RE: GAS Saito
Tower Hobbies
Logged in as Guest
Users viewing this topic: racer rob-RCU, mobilemenice80, kiosk, Ed Vollmer, Olli-Matti, Hans Meij, bhorton
  Printable Version
50' Gas fuel tubing
Seller:  RC Extreme power
Details:   $25.00   |  9/27/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: GAS Saito
Page: <<   < prev  6 7 8 9 [10] 11 12 13 14 15   next >   >>
Login
RE: GAS Saito - 4/2/2008 11:18:01 PM
reincarnate
Status: offline
quote:
ORIGINAL: kochj
Did you guys get you MAN copy???
There RPM figures for the FG-36 Seem to be padded~.....
They do not seem to be close to what others are getting.....
20X8 APC=7500
18X10 APC=8100
A SPE 40cc gas RPS:
20X8=7150
18X10=7350
So the Saito 36cc puts out more power than a 40cc gas 2-stroke??????
Any one feel that this is a little odd???
Justin
They're actually a little thin if anything. I know, I know, MAN always pads their articles, but this one is actually pretty close from what I've seen on mine. I've only run four props so far, so not a huge baseline but:
18x8 MAS Classic=8300
18x10 Xoar=7900
19x6 Xoar=7800
20x8 Xoar Sword=7400
Looking to running a 20x6 Xoar for flight, so hopefully they have a rep at Toledo!
89 Octane US and Evolution oil at 20:1. Air temp was 50 deg F. All RPM at same needle setting.
Besides Justin, RPM doesn't necessarily equate to power as you know. The Saito will develop it's most efficient power at a different place than the SPE, and that's not top end.
The Saito will sound better doing it though...
(in reply to kochj)
       Post #: 226
RE: GAS Saito - 4/2/2008 11:29:26 PM
kochj
Status: offline
quote:
ORIGINAL: Hans Meij
Had one one the bench today, and it was much better then I expected.
After about half a tank of fuel
Menz 18*8 8100
APC 16*12 8300
Engel 18*11 (this is a narrow blade carbon prop) 7900
Engel 17*12 (this is a wide blade carbon prop) 7600
Fuel: Shell VPower , 1:20 Mobil one oil.
This engine performed 500 rpm better than my OS200 on 10% nitro
The only prop I can relate the 40cc engine too is the APC props.....
This is how I am able to make a comparison between the two engines......
Different props even though same pitch and length, gives me nothing to make the comparison too.......
So, actually those mean nothing to a direct comparison test.......
If I used those same props you have there on the FLy RC magazine SPE 40, then I would have a direct comparison!....... But I do NOT....
Someone said back a bit in the forum that MY Giant Aeromaster w/ a saito gas would be simular to mounting a 32cc gas engine on it and would barly fly it!.....
Care to Rethink that one??????????????????/
Sounds as if this engine is puting out far more power than the KNaw sayers had initially anticipated!......
Good to hear!..... This engine sounds like a keeper....
Justin
_____________________________
Winning isn''''t everything, it''''s all there is.
(in reply to Hans Meij)
       Post #: 227
RE: GAS Saito - 4/3/2008 7:09:35 AM
Hans Meij
Status: online
quote:
ORIGINAL: kochj
You are right about that. I even find it difficult to compare a two stroke with a four stroke only based on ground-rpm numbers.
For me this engine was a pleasant surprise, vibrations for such a large single fourstroke were moderate, exhaust fumes were clean (even with the 1:20 mix) fuel consumption was really low.
I will try this engine on a pattern ship and see how it performs for that purpose. For a big draggy plane like a giant aeromaster i would select a bigger engine however. I'm sure it will not do better than what you have experienced before.
It was this video, that convinced me to give it a try.
http://www.hokusei-japan.com/FG-36-Edge1.wmv
http://www.hokusei-china.com/P%20P%20EDGE%20540T%2026CC.htm
< Message edited by Hans Meij -- 4/3/2008 7:22:17 AM >
(in reply to kochj)
       Post #: 228
RE: GAS Saito - 4/3/2008 7:55:39 PM
kochj
Status: offline
Ahaa...
I was wondering where I downloaded those videos from!....
I posted them on the RCU video page as well...
In a MAN review (hear I go again)LOL........ THey used a O.S. 1.60FX and said that it had plenty of power!..... Flew great and said that you
could make the loops very large without it falling off.......
I know that the O.S. 200 FS is not as powerfull as the OS 160FX..... (Except for the High ENd Fuel Injected one) Few 400 less according to some pattern guys.......
If the Saito is pulling about 400rmps more than the O.S 200, then I can conclude that it is very Simmular in power to a O.S 1.60FX nitro 2-stroke?
I am just trying to get some sort of an idea of engine comparison and what planes this engine would work in.......
The Aeromaster seems like it would be too big of a plane for this engine... But according to those RPM nubers..... The FUji 43 works great in it... and If the Saito is pulling
more than some of the 40cc gassers.... I would not think twice about placing it in that plane!.....
THen again, I could be way off,,,, been there before!.....I know, the Whole 4 stroke 2-stroke power band thing... But the RPM numbers seem amazing to me.....
Justin
       Post #: 229
RE: GAS Saito - 4/9/2008 12:07:29 AM
kiosk
Status: online
quote:
ORIGINAL: reincarnate
Mines installed and ready to test in the H9 1.50 Mustang. Pretty involved firewall mod, but overall not too bad. Break in testing this weekend if it doesn't rain.
what size fuel line are you using on your FG36?
