RE: Sig's new Waco SRE
Tower Hobbies
Logged in as Guest
  Printable Version
KAOS /OS91P-SCRATCH BUILT RTF/SPA LEGAL
Seller:  F.Imbriaco
Details:   $500.00   |  7/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Sig's new Waco SRE
Page: <<   < prev  6 7 8 9 10 11 12 13 [14] 15   next >   >>
Login
RE: Sig's new Waco SRE - 4/25/2008 4:25:54 AM
thetireman1
Status: offline
I too had a issue with the tips of the main wing as the covering was not overlapped. They made me pay for the wing to ship it and I sent my bad one back and then they issued credit.
(in reply to kruzin55)
       Post #: 326
RE: Sig's new Waco SRE - 4/30/2008 2:50:39 AM
WacoOne
Status: offline
The right wing tip of the bottom wing was defective on mine. A joint wasn't glued. Sig replaced it right away.
Silver Kiwi...
How much clearance do you have between the rocker arm covers and the cowl with your Saito 100? I've got a great running OS FT-120 twin I'm trying to use but due to the engine being mounted off center to compensate for the right thrust, one rocker arm cover touches the inside of the cowl. I think the heat would distort the fiberglass. I certainly will NOT cut a clearance hole in the cowl. Any ideas?
(in reply to thetireman1)
       Post #: 327
RE: Sig's new Waco SRE - 4/30/2008 4:32:20 PM
silver.kiwi
Status: offline
quote:
ORIGINAL: WacoOne
Silver Kiwi...
Hi WacoOne,
I have approximately 1/4 to 3/8 inch clearance between the cowl and the valve covers on my SRE. Heat has not been a factor here however, on another plane of mine (Monocoupe) the intake valve cover just touched the cowl and did very slightly distort the fiberglass. The distortion was as much from vibration as heat, I think. It didn't discolor the cowl but rather just caused a slight bulge that caused the paint to spider web.. In that case, I expoxied a thin piece of cork gasket material to the inside of the cowl and that seemed to work. Of course your rocker covers are different from the Saito and might make an even tighter fit. I'd try it and see if you get any distortion that you can't live with before cutting holes or a different engine. You could also try shimming the right thrust out a little and if the flight is not affected much, go with that. Let us know how you fair.
SK
(in reply to WacoOne)
       Post #: 328
RE: Sig's new Waco SRE - 4/30/2008 6:15:08 PM
Didg
Status: offline
Personally, I would shim the right side of the engine mount, until the engine fits in the cowl without touching the sides. Then see how the thrust line is.
There's not much right thrust built in to the firewall, but if your rocker cover is only just touching the cowl you should be ok.
It'll still fly ok without any right thrust, you'll just have to work the rudder more, or use a throttle to rudder mix.
_____________________________
WACO Brotherhood #52
(in reply to silver.kiwi)
       Post #: 329
RE: Sig's new Waco SRE - 5/3/2008 1:38:49 AM
WacoOne
Status: offline
Okay, Guys. Thanks for your input. I hadn't considered shimming the right thrust but that may be the answer. With the engine centered on the firewall there is about 1/4" of clearance on each side so I'll work from that angle. The idea of putting gasket material on the inside of the cowl should prevent any distortion. I have some asbestos gasket material that might work well also.
Thanks again for the suggestions and I'll let you know how it works out.
Bill
(in reply to Didg)
       Post #: 330
RE: Sig's new Waco SRE - 5/3/2008 7:09:49 PM
Didg
Status: offline
On Wildhare's 100" SU26 there is no side thrust built in to the firewall.
That way you can shim your mount if you want it or not.
It's not nessesary, it just makes the plane a bit more easy to fly.
       Post #: 331
RE: Sig's new Waco SRE - 5/4/2008 7:32:17 PM
WacoOne
Status: offline
I've built many a plane from kits and never put side thrust in any of them. If there was ever a problem I didn't see it.
Bill
WACO Brotherhood #21
(in reply to Didg)
       Post #: 332
RE: Sig's new Waco SRE - 5/7/2008 11:42:17 AM
kvlasblom
Status: offline
I'm also thinking of fitting a Saito FA-100 in my plan-built SRE.
Only I don't understand how it can fit into the cowling accoriding to the measurements I found on the Internet, from the propshaft to the top of the engine is 106mm.
If I measure the clearance on the front view of my plans, I see that I only have 96mm from the thrustline to the exterior line of the cowling...
I really want to avoid cutting a hole in the cowling, but don't want to have to fit a smaller engine, although I have no idea how heavy this thing is going to get yet.
According to the SIG site, theirs should be around 4.5 Kg, so I'm hoping not to exceed that.
WACO Brotherhood #93
Current project: 1/6 WACO SRE build from plans
       Post #: 333
RE: Sig's new Waco SRE - 5/14/2008 7:52:51 PM
silver.kiwi
Status: offline
If the space inside your cowl is the same or larger than Sigs, then you'll have plenty of room. Check out the photos of my installation and you can see that the 100T is a prefect fit and has plenty of power to fly the plane nicely.
< Message edited by silver.kiwi -- 5/14/2008 7:58:37 PM >
(in reply to kvlasblom)
       Post #: 334
RE: Sig's new Waco SRE - 5/14/2008 8:08:20 PM
kvlasblom
Status: offline
Thanks!
Yes, the space is more or less the same.
Only problem is the cost of the twin.
My only other worry is that it will provide less power and be heavier than the Saito 100 single cylinder engine.
Food for thought...
       Post #: 335
RE: Sig's new Waco SRE - 5/14/2008 8:50:44 PM
Didg
Status: offline
Any suggestions for a good 1/6 scale civilian pilot.
I'm going to enter mine in to some scale comps and I neen to have a pilot fitted or I'll lose points.
       Post #: 336
RE: Sig's new Waco SRE - 5/14/2008 11:40:24 PM
thetireman1
Status: offline
You can use the Williams Bros. or the Great
Planes busts. There also is a guy selling scale headsets in various sizes on RCU too.
(in reply to Didg)
       Post #: 337
RE: Sig's new Waco SRE - 5/15/2008 1:42:09 PM
S. Christensen
Status: offline
Hi Didg!
The real value of a thread such as this is the archival posts and photos. Case in point is your question regarding 1/6th scale civilian pilot figures for your own Waco. Go back to page 12, posts #279 (from Silver Kiwi) and #281 (from myself) in this thread. These posts directly address this question and offer some reasonable answers for you.
Scott @ SIG
Scott
AMA 47765, Waco Brotherhood #42
(in reply to Didg)
       Post #: 338
RE: Sig's new Waco SRE - 5/15/2008 3:55:51 PM
earthling
Status: offline
i saw that too. Nice one. I see your 2 seat spacewalker on your avatar... my 1st large scale build was a 1 seat spacewalker in the early 90's... had it until bad crash in 2000 when elevator servo arm broke.. still my favorite giant scale
(in reply to gnirwin)
