crimsonrain22
IN, USA Status: offline
Well I just came in from my first semi major crash. Been flying my fixed pitch around alot and getting braver, Wind was low, sky was blue so I was feeling brave. Took the king out to my back yard launch pad, Kids had a pool over the summer so I have a 15ft circle with no grass in my yard. Gave it a test hover, sit it back down all looked good so I fliped the scary switch(throtle hold) took it up and gave it full right rudder. It spun around and stopped perfect, With a big smile on my face I wanted more, so I flew up alittle higher and gave full right aileron control rolling it over while applying negative pitch been going through this in my head now for days. So there I was upside down in a perfect hover, l gave it allittle more negative and more aileron and fliped it back over. Thinking ok so far so good then allittle wind came tail swings out. I correct, over correct and its headed towards my house at record(for me) speed. I try to correct again, over correct and try to level it out and smack it hits the ground and flops allitlle im in so much shock it takes me a second to think Idle up is on and it flops around allittle. All in all very little damage as I was flying instead of fixing my lawn mover so my lack of lawn maintenance saved the day. Broken body mount rod, Striped main gear and a few chips on the blades, Bent feathering shaft, good things the ones crashcrash sent me came in today. New parts on the way with some new frp blades and some trex tail blades from rusty. I know what went wrong but will most likely forget what it was as soon as I have a tx in my hand. And a short video of it right before, Wife was taping and camera shut off right before I inverted it, just my luck. http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=21078598
< Message edited by crimsonrain22 -- 10/30/2007 4:58:37 AM >
_____________________________
Gravity Sucks.......... Trex 450
