ZDZ80 SUPER
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> ZDZ & RCS Support >> ZDZ80 SUPER
Page: [1]
Login
ZDZ80 SUPER - 11/22/2006 3:08:46 AM
FLYMAN
Status: offline
MY ZDZ 80 IS HARD TO START I HAVE DONE LIKE THE MANLE TOLD ME TO DO STILL HARD TO START O AND THIS IS A NEW ZDZ 80 BUT WHEN I GET IT TO START THIS ZDZ IS A BAD ASS ENGINE THIS THING RUNS GREAT STILL ON 32-1 MIX ABOUT 3 GALS IT WAS STARTING LIKE A TOP BUT NOW IT IS NOT ANY HELP OUT THERE THANKS
       Post #: 1
RE: ZDZ80 SUPER - 11/22/2006 8:03:05 PM
Mike Dooley/RCS
Status: offline
Set L needle to 2 turns out. What has your CHT been running? What prop and RPM? Is your ig battery ok?
_____________________________
Mike Dooley
RC Showcase
(in reply to FLYMAN)
       Post #: 2
RE: ZDZ80 SUPER - 11/23/2006 2:49:22 AM
FLYMAN
Status: offline
my rpm is 5800 prop is a pt wood 26-10 and the low in is set at 1 3/4 out and cht ??? the battery is new and it is ok and it is a 6.v thanks walter
< Message edited by FLYMAN -- 11/23/2006 2:57:24 AM >
(in reply to Mike Dooley/RCS)
       Post #: 3
RE: ZDZ80 SUPER - 11/23/2006 2:54:30 AM
FLYMAN
Status: offline
i got it fixed starts like a top thanks
< Message edited by FLYMAN -- 11/25/2006 2:45:40 AM >
       Post #: 4
RE: ZDZ80 SUPER - 4/29/2007 8:02:49 AM
rcgood
Status: offline
quote:
ORIGINAL: FLYMAN
You wanna tell us what you did to get it fixed? I'm having some problems too.
       Post #: 5
RE: ZDZ80 SUPER - 6/21/2007 8:29:55 PM
gooseF22
Status: offline
Good
did you ever hear what he did to get it starting?
Goose
Team Fromeco
(in reply to rcgood)
       Post #: 6
RE: ZDZ80 SUPER - 6/25/2007 7:53:05 AM
rcgood
Status: offline
nope
(in reply to gooseF22)
       Post #: 7
RE: ZDZ80 SUPER - 6/27/2007 1:30:12 PM
JoeAirPort
Status: online
Just use the ckoke to start it. Leave the choke 10-20% open and it will start.
Joe AP
       Post #: 8
RE: ZDZ80 SUPER - 4/28/2008 12:05:40 PM
cropduster48
Status: offline
My zdz 80 rv-j sounds all the world to be having ignition problems. Also having some kickback problems while starting. And yes, the ignition mod is set corectly. Its a new engine, and no I havent tried changing the sparkplug yet. Low needle set at 1-7/8. Forgot what the high needle is set at, but it is leaned out just enough to stop the 4 cycling at full power. 93 octane, 32 to one Lawn Boy oil. No air leaks in fuel syatem. Engine starts pretty easly, idels fairly well. I am running the battery power through a miriacle switch, reducing the voltage from 8 volts down to 6 volts. Could this be my problem. I have heard that miracle switches don`t work well on ignition systems. The exact problem is this. Random miss fire along with a backfire through the muffler followed by a very rough running engine for about 10 seconds, and then sudenly starts running properly again. This problem while active stays present even while reducing power all the way down to idel. There seems to be nothing loose in the wiring. Using standard recomended prop for this engine. Engine has non restrive cooling air, but is trying to run very hot. Max temp I have seen is 320 F. The engine has not been stuck, is very quite, and has good compresion. This engine sounds like it is running to much ignition lead, but the pickup senser is set corectly. I have flown my Yak 54 two times with this engine, but landed becaus of the rough running engine after take off. When it decides to run corectly, it has lots of power. I have a lot of experence with highperformance two cyle engines, so any input would be helpful.
Mr Gerald D Robison
Poplar Bluff Mo.
(in reply to JoeAirPort)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
8.750RCU1
