RE: Sig's new Waco SRE
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Sig's new Waco SRE
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: Sig's new Waco SRE - 2/18/2008 3:54:54 AM
rockz
Status: offline
Only a lathe and a drill press
(in reply to silver.kiwi)
       Post #: 226
RE: Sig's new Waco SRE - 2/20/2008 12:21:05 AM
rockz
Status: offline
Hi, test flew waco with 90 Saito twin this morning in dead calm conditions.Take off is a bit longer[on grass field] but plenty of power,half throttle is about right and the sound of a twin makes it very realistic.Also chaged wheels to three and a half inches and put a scale tail wheel setup.Used flexipipe for exhausts welded to header pipes, also turned up a custom nut to fit spinner.Just waiting for a onboard glow to turn up and get the cowl back on.Also found tuning engine with tacho the most reliable.
(in reply to rockz)
       Post #: 227
RE: Sig's new Waco SRE - 2/20/2008 12:43:38 AM
silver.kiwi
Status: offline
quote:
ORIGINAL: rockz
I started the breakin on the Saito 100T this morning but attempted no flying as it was quite windy. The engine ran fine but I had to stop before I could peak the RPM because the on board glow battery ran dead. It's 1600 mah and was good for about 40 minutes of continuous use. I'll run it again tomorrow and lean the carbs so I don't need continuous glow power. The twin cylinder engines sure sound nice, don't they? Did you still use the wheels pants with the larger wheels? I was thinking of doing the same because our grass can be thick at times.
(in reply to rockz)
       Post #: 228
RE: Sig's new Waco SRE - 2/20/2008 1:44:12 AM
rockz
Status: offline
No, i dont use the pants or flying wires but i will fit flying wires soon just to see how easy the can be riggede.
       Post #: 229
RE: Sig's new Waco SRE - 2/20/2008 1:51:50 AM
silver.kiwi
Status: offline
Here my finished product. Maiden flight tomorrow if the engine cooperates? The flying wires are not difficult and take me less time to attach/remove than the "N" struts. Once rigged all that is necessary is to remove the 4 attaching screws from the lower wing.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to rockz)
       Post #: 230
RE: Sig's new Waco SRE - 2/20/2008 2:20:52 AM
GaGeeBees
Status: offline
Looks great silver.kiwi. The flying wires add a lot to the scale looks. Does it come with a dummy engine? That would be the finishing touch. Nice work. Can't wait to hear how the maiden flight goes.
_____________________________
...and then the unthinkable happened!
       Post #: 231
RE: Sig's new Waco SRE - 2/21/2008 1:08:40 AM
silver.kiwi
Status: offline
quote:
ORIGINAL: GaGeeBees
Maiden flight complete........zero faults. Here's the offical poster pictures of the event. I was alone at the field so I couldn't get any airborne shots. The Saito FA-100T pulls the plane with good authority and takeoffs are short even on the grass. As for the plane itself, I could not be more pleased. Two clicks of right aileron and two clicks of down elevator and she tracks straight as an arrow. Drop the flaps and it lands like a feather. Want to do unscale aerobatics? That's O.K. too. That's a great testament to a straight airframe thanks to SIG's engineering and jig built laser cut parts. First comments about the lower wing aside, this is a great model and with great quality throughout. The instruction manual is the best I have seen with an ARF. I don't know who the author and proof reader are but they are to be commended. I suspect Scott Christensen. Although a dummy radial does not come with the kit I purchased one but probably will not install it as I hate covering up the FA-100T.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to GaGeeBees)
       Post #: 232
RE: Sig's new Waco SRE - 2/21/2008 6:19:41 AM
kvlasblom
Status: offline
Thanks Silver.Kiwi!
You not only have a beautiful model, but your flying field is also something to be jealous of!
Has anyone placed any video clips of the Waco online yet? I can't find any anywhere....
WACO Brotherhood #93
Current project: 1/6 WACO SRE build from plans
       Post #: 233
RE: Sig's new Waco SRE - 2/21/2008 4:38:21 PM
S. Christensen
Status: offline
Silver Kiwi,
Congratulations on your Waco maiden! If you're anything like me, my own Waco very quickly became my favorite! It's as much fun in the pits as it is in the air. And for such an interesting model, I've found it to be virtually viceless in its flight envelope. I'm pleased as punch that you have enjoyed the assembly, as well as the flight of your new model - after all, THAT was the whole idea. I know that you're rightfully enamoured with your Saito 1.00 twin, but I still have to say that a nicely done dummy 9-cylinder radial in the front really looks nice, at least in my humble opinion.
Again, congrats and I sincerely hope that you continue to enjoy your great looking model!
Kind Regards,
Scott Christensen
SIG Mfg. Co., Inc.
Click for fullsize
Click for fullsize
Scott
AMA L-47765, AMA Hall of Fame, Waco Brotherhood #42
       Post #: 234
RE: Sig's new Waco SRE - 2/21/2008 9:27:49 PM
rockz
Status: offline
Silver Kiwi, how do you adjust needle valves with the cowl on, i cant see any extentions from the photos.
(in reply to S. Christensen)
       Post #: 235
RE: Sig's new Waco SRE - 2/21/2008 10:04:29 PM
silver.kiwi
Status: offline
quote:
ORIGINAL: rockz
The answer to that is, I don't. I've found in the past that once the engine is running correctly I try not to mess with it. I'm hoping this one will be the same as I HATE cutting holes in the cowl. Also, this cowl fits great (no complicated engine or exhaust to fit around) and is easily taken off and put back on if needed. The only hole is in the left side for the fueling service valve as shown in the instruction manual. How did you accomplish the job with your twin cylinder .90?
(in reply to rockz)
       Post #: 236
RE: Sig's new Waco SRE - 2/21/2008 10:09:14 PM
silver.kiwi
Status: offline
quote:
ORIGINAL: S. Christensen
Silver Kiwi,
Kind Regards,
Scott Christensen
SIG Mfg. Co., Inc.
Yours certainly does look nice and I may rethink the idea after I am able to get a new union nut for the correct spinner. By the way, what did you use for the cowl scoops on the lower cheeks?
       Post #: 237
RE: Sig's new Waco SRE - 2/21/2008 11:17:15 PM
rockz
Status: offline
I test flew mine without the cowl[still waiting on onboard glow]and only have three holes in cowl.One for the fueller,one for needle valve [asp 90], and one in the bottom to clear rocker cover[asp90\]If i have to fit extentiones to needle valves i will try and dummy them up like fuel cap and breather, how ever you cant see them when flying.I prefer practability on my planes.
       Post #: 238
RE: Sig's new Waco SRE - 2/22/2008 12:15:17 AM
GaGeeBees
Status: offline
I have to agree with Scott, the dummy radial really completes the model. I rarely fiddle with the needle valves on my Saitos either but I do usually run an extension out through the cowl.
Congrats on your maiden flight, kiwi! Sounds like it flies as good as it looks. I'm hoping to be able to order mine after the Perry (GA) swap meet.
(in reply to rockz)
       Post #: 239
RE: Sig's new Waco SRE - 2/22/2008 2:01:31 AM
haze_b
