RE: Sig's new Waco SRE
Tower Hobbies
Logged in as Guest
  Printable Version
bill hempel 50% cub rtf - RTF
Seller:  rvpc2003
Details:   $7,500.00   |  12/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Sig's new Waco SRE
Page: <<   < prev  9 10 11 12 13 14 15 16 17 [18]
Login
RE: Sig's new Waco SRE - 11/25/2008 7:39:36 AM
fsheplavy
Status: offline
quote:
ORIGINAL: rcten
Maynardrupp,
I read back in this forum that they recessed the servos and it is true, the only problem is they havn't updated the assembly manual to reflex this change, however it is a no brainer with the parts supplied and the size of the servo openings in the wing.
Certainly not in the one I received two weeks ago. Sure wish they had.
Fred
(in reply to rcten)
       Post #: 426
RE: Sig's new Waco SRE - 11/26/2008 12:34:33 AM
MormonMike
Status: offline
A YKS-6, I can hardly wait . MM
(in reply to kvlasblom)
       Post #: 427
RE: Sig's new Waco SRE - 11/26/2008 12:39:39 PM
maynardrupp
Status: offline
I don't really understand the statements about "internal servos". This airplane is not a kit, so the servo rails are already installed and waiting for your servos. You certainly could cut the area out, make a plate and reinforcement to rotate the servo , mount it to the cover plate, and it would then go internal with only the arm exposed through a slot. I have not seen any documentation on this mod and it would require cutting up the covered wing. If they ever do offer this great airplane as a kit, I would be the first in line to buy one. I love to build and have built 2 of SIG's sumpin extra.
(in reply to fsheplavy)
       Post #: 428
RE: Sig's new Waco SRE - 11/26/2008 6:54:19 PM
silver.kiwi
Status: offline
quote:
ORIGINAL: maynardrupp
Maynardrupp,
If you are looking for documentation on this modification, look at my posts #196 page 8 and #352 page 15 of this thread and you will see how I recessed the flap servos and used covers on the ailerons. You should have no trouble doing the same with your building skills. It really does improve the looks. If you would like other photos I will be happy to provide them. Cheers.
(in reply to maynardrupp)
       Post #: 429
RE: Sig's new Waco SRE - 11/27/2008 4:41:07 PM
MormonMike
Status: offline
Well, what to do about this flexable muffler pipe. It cracks about an inch from the engine head. Of course, a $40 refund from the LHS is'nt going to happen. And this is just from two ten minute flights. Sure, it looks good with the muffler and all tucked up under the cowl but, ya know, Maybe it'd be more practical to install an RC Specialties type "Turbo-Muffler". Only the very end of the exhaust pipe would protrude from under the cowl and what the heck, it's only twice as much more than the flex tube cost. Let's do it and I'll let you guys know how it works out. Seeya, MM
(in reply to silver.kiwi)
       Post #: 430
RE: Sig's new Waco SRE - 11/27/2008 5:32:39 PM
skylarkmk1
Status: offline
MM,
Try one of the Silicon Rubber exhaust connectors for tuned pipes and such at the crack. It should absorb the vibration causing the crack. Cut the flex off off at that point and smooth both ends and install the coupler. A whole lot cheaper than a new muffler. If it does not work, it is only a couple of bucks.
_____________________________
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
(in reply to MormonMike)
       Post #: 431
RE: Sig's new Waco SRE - 11/27/2008 7:33:27 PM
MormonMike
Status: offline
OK, We''ll see. MM
(in reply to skylarkmk1)
       Post #: 432
RE: Sig's new Waco SRE - 11/28/2008 2:25:05 AM
maynardrupp
Status: offline
My first one also broke at the same point, just beyond the cylinder head. I then broke the engine infurther with the stock exhaust tube. I also leaned the low speed quite a bit. Now I tried all kinds of silicone heat resistant tubing and model car tubing to repair the broken tube. All failed. We then cleaned the whole area and silver soldered it. This also failed. I finally bit the bullet and bought another new $40.00 flex pipe. This time I snipped a 2" long 1/4" wide strip of soft aluminum sheet about .035" thick. This easily wrapped around the flex pipe and I attached it to a motor mount bolt. This seemed to absorb or dampen the vibrations that broke the first one. I now have about 40 flights on the SRE and the pipe is fine.
       Post #: 433
RE: Sig's new Waco SRE - 11/28/2008 8:51:44 PM
MormonMike
Status: offline
Yup, I had an idea it was vibration. Since it'd cost another $40 bucks for a new pipe, I went ahead and ordered a Turbo Muffler instead. No big thing, MM
       Post #: 434
RE: Sig's new Waco SRE - 12/1/2008 5:22:55 PM
maynardrupp
Status: offline
quote:
ORIGINAL: MormonMike
Can you hide the "Turbo Muffler" or will it stick out? The system on the plans really works perfect after I added the vibration absorber strap and broke the engine in.
       Post #: 435
RE: Sig's new Waco SRE - 12/1/2008 11:14:40 PM
MormonMike
Status: offline
Maynard, I took rough measurments, appears to just barely fit and then I'll install a silicone exhaust extension routed to where the first muffler was at. Just luv those TurboHeader mufflers. I also appreciate your concern. This is not one of those "Chinsey-Kiddie" ARF's and deserves serious respect. I promise it will be a very neat install. I think I'll try to post a photo when it's done, maybe about a week till I recieve it. Seeya then MM
       Post #: 436
RE: Sig's new Waco SRE - 12/5/2008 11:11:40 PM
Warbird 01
Status: offline
Nice thread guys. I really like the look of this plane. I have been looking at the Pacific Gee Bee Y and happen to come across this plane. My question is: is there a copy of the build manual posted online anywhere? I always like to read them to see what all comes with the kit, and what "extras" I will need to invest in. Any information would be great. Thanks!
Shawn
       Post #: 437
RE: Sig's new Waco SRE - 12/6/2008 3:28:33 AM
silver.kiwi
Status: offline
quote:
ORIGINAL: Warbird 01
Shawn
Hi Shawn,
I own both of the planes you are considering. I like them both very much as both are very high quality ARF's. The Waco has the best manual I have seen bar none. I don't think that it is available online except that SIG may list it in the parts section of their WebSite if you wish to purchase a copy. As far as extras are concerned you will need very little as SIG has provided a very nice hardware package that adds greatly to the scale looks you see here on this thread. You will want the muffler flex pipe extension if using the Saito FA100 or similar engine. A dummy radial engine and pilot is another nice addition. Standard servos work for all controls. I added wing servo covers but the new kits are supposed to include these.......check with SIG to be sure. This thread shows other nice touches that are easy to do and really add to the scale appearence of this already great looking and flying airplane.
(in reply to Warbird 01)
       Post #: 438
RE: Sig's new Waco SRE - 12/6/2008 5:20:06 AM
Warbird 01
Status: offline
Thanks for the info. I am leaning towards the Waco for right now with the satio engine. I have found, that most of the time, when they show an engine, it is best to use it. I'm not sure if you are into electrics, but check out Pilot-1. They have several 1/8 scale golden age airplanes including a Waco YCS 6 and a Wendell-Williams Model 44. Now if someone would just come out with a Travel Air Mystery Ship. Happy Flying!
Shawn
       Post #: 439
RE: Sig's new Waco SRE - 12/8/2008 10:37:16 PM
MikeL@Sig
Status: offline
quote:
ORIGINAL: silver.kiwi
Shawn
Hi Shawn,
Shoo
