RE: SE5a 1/6 Scale Scratch Build
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Grumman Lynx - ARF
Seller:  Dean rcu
Details:   $1,900.00   |  3/17/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: SE5a 1/6 Scale Scratch Build
Page: <<   < prev  16 17 18 [19] 20 21 22 23 24 25   next >   >>
Login
RE: SE5a 1/6 Scale Scratch Build - 7/8/2007 11:36 AM
timfarrar
Score: 100
Last Login: 12/16/2009
Status: offline
Steve :
You need to simulate a big rip in the side of the covering so you can see that beutiful work in there.
SEEYA, TIM
_____________________________
Build light to fly, not strong to crash.
http://home.earthlink.net/~timothyfarrar/index.html
Hide Signatures
(in reply to smcouch77)
       Post #: 451
RE: SE5a 1/6 Scale Scratch Build - 7/8/2007 1:26 PM
smcouch77
Score: 100
Last Login: 3/20/2010
Status: offline
Thanks Tim. Maybe some really big bullet holes would work.
I've got the other side stitched and I'm puting on the lower wing stubs. I'll post some pics when they're on.
Steve
< Message edited by smcouch77 -- 7/8/2007 1:28 PM >
Life is too short to fly ugly airplanes!
Hide Signatures
(in reply to timfarrar)
       Post #: 452
RE: SE5a 1/6 Scale Scratch Build - 7/8/2007 6:17 PM
R8893
Score: 100
Status: offline
I have used those nib type drafting pens with paint. I had to thin the paint quite a bit. And just like in high school drafting class I left big blobs where they didn't belong. Never could ink a drawing; didn't need to by the time I discovered Rapidographs.
Chuck
Hide Signatures
       Post #: 453
RE: SE5a 1/6 Scale Scratch Build - 7/8/2007 6:27 PM
BobH
Score: 100
Status: online
I use Rapidograph pens too. I have several different diameters that work well. They are especially nice when outlining lettering that's to be painted in.
BobH.
Hide Signatures
(in reply to R8893)
       Post #: 454
RE: SE5a 1/6 Scale Scratch Build - 7/9/2007 1:48 AM
smcouch77
Score: 100
Status: offline
I never had any luck with the drafting pens either. Can I assume that the Rapidograph pens are available at a drafting store?
I finished the fuse stitching, today. Also, I attached the wing root sections and made the aluminum fairings. The fairings are made with a heavy aluminum foil I got at Hobby Lobby. It's beginning to look a lot like an airplane
Steve
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to BobH)
       Post #: 455
RE: SE5a 1/6 Scale Scratch Build - 7/9/2007 6:26 PM
R8893
Score: 100
Status: offline
Roger on the Rapidograph
Hide Signatures
       Post #: 456
RE: SE5a 1/6 Scale Scratch Build - 7/10/2007 8:21 AM
camdyson
Score: 100
Last Login: 2/2/2010
Status: offline
Using a nib in a compass to cut in is really not that hard - my first ever go was on my old Puppetteer using humbrol enamels, and I found it pretty easy actually.
Looking amazing btw Steve.
Cheers,
Cam
Click for fullsize
Hide Signatures
(in reply to R8893)
       Post #: 457
RE: SE5a 1/6 Scale Scratch Build - 7/10/2007 10:43 AM
smcouch77
Score: 100
Status: offline
Hi Cam. Good to hear from you. Maybe I should try my hand at using a nib again. I was very young the last time and didn't have much patience. Your roundels look great.
Steve
Hide Signatures
(in reply to camdyson)
       Post #: 458
RE: SE5a 1/6 Scale Scratch Build - 7/10/2007 2:35 PM
abufletcher
Score: 1540
Status: online
I was thinking the same thing. Cam, those roundels look PERFECT!
Hide Signatures
       Post #: 459
RE: SE5a 1/6 Scale Scratch Build - 7/10/2007 11:47 PM
timfarrar
Score: 100
Status: offline
Hey guy's :
Do one of you have a picture of this nib you are talking about ?
I dont know what it looks like.
Is it filled with paint or something ?
SEEYA, TIM
Hide Signatures
(in reply to abufletcher)
       Post #: 460
RE: SE5a 1/6 Scale Scratch Build - 7/11/2007 6:24 AM
camdyson
Score: 100
Status: offline
I'll dig it out and post a pic tonight. Yes, it has a nib which you dip in the paint and use like a fountain pen - I'll explain the "secret" when I post the pics.
Cheers,
Cam
Hide Signatures
       Post #: 461
RE: SE5a 1/6 Scale Scratch Build - 7/11/2007 11:26 AM
camdyson
Score: 100
Status: offline
O.K., couple of pics attatched. As you can see, the compass will do circles to about 200mm diameter - nearly 500mm with extension.
Easy to use, just dip the nib in the paint - unthinned - so there's 5-6mm or so captured, and WIPE EXCESS OFF OUTSIDE OF NIB. Then just practise lines as you slowly wind nib open/closed to get the desired thickness, and you're away. Refill, wipe outside, and go for it!
To do circles on painted fabric, just tape a small piece of thin ply at the rough centre to protect it from the compass point, and mark the centre. Paint the light colours first, eg white in the case of my Pup, and overlap border where darker colours will be. Then use compass/nib to draw borders of darker colours, and fill in by hand with a brush.
I've also used Frisket film and sprayed, more on WWII fighters, but hand-painting seems more "characteristic" on WWI planes. I even used the nib freehand to do the lettering - again to my "sport scale" standards only, but easier than a brush!
