip. Is it safe to do this?
Thank you very much.
Mike
Click for fullsize
(in reply to Tram)
       Post #: 27
RE: Which lipo charger? - 12/16/2006 6:17:18 PM
Tram
Status: offline
Mike-
You have it exactly correct..
You could leave the red wire as is and throw some shrink wrap on it..
You'd be good to go..
Jeff
Jeff Williams
       Post #: 28
RE: Which lipo charger? - 12/16/2006 7:31:29 PM
mikeang
Status: offline
Jeff, thank you for all of your help so far.
Now all i have to do, is to order the charger.
Best regards
Mike
(in reply to Tram)
       Post #: 29
RE: Which lipo charger? - 12/17/2006 12:54:10 AM
Tram
Status: offline
Order one.. You won't be sorry..
Jeff Williams
       Post #: 30
RE: Which lipo charger? - 12/17/2006 8:31:16 PM
mikeang
Status: offline
I made my order last night
I am looking forward to use this charger.
Mike
(in reply to Tram)
       Post #: 31
RE: Which lipo charger? - 12/18/2006 3:27:43 AM
Tram
Status: offline
I love all of mine, I am sure you will enjoy yours.
Jeff Williams
       Post #: 32
RE: Which lipo charger? - 12/18/2006 9:00:50 AM
mikeang
Status: offline
Jeff, i have a question regarding the leads.
The leads that i will solder with the adapter wires have diameter of 1mm. There will be a problem using these thin wires?
Thanks.
Mike
(in reply to Tram)
       Post #: 33
RE: Which lipo charger? - 12/19/2006 3:17:57 AM
Tram
Status: offline
No, you shouldn't have any problems with the wires..
Jeff Williams
       Post #: 34
RE: Which lipo charger? - 12/19/2006 7:49:24 PM
mikeang
Status: offline
Jeff, if no problem, can you measure the length of the wires of the adapter that you made?
Just to get the idea of how long the wires should be.
Thanks again
Mike
(in reply to Tram)
       Post #: 35
RE: Which lipo charger? - 12/19/2006 10:33:54 PM
Tram
Status: offline
Ah, the distance shouldn't matter..
I think they were about an inch, but you can make them as long as you like..
Jeff
Jeff Williams
       Post #: 36
Jump to:
