rv8pilot
FL, USA Status: offline
Recently bought one of these having thought for years that the idea of a quality four-stroke gasser would be great. Over the last couple days I ran it in for a total of about 40 minutes or so. Difficult to start by hand without choking, but starts ok after its wet. Hot starts are fine. Seems to run fairly smooth for a big single. Today I finally had what I felt was enough running time to go to full power. I'm using a Master Airscrew 18x8 and the engine could get no more than 7100 rpm regardless of needle settings. Max rpm occurred at about 3/4 throttle, and more throttle did nothing. Having read the posts about cam timing affecting torque and rpm, I tried an old Dynathrust (remember them?) 20x8, close enough to a Master Airscrew in shape to be comparable. It turned 7000rpm. According to the horsepower calculator on the net by Barry Hobson, an 18x8 at 7100 is using about 2hp, and a 20x8 at 7000 is using about 3hp. So what is going on here? I suspected that the cam gear timing might have been off and called Horizon and spoke to Nathan. Got his ok to tear down the top end and check/reset the cam gear (I've done this a lot as I repair these things as sideline), to make a long story short, no change in running-still 7100 on the 18x8. Now I'm thinking that it may be a fuel delivery problem in the carb. Nothing else in the fuel system is restrictive, so I'm at a loss here. Anybody want to take a shot at this. Its beginning to sound a little like the guy who got 8500 originally and now only gets 6700. (Sorry, I forgot the fellows name.)