If that's still not clear let me know and I'll dig out some photo sequences of the actual process.
Cam
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by camdyson -- 7/11/2007 11:27 AM >
Hide Signatures
       Post #: 462
RE: SE5a 1/6 Scale Scratch Build - 7/11/2007 12:00 PM
smcouch77
Score: 100
Status: offline
Thanks Cam. Your "Sport Scale" lettering looks fantastic. I definitely have to try this method out. I still have to "paint" this little guy twice. He's 2" tall.
Steve
Click for fullsize
Hide Signatures
       Post #: 463
RE: SE5a 1/6 Scale Scratch Build - 7/11/2007 2:14 PM
camdyson
Score: 100
Status: offline
Looks like he has "small man syndrome......"
Hide Signatures
       Post #: 464
RE: SE5a 1/6 Scale Scratch Build - 7/11/2007 4:39 PM
smcouch77
Score: 100
Status: offline
Naaa! I think he just has an "Ax To Grind"
Steve
Hide Signatures
       Post #: 465
RE: SE5a 1/6 Scale Scratch Build - 7/12/2007 6:49 PM
smcouch77
Score: 100
Status: offline
I finished the bottom covers today. I still need to make the false hinges, but they won't go on until final assembly. The front cover will be removable as will the one under the pilot's seat.
Also, I made the drain cock for the radiator. The handle is removable, making it functional. It will be used to drain the oil from the catch tank for the crankcase breather.
At last, the fuselage is ready to paint. So I guess I'd better get offline and get busy.
Steve
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 466
RE: SE5a 1/6 Scale Scratch Build - 7/12/2007 11:24 PM
timfarrar
Score: 100
Status: offline
Cam :
Thanks very much for your exsplanation, it was very clear and I think that it is amazing how you painted that writting on your rudder.
It looks great.
Steve :
I dont know what to say................ Your plane just makes me sick
You are truely doing an amazing job.
SEEYA GUY'S, TIM
Hide Signatures
       Post #: 467
RE: SE5a 1/6 Scale Scratch Build - 7/13/2007 1:21 AM
abufletcher
Score: 1540
Status: online
Steve, one question about the stitching. How do you cover up the front and rear end of the stitching. Is this covered up under "edge tapes?" And how do you do the edge tapes?
Hide Signatures
       Post #: 468
RE: SE5a 1/6 Scale Scratch Build - 7/13/2007 3:02 AM
smcouch77
Score: 100
Status: offline
I ran the stitching out to the leading and trailing edges and cut it off flush. The edge tape covers it. I tried to use a single tape to wrap around the edges, but since the edges change thickness at each rib the result looked scalloped. So I ran a strip along the bottom edge and cut it off flush with the edge. Then I ran another strip along the top and overlapped the bottom about an 1/8". Since the bottom edge is outlined with PC10 the seam dosen't show.
I painted the fuse today. Tomorrow I'll start on the markings. I want to have everything painted before I start with the clear coat. That way I'll have the best chance of getting an even finish overall. Then I can start making it look uneven and weathered
Steve
Hide Signatures
       Post #: 469
RE: SE5a 1/6 Scale Scratch Build - 7/13/2007 9:55 PM
smcouch77
Score: 100
Status: offline
I got a couple of new toys today. A beam compas, extension, and a Rapidograph pen. The compas uses a clamp (very strong) to hold whatever in place. No excuses for sloppy roundels now
Steve
Click for fullsize
Hide Signatures
       Post #: 470
RE: SE5a 1/6 Scale Scratch Build - 7/14/2007 5:37 AM
abufletcher
Score: 1540
Status: online
Two questions: From where and how much? I'm tempted to pick up one of these myself over the summer. What's the deal with the radiograph pens by the way? Are they just for black or can they be filled with any color (or any paint)?
Hide Signatures
       Post #: 471
RE: SE5a 1/6 Scale Scratch Build - 7/14/2007 11:25 AM
smcouch77
Score: 100
Status: offline
I got them at an art supply store (Prisim). You should be able to get them at any drafting or art store. Compas $17. Extension $10. Rapidograph pen $17.
The pen has a cartridge that you fill with your medium. They come in different sizes. I didn't get the largest, which was a mistake. Even thinned down to water I can't get it to flow.I'm going to try adding a wetting agent and see if that works. If not I'll get the largest pen and try that.
Steve
Hide Signatures
       Post #: 472
RE: SE5a 1/6 Scale Scratch Build - 7/15/2007 9:56 PM
smcouch77
Score: 100
Status: offline
I finished getting the colors on today. I'll let it dry for a few days and then everything gets a couple of coats of poly.
BTW, if anyone knows how to use the Rapidograph pens, I could use some help. I couldnt get anything thicker than water to flow through. I got the largest they had (size 7) but no luck. So the markings had to be done with a brush.
Steve
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 473
RE: SE5a 1/6 Scale Scratch Build - 7/16/2007 4:00 AM
abufletcher
Score: 1540
Status: online
You suddenly look like you're almost done! I'm envious!
Hide Signatures
       Post #: 474
RE: SE5a 1/6 Scale Scratch Build - 7/16/2007 4:34 AM
smcouch77
Score: 100
Status: offline
About all that's left is a couple of coats of varnish and assembly. I still have to make the dummy engine and of course the rigging, but I think it'll be ready for the NATs.
Your wings are looking great. Actually you're ahead of me since you have your rigging done. Now I'm envious
Steve
Hide Signatures
       Post #: 475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.453RCU1