(in reply to reincarnate)
       Post #: 230
RE: GAS Saito - 4/9/2008 6:09:16 AM
wswanepoel
Status: offline
[/quote]
[/quote]
I used medium size (here we get small medium and large) fuel line, but you can use small as well as this motor consume very little fuel.
Regards Bill
Remember: Nose heavy planes flies like a dog. Tail-heavy planes only fly once.
(in reply to kiosk)
       Post #: 231
RE: GAS Saito - 4/9/2008 1:20:48 PM
SteveD-RCU
Status: offline
quote:
ORIGINAL: wswanepoel
I have the same sticky exhaust valve problem every 3 to 4 flights. I have to open and lubricate the valve and then i can fly again. I am on 20:1 mix and has done about 12 flights now. Any suggestions will be welcomed. What about adding some valve ease or injector cleaner to the gas? is this an option? Might a different type of oil help? I am using standard ACE hardware ash less two stroke oil.
BTW: It is installed in a Cessna 182 skyline supposed to have a 120 to 150 four stroke, but it is flying fantastic with this 36 gas Seito. It has a 435ml tank and filled with gas will last more than 1hour and 15 minutes.
Thanks in advance.
Can you give us more details wswanepol?did your engine die in flight?Did the exhaust valve stick just prior to a flight?Do you think its the rich mixture that maybe is causing the valve to stick?Maybe since your engine is basically broken in with 12 flights you might try 30:1 mix to see what happens.Then maybe try a different oil.Keep us posted.
Steve
< Message edited by SteveD-RCU -- 4/9/2008 1:33:30 PM >
(in reply to wswanepoel)
       Post #: 232
RE: GAS Saito - 4/11/2008 7:32:55 PM
togatoga
Status: offline
Tsutomu's friend reported the same thing about the sticky valve due to lack of lubrication. Did the same thing and lubricated the rocker shaft to free it.So far no word from Saito as to a fix.I'm holding off running the engine until I get word of a fix if there is one I hope.Don't want to ruin the engine.
(in reply to SteveD-RCU)
       Post #: 233
RE: GAS Saito - 4/11/2008 8:10:41 PM
wswanepoel
Status: offline
quote:
ORIGINAL: SteveD-RCU
Steve
Hi Steve
The engine never died in flight. If I want to start it the next flight there is just no compression. I have tried other brands of oil with the same effect. Although I have had about 12 flights now I am scared to go to 30:1 mixture as they say 5 tanks of 20:1 for braking in their manual. That will mean about 6 hours of flying time. As we are in the desert here I keep my flights to about 5 to 6 minutes as it is on average between 30 to 35 degrees here. I have fitted a temperature probe on the cylinder head and although the temperature never go over 92 deg Celsius, I am still scared to fly for longer periods. giving all this I only have done about 1 hour 30 minutes on the engine and as I say I don't really know if it is run in or not. I was actually waiting to reach 2.5 litres of fuel before going over to 30:1. As a matter of interest I have added plus minus 50 ml of valve ease / injector cleaner to the 3 litres of gas that I have mixed and on the last 3 flights I had no sticky valve problem anymore. It is to early to say but I will add another 6 flights tomorrow(weather permitting) and then I will be able to be certain if this did solve the problem.
I will keep you posted.
Regards Bill
       Post #: 234
RE: GAS Saito - 4/14/2008 6:15:55 AM
wswanepoel
Status: offline
It seems that they have lost some messages here.
To recap I have done 6 flights yesterday morning and 3 yesterday afternoon
resulting in about 60 minutes for flying. The sticky valve issue is
something of the past. Weather it is the Valve Ease/ Injector cleaner
additive that I have mixed with the fuel. Or whether the engine is becoming
lose I don't know, but I am just glad it is something of the past. I also
noticed that my head temperature is 10 deg Celsius lower than what it was
before.
Has anyone have an idea for a choke on this engine. If you do a hand start
you do need a choke of some sort in my opinion.
I attaché a picture of the bottle of valve ease/ injector cleaner additive
that I have used.
Click to see fullsize image.
Click for fullsize
< Message edited by wswanepoel -- 4/14/2008 1:38:22 PM >
Regards Bill
       Post #: 235
RE: GAS Saito - 4/14/2008 1:08:35 PM
SteveD-RCU
Status: offline
Thats good news Bill,the only thing I can think of for the choke problem is to install a primer line with the outlet near the carburator .Saito had a setup like this for their 170R which needed prime for the first run although all it did was add a little fuel to a small bowl beside the carb and it drained in from there.Would be easy to tap into the carb line near the carb with a t-fitting with a 1/8" line maybe?
Steve
       Post #: 236
RE: GAS Saito - 4/14/2008 1:50:55 PM
wswanepoel
Status: offline
Steve
This might be a good idea. If somebody have a picture of this I would appreciate it.
Regards Bill
       Post #: 237
RE: GAS Saito - 4/21/2008 8:09:15 PM
normandouellette
Status: offline
Hello guys just joining to get updates.
Any issues on this engine so far other than sticky valves? I'm looking to get 4 to power my avro Lancaster 17 feet. The 4 stroke is apealing.
Normand
       Post #: 238
RE: GAS Saito - 4/21/2008 8:48:05 PM
SteveD-RCU
Status: offline
None yet that I've heard Normand.A 17ft Lanc sounds like quite a project,did you draw your own plans?My DC3 will soon be ready with the Saito gassers I'll give a report soon.
Steve
(in reply to normandouellette)
